OHP Film, Transperancy, Acetate Film
2007-09-02 by Mr Crazy
Does any one know if OHP film, Transperancy and Acetate Films are the same or all are different?
Which is the best for Toner Transfer?
Parag
Pinpoint customers who are looking for what you sell.
[Non-text portions of this message have been removed]2007-09-02 by Stefan Trethan
On 9/2/07, Mr Crazy <crazymr420@...> wrote: > Does any one know if OHP film, Transperancy and Acetate Films are the same or all are different? > > Which is the best for Toner Transfer? > > Parag > > I'm not sure if any of the above is ideal for TT (i consider them one and the same BTW). Some people have said it works, but most people seem to prefer soaking the paper to dissolve it. ST
2007-09-02 by Andrew
> > Mr Crazy wrote: > > Does any one know if OHP film, Transperancy > > and Acetate Films are the same or all are > > different? > > > > Which is the best for Toner Transfer? > ST wrote: > I'm not sure if any of the above is ideal for > TT (i consider them one and the same BTW). > Some people have said it works, but most people > seem to prefer soaking the paper to dissolve it. When I used to do TT I used OHP transperancies and found there was as much variation from brand to brand as people find with different paper stocks. I agree with ST that the three names above seem to be used interchangeably (even if there may be some technical difference I don't know of)
2007-09-03 by Mr Crazy
I was asking for it as I am not getting good results with them for TT. What is the other reliable and reasonable method can be used for this? Photoresist film?
Parag
> > different?
stocks.
Ready for the edge of your seat? Check out tonight's top picks on Yahoo! TV.
[Non-text portions of this message have been removed]2007-09-03 by Len Warner
At 11:41 pm ((PDT)) Sat Sep 1, 2007, in Digest 2273 Mr Crazy wrote: >Does any one know if OHP film, Transperancy 'transperancy' is presumably a mis-spelling of 'transparency' 'OHP Film' and 'transparency film' are probably synonymous in this context, though 'transparency film' has a quite different meaning in the context of silver-emulsion photography. >and Acetate Films are the same or all are different? 'acetate film' is a subset of OHP film and is likely to be unsuitable for toner transfer (TT) because it is likely to melt in the laser printer fuser and occasion an expensive repair. >Which is the best for Toner Transfer? None of these terms is an adequate specification for TT. You need a film which is safe against laser fuser temperature, so you need either a laser transparency film or a laser-safe inkjet transparency film. If, indeed, you need a _transparency_ film for TT at all, since the purpose is not projection of the image but mechanical transfer of the toner medium. Note that many people are using inkjet printer _paper_. The reason for this is that the structure of some papers includes a layer which separates in water, allowing the paper to be peeled from the toner image. In others, the backing paper disintegrates on soaking and can be removed with mechanical encouragement. Some magazine and catalogue paper is coated and separates in water so this provides a very cheap source which for many people gives satisfactory results, though you will have to experiment until you find ones which work for you. If you look in the group archives you will find plenty of discussion on these topics. Regards, LenW
At 7:26 am ((PDT)) Sun Sep 2, 2007, in Digest 2274 Stefan Trethan wrote: >On 9/2/07, Mr Crazy <crazymr420@...> wrote: > > Does any one know if OHP film, Transperancy and Acetate Films > > are the same or all are different?[snip] > >I'm not sure if any of the above is ideal for TT (i consider them one >and the same BTW). Some years ago, at the college where I then taught computing, so did some of the newly (but partially) computer-literate teaching staff. As they began to word-process their classroom presentations and sought to emulate more knowledgeable staff who were printing direct to OHP slides or photocopying printed copy**, they discovered the hard way that the _acetate_ film on which they had been used to hand-draw was inadequate. The least-bad outcome was that the sheet cockled in the printer or photocopier and the result was probably unusable. The worst outcome was that the sheet never emerged - it had wrapped itself into a heat sealed tube around one of the fuser rollers and the printer or copier would be out of action until a technician could find the time to dismantle it. [** We found that a denser projection image could be obtained by photocopying paper printouts than by laser printing directly. The laser printers of the time couldn't transfer as much toner to plastic film as they could to paper, while the copiers had no problem making a dense copy onto film.] Later, we had another (but less disastrous) learning experience when new-model fuser temperatures went up and some photocopier transparency film proved insufficiently heat resistant and was likely to distort during printing. ISTR that some types of film had a temporary paper backing sheet which made them behave better than un-backed ones - and there was a warning on the pack not to remove the backing before printing. 'Acetate' is an old term for old material which may still be available. Don't specify it and don't try to put it through a laser printer. Regards, LenW
Hi Len,
Thanks for the answer, no wonder I was not getting the results. I will try with the methods you suggested, laser transparency film, inkjet paper, mag paper.
The last time I tried with the transparency, image really became skewed at one end. Drawing was in perfect rectangle, but printout was not, I think it was because of transparency not being Laser transparency.
regards,
Parag
Len Warner <novost@...> wrote: At 11:41 pm ((PDT)) Sat Sep 1, 2007, in Digest 2273 Mr Crazy wrote:
on these topics.
Regards, LenW
Yahoo! oneSearch: Finally, mobile search that gives answers, not web links.
[Non-text portions of this message have been removed]2007-09-03 by Andrew
> Len Warner wrote: > <SNIP> > If, indeed, you need a _transparency_ film > for TT at all, since the purpose is not > projection of the image but mechanical > transfer of the toner medium. > > Note that many people are using inkjet > printer _paper_. > My reasons for using the OHP trannys many moons ago was because the toner transfer worked quite well and there was no paper fuzz that I got when experimenting with papers. These days with a plethora of clay coat type inkjet papers around there may be no advantage to the OHPs. I have just bought some homebrand ink jet paper to give a try to see how it compares.
2007-09-03 by Thomas D. Kask
I have been reading the posts as they come across my email for a few weeks now hoping to get more insight on this process. I have accomplished TT PCBs with mediocre results in the past using online guides from across the internet. I believe my biggest hindrance has been using a paper poorly suited. As I read here there seem to be lots of "what not to dos, but I haven't gotten a very concise concept of what does work consistently well and is readily available today. What paper or transparency can I go out and purchase today at Wal-Mart, CompUSA, Office Max/Office Depot (No Staples here) or similar store common in south-eastern US? I get good clear detailed lines on my print, just bad transfers, mostly no transferring completely, resulting in pitted toner images transferred to my CC board. Hope you guys can suggest some commonly available local sources for good TT paper or transparency. Thanks. tdkask [Non-text portions of this message have been removed]
2007-09-04 by timbomcnuckle
save your few dollars- use glossy magazine paper- don't worry if it is printed upon already. This material works great, disolves great- overall great results! found out the hard way./jd --- In Homebrew_PCBs@yahoogroups.com, "Thomas D. Kask" <tdkask@...> wrote:
> > I have been reading the posts as they come across my email for a few > weeks now hoping to get more insight on this process. I have > accomplished TT PCBs with mediocre results in the past using online > guides from across the internet. I believe my biggest hindrance has been > using a paper poorly suited. As I read here there seem to be lots of > "what not to dos, but I haven't gotten a very concise concept of what > does work consistently well and is readily available today. What paper > or transparency can I go out and purchase today at Wal-Mart, CompUSA, > Office Max/Office Depot (No Staples here) or similar store common in > south-eastern US? I get good clear detailed lines on my print, just bad > transfers, mostly no transferring completely, resulting in pitted toner > images transferred to my CC board. > > > > Hope you guys can suggest some commonly available local sources for good > TT paper or transparency. > > > > Thanks. > > tdkask > > > > [Non-text portions of this message have been removed] >
2007-09-04 by DJ Delorie
I use the Pulsar paper with very good results. The other trick I've read about but not yet tried is to use plain gelatin, diluted 4:1, to coat your own paper. The key is that whatever paper you use should have a coating that is (1) heat resistant but (2) water soluble. Some "glossy" papers have a clay coating on them, for example. DO humidify your paper. A few minutes in a closed box with a container of water (don't get the paper wet) softens the fibers so they lay flat and take a more even layer of toner. DO use sufficient heat, else the toner won't stick well. DO let the paper soak fully. Pulsar paper just floats away when it's done, resist the urge to help it along. DO clean the board well, and dry fully. Keep your grubby fingers off the copper! And the paper! And the toner!
2007-09-04 by Jim Hutchinson
timbomcnuckle wrote: > save your few dollars- use glossy magazine paper- don't worry if it is > printed upon already. This material works great, disolves great- > overall great results! found out the hard way./jd > > Magazine paper is very thin ... does it have to be put on a "carrier sheet" or will my HP 1021 handle it ok ??? and dose the ink load have an effect ie sparse print vs dark picture ... Jim
> --- In Homebrew_PCBs@yahoogroups.com, "Thomas D. Kask" <tdkask@...> wrote: > >> I have been reading the posts as they come across my email for a few >> weeks now hoping to get more insight on this process. I have >> accomplished TT PCBs with mediocre results in the past using online >> guides from across the internet. I believe my biggest hindrance has been >> using a paper poorly suited. As I read here there seem to be lots of >> "what not to dos, but I haven't gotten a very concise concept of what >> does work consistently well and is readily available today. What paper >> or transparency can I go out and purchase today at Wal-Mart, CompUSA, >> Office Max/Office Depot (No Staples here) or similar store common in >> south-eastern US? I get good clear detailed lines on my print, just bad >> transfers, mostly no transferring completely, resulting in pitted toner >> images transferred to my CC board. >> >> >> >> Hope you guys can suggest some commonly available local sources for good >> TT paper or transparency. >> >> >> >> Thanks. >> >> tdkask >> >> >> >> [Non-text portions of this message have been removed] >> >> > > > > > Be sure to visit the group home and check for new Links, Files, and Photos: > http://groups.yahoo.com/group/Homebrew_PCBs > Yahoo! Groups Links > > > > > >
Jim Hutchinson <jhutch17@...> writes: > Magazine paper is very thin ... does it have to be put on a "carrier > sheet" or will my HP 1021 handle it ok ??? I always cut out a section of paper "just big enough" and tape it to plain copy paper when I print, it works just fine. No reason why you couldn't do it with magazine paper. What I do is print on the plain paper first, so I know where the image is going to show up, then tape the TT paper over that image. I haven't missed the TT paper yet :-)
2007-09-04 by keith
On Monday 03 September 2007 22:18, DJ Delorie wrote: > Jim Hutchinson <jhutch17@...> writes: > > Magazine paper is very thin ... does it have to be put on a "carrier > > sheet" or will my HP 1021 handle it ok ??? > > I always cut out a section of paper "just big enough" and tape it to > plain copy paper when I print, it works just fine. No reason why you > couldn't do it with magazine paper. What I do is print on the plain > paper first, so I know where the image is going to show up, then tape > the TT paper over that image. I haven't missed the TT paper yet :-) > > > What do you use for tape? Having it come off could be messy. -- Keith Bowers - Thomasville, NC
keith <kabowers@...> writes: > What do you use for tape? Having it come off could be messy. Plain old cellophane (scotch) tape. I don't try to peel it off the TT paper; peel it off the plain backing paper, then cut it off the TT paper. Or I put the whole thing in a paper cutter and just cut the tape off the TT paper; the carrier get cut too but who cares? Or cut the TT paper off the backing with scissors. Note: you ONLY tape the LEADING edge of the TT paper; not the corners, and not all the way around! The "leading" edge is the one that enters the printer first. When done right, you can lift the TT paper up and easily cut the tape off without having to remove the tape from the carrier.
2007-11-05 by Dennis
Hi Parag, I can't answer your questions about the differences, but can tell you what did and didn't work for me. I've had good success with HP Inkjet transparencies. They have several grades; I can give the exact part number if you're interested. I'm using a Lexmark Optra E+ printer with toner refills; I haven't found toner to be a significant variable. I've used the OEM toner and any brand of refill and haven't noticed a difference. Nothing else worked very well. Some CompUSA inkjet transparencies looked like they'd do well (better toner coverage), but I couldn't get a good transfer. May need to work on ironing time. Also tried laser transparencies and transparencies used for color wax printers (Phaser type). Nothing worked as well as the HP inkjet transparencies. With all inkjet transparencies, I get virtually 100% of the toner transferred. Laser transparencies appear to have a greater affinity for toner; but I was doing a "hot" remove back then. With inkjet, I do a "cool" remove. Since I'm not using the laminator technique, I find that the transparencies allow me to apply heat/pressure where needed. You need to cover the transparency with a paper towel to protect the carrier from melting. This will also help for double sided applications because you can see through the carrier to line things up. To date, the only double sided boards I've done were for card edge connectors and I did the layout so that I only needed the fingers to line up -- basically 2 single sided layouts on the same board. The paper towel will take a pass or two to shed excess fibers; then sticking to the transparency will lessen. I typically have some pin holes, but nothing that's more than cosmetic and I've never noticed any etching all the way through the copper. If you remove all of the toner (I used to leave it to prevent oxidation), you could scrub the copper to remove any oxidized spots. Copper fills are more problematic, but they can be touched up with an etch resist (I use fine point black Sharpies, ultra-fine and industrial chisel tips don't work). But that's purely cosmetic. If you're worried about conductors being compromised by the pitting, you could make them wider or tin the traces with solder. I tried using a solder pot for tinning, but temperature appears to be important and I need to perfect my technique. I've only had traces from an inkjet transparency transfer that were "bad" enough for me to want to go over it with a Sharpie once; I was too lazy to clean the board and try again. That board was 100mmX160mm (posted with my photos). An upside to my inkjet transparency method is that once ironing is done and the board has cooled to the touch, I'm almost ready to etch. No soaking/rubbing or dealing with paper fibers. I use a toothbrush scrub with some liquid soap to remove any traces of the coating from the transparencies. Then I do any touch-up before etching. One last thing. Since the carrier is transparent, I can see how much traces are spreading. I can also see how small the pad/via holes are getting. I like to have them almost closed to use as a pilot hole for drilling. I choose the smallest hole diameter for all holes. For library components, I put a via on them (there are times when Eagle complains). I usually end up cutting and pasting the metal/vias to a different board, replacing library pads with vias, and arraying the pattern to fill an 8.5x11 sheet for printing. I have some pictures posted for an inkjet transfer. Regards, Dennis --- In Homebrew_PCBs@yahoogroups.com, Mr Crazy <crazymr420@...> wrote: > > Does any one know if OHP film, Transperancy and Acetate Films are the same or all are different?
