setting up for smd
setting up for smd
2007-08-20 by niceike5
Hello
I'm a new member, a software developer and tinker-er. My latest
tinkering has taken me into smd and I need to put together a small
rework setup. I want to know what equipment I need. So far it looks
the primary equipment is a stereo boom microscope and a good fine
point hot air solder station.
I'm thinking of picking up a second hand Leica sz4 which seems to be
the old standard. But, I see reasonably priced Amscope units on Ebay
and am wondering if there any good. Does anyone own an Amscope? Any
opinions out there on a low cost scope for smd work?
For a soldering station, I'm thinking of a Weller wad101 or Edsyn
971ha. But I want to get some opinions. Here at work, even though
the guys do most of the rework with regular temp controlled irons.
The consensus seems to be that a good fine point hot air iron is a
must. Any opinions?
Re: [Homebrew_PCBs] setting up for smd
2007-08-20 by DJ Delorie
"niceike5" <mwood@...> writes:
> So far it looks the primary equipment is a stereo boom microscope
> and a good fine point hot air solder station.
I use a 2.5x/3.5x visor, with which I've done down to 01005
capacitors, but I have a toy 200x microscope for verification.
I use a Metcal MX station, with both the 20mil conical tip for regular
work and a Talon for removal.  The talon covers everything up to SSOP
and some DIP (no QFP).  Or, I put the board back on the hotplate and
let it melt all the solder, then just pick off the parts I'm
interested in.
2007-08-20 by Leon
Sent: Monday, August 20, 2007 8:58 PM
Subject: [Homebrew_PCBs] setting up for smd
> Hello
> must. Any opinions?
Metcal makes the best soldering equipment, it isn't too expensive if bought
second-hand. I use an old STSS power unit with an MX-500 handpiece and
cartridges.
Leon
Leon Heller
Amateur radio call-sign G1HSM
Yaesu FT-817ND and FT-857D transceivers
Suzuki SV1000S motorcycle
leon355@...
Re: setting up for smd
2007-08-21 by Andrew
> <SNIP>
Let the holy wars begin :D
Re: [Homebrew_PCBs] Re: setting up for smd
2007-08-21 by Stefan Trethan
On 8/21/07, Andrew <andrewm1973@...> wrote:
> > <SNIP>
My thought exactly ;-)
Everyone will do well to remember these are opinions ;-)
Regardless of brand, who is using a "small" hot air iron shaped like a
regular iron (aka hot air pencil), and how's it like?
http://www.lashen.com/vendors/CooperTools/images/WRS1002.jpg
(disregard brand please)
Also, who's using the larger hot air tool (aoyue, hakko,...) with the
larger handpiece and thicker hose? Any experience with those?
http://www.wildanger-digital.de/eBay/aoyue/852/852a+.jpg
(Again please disregard the brand)
I'd like some opinions on how the types compare in actual use.
thanks!
ST
2007-08-21 by pgdion1
I've been doing rework for years and although hot air is nice, it's
not necessary for small builds and proto-types. I use a temp
controlled Weller iron and I have an older Pace rework (de-soldering)
station that still comes in handy for SMD (sucks pretty much all the
solder off the pads). Some solder wick is also handy to clean things
up. A soldering tweezer tip (Like Talon) is also very useful. Brand of
iron is pure personal preference. We have Met-Cals and Wellers at my
work. Some guys swear by Met-Cal, I prefer Weller (as do some others)
and hence it's what I have at home.A decent heat gun (Ungar, with the
small nozzles) & flux is the only other items in my arsenal. For
inspection I have a good magnifying glass and several Jewelers Loupes
(5x, 10x, 20x). That with good lighting is all I need. A Micro-scope
would be a nice plus though.
For tips on my Weller I like the ETU for most everything small and
EPH101 for fine touch up (fixing one lead, ect). I also use the ETO a
lot and the ETA  for larger items.
Phil (KA0HBG)
> Hello
Shhhh, shhhh, don't say that!
I've been preparing them the last few weeks that we _need_ more SMD
tools, you can't go around saying things like "not necessary" ;-)
I know it can be done with the tools you mentioned (i have pretty much
the same list just other brands), but regularly we need like 5 to 10
prototypes at once and it's more and more SMD parts every time, and
they get smaller too. That can easily be a day or more of soldering.
At least a pneumatic paste dispenser is a must, applying it by hand
with the syringe is hard work if you try doing it for a long time. And
the hot air gun is really not ideal for reflow either.
ST
2007-08-21 by DJ Delorie
"Stefan Trethan" <stefan_trethan@...> writes:
You need to talk them into buying reflow gear :-)
That's the plan ;-)
Has anyone experience with the cheaper reflow ovens like the one from LPKF?
<http://www.lpkf.com/_images/255.jpg>
Note that apparently the small slot in the drawer is a "large glass window".
You understand now why i am afraid of more hyperbole in the brochure?
ST
2007-08-22 by pgdion1
LOL- Sorry about that Stephan.  I agree, anything more than one or 2
by hand is not practical this way. If it gets to that, I have the
luxery of sending boards down to or rework group to be done. Only
problem is a lot of times they come back and I still have to touch
them up by hand - Arrrrrgh!
> ST
2007-08-23 by Stephanie Ann Thompson
At my experience in my workplace, the metcal irons worked great. The
most used were a 3mm or so conical chisel tip, and a smaller version
of it. I found the larger tip helped prevent me from burning the
board because of the greater mass and surface area, made for great
thermal recovery. With the larger tip i could easily solder 402 parts.
We had a Hakko Hot air gun, the main usage was for removal of smt
parts, not insertion. however on occasion i would use it to preheat
large parts with ground planes like power mosfets or the like. I've
also used it to solder SOIC parts, though a bit harder. Pre-tin the
pads, use some flux and hold the part in place while reflowing with
the hot air gun. Often this required touchup later. As for a stereo
microscope, it's a must for delicate work. certian SMT connectors and
sockets you will need a microscope for. I've tried several different
kinds, though the one i liked the most for ease of use was a
stereoscope with a single viewing window. i don't remember the brand
but it used a rotating mirror or something inside it. lol. The other
i've used is the two eyepiece type. it did seem to have better
optics, but keeping the right distance to the eyepiece was
frustrating. in any rate, buy the brightest light halo you can
afford. at high levels of magnification you will appreciate more
light.
Hope this helps.
-Steph
SMD
much
10
and
soldering.
hand
time. And
> > ST
it's
soldering)
all the
things
Brand of
at my
others)
with the
Loupes
scope
2007-08-23 by niceike5
This is some great info thanks. It's really caused me to take a
deeper look at the equipment out there. But, I do have a couple
questions;
DJ: > I put the board back on the hotplate
What do you use for a hot plate?
Phil: >decent heat gun (Ungar
Is this a hand held dryer style unit like 6996?
Does any one have opinion on the Aoyue 968 combo units?
They're very reasonably priced I wonder if there any good.
At any rate, I've been a Weller guy for years. But reading the
technotes on the Metcal smartheat really causes one to think,
especially when it is corroborated like this.
--- In Homebrew_PCBs@yahoogroups.com, "Stephanie Ann Thompson"
The
version
parts.
preheat
I've
with
stereo
and
different
brand
other
> light.
> Hope this helps.
> -Steph
or 2
touch
more
> SMD
necessary" ;-)
pretty
> much
to
> 10
time,
> and
> soldering.
> hand
> time. And
> > > ST
nice,
> it's
> soldering)
> all the
clean
> things
useful.
> Brand of
Wellers
> at my
some
> others)
> with the
For
Jewelers
> Loupes
Micro-
> scope
2007-08-23 by DJ Delorie
Whatever was cheapest at Target.  Currently, an Aroma $20 model.
http://www.delorie.com/pcb/hotplate/
Some shots of it in action at the bottom of this page:
http://geda.seul.org/projects/djs_pcbs/
I'm the one in the green shirt, but ignore the liquid tin results - I
missed a step and it came out all wrong.
My favorite part of the metcal system is that it goes from cold to
ready in about 15 seconds, so you can switch tips all you want without
worrying about the usual "warm up" penalty.
2007-08-23 by Leon
Sent: Thursday, August 23, 2007 4:27 PM
Subject: Re: [Homebrew_PCBs] Re: setting up for smd
I usually find it quite difficult to clear solder from plated holes. I just
tried some new desolder braid using my Metcal on a couple and it cleared
them very easily.
Leon
2007-08-23 by lists
In article <001101c7e59f$d25bf0b0$4101a8c0@AZATHOTH>,
> just tried some new desolder braid using my Metcal on a couple and it
> cleared them very easily.
The best solution I came up with was to apply a /very/ pointed tip to the
hole on the component side (point enters the hole very slightly) and a
vacuum desoldering station bit on the other. Apply the suck, quickly
remove the other iron while sucking and the result is a nice clean hole.
Works every time :-)
