whas wondering if i can make tssop pcb?
Re: [Homebrew_PCBs] whas wondering if i can make tssop pcb?
2007-11-27 by DJ Delorie
"eloitmtl21" <processor_83@...> writes:
> hello  i whas wondering if i can make pcb  for tssop device with the
> laser printer method ?
TSSOP only needs 10/10 rules.  I've done VSSOP with toner transfer,
which needs 8/8 rules (well, 7.8/7.8 rules - 0.4mm pitch).
In these, the vssop chip is the 14 pin one:
http://www.delorie.com/pcb/smd-challenge/old/proto-boards.html
In this one, the vssop is to the right of the capacitors:
http://www.delorie.com/pcb/first.html
2007-11-27 by Dylan Smith
Yes.
I've done home made boards with laser toner transfer for an LQFP with
0.4mm pitch. It takes some care (good paper, careful ironing on, don't be
too vigorous when removing the paper since the small pads/traces can be
easy to rub off). IIRC, TSSOP has the same pin pitch as an SSOP - which I
found to be not too hard at all.
