heat press transfer - cheap anti-stick paper alternative: baking paper
2007-07-28 by michael_haberler
here's an idea for laser toner transfer - it's not a "process" (yet) -
maybe somebody gives it a try:
Being a cook, I have "Backpapier" (baking paper) in the kitchen, which
is heat-resistant anti-stick coated paper. It's very thin and robust.
I thought the "anti-stick" feature would work with laser toner as
well, not just cookie doe - and it does. The toner comes off easily
from the paper when ironing it to metal.
I dont have a PCB or pre-etching liquids around here right now, so I
tried to transfer a PCB design with a iron onto a hard disk platter I
had lying around.
The paper comes right off when the metal with the paper is thrown into
water. I havent learned the process of direct transfer yet, as for
heat and duration, but results look promising - some places of the
paper had the toner completely removed and transferred to the platter.
The paper comes on a roll and needs to be cut into sheets. These dont
feed easily into a laser printer directly, but it's very thin - so I
glued a patch of that paper to a normal A4 paper sheet - that is
strong enough to keep the baking paper in shape for the printing
process. Then I put it in the manual feeder - voila.
I'll cut a few sheets and put them in a thick book - let's see if they
come out flat. But the glue trick is good enough.
This is the paper I used - available in every supermarket:
http://www.toppits.de/de/sortiment/back-profis/back-papier/index.html
I'd be interested to hear what other cooks report ;-)
-Michael
Re: heat press transfer - cheap anti-stick paper alternative: baking paper
2007-07-28 by docstein99
Does the wax or whatever coating also get transferred to the metal?
Because if that doesnt get vaporized, then it may act as a resist -
with the toner itself, layored on top of the copper.
2007-07-29 by wayneosdias
> -Michael
Looks interesting, I followed your link and Im unable to decipher
exactly what the product is, is it ordinary wax paper?
Currently I just use laser photo paper, but removing the paper after
transfer is a total pain, your tech sounds very interesting.
wayne
Re: [Homebrew_PCBs] Re: heat press transfer - cheap anti-stick paper alternative: baking paper
2007-07-29 by Leon
Sent: Sunday, July 29, 2007 5:05 PM
Subject: [Homebrew_PCBs] Re: heat press transfer - cheap anti-stick paper
>> -Michael
I think it's coated with Teflon.
Leon
Leon Heller
Amateur radio call-sign G1HSM
Yaesu FT-817ND and FT-857D transceivers
Suzuki SV1000S motorcycle
leon355@...
2007-07-29 by Gus S Calabrese
> On Jul 29, 2007, at 11:03 AM, Leon wrote:
> From: "wayneosdias" <wayneosdias@...>
> paper
> index.html
> >> -Michael
> Leon
> Leon Heller
> leon355@...
would this work ?
http://cgi.ebay.com/Baking-Parchment-Paper-Pan-Liner-25-Dbl-50-Sheets-
NR_W0QQitemZ260142868921QQcmdZViewItem
Gus
2007-08-17 by dagmargoodboat
> > paper
> > index.html
> > >> -Michael
> > Leon
> > Leon Heller
> > leon355@...
> would this work ?
> Gus
That's the stuff--baker's parchment paper.  I had the same thought,
but it doesn't look like our members have had much success.[1]  If you
search the archives for "parchment" you'll get a number of reports.
Cheers,
James Arthur
[1] For example:
http://tech.groups.yahoo.com/group/Homebrew_PCBs/message/10653
  "Get some of the Reynold's parchment paper, it's
   pretty well non-stick itself."
http://tech.groups.yahoo.com/group/Homebrew_PCBs/message/10868
"The wife's silicon baking parchment worked
 wonderfully on the transfer side of things,
 but didn't accept a very dense coating of
 toner to start with, so I abandoned it."
 http://tech.groups.yahoo.com/group/Homebrew_PCBs/message/13899
 http://tech.groups.yahoo.com/group/Homebrew_PCBs/message/15283
