UV developer re-do's....how to??
2007-08-14 by timbomcnuckle
Hullo again all,, I am having a bit of a problem with figuring out
how ,if anyway, one is able to do a touch up when making a transfer
based on the UV developer method-- I realize that it is likely that
there is no help there due to the nature of the process itself, but am
hoping the assumption is wrong?
 I'm not in any trouble here, just curious-- I have way more experience
with doing the plain-jane TT pcbs's but have most of the equip to do
both methods (except for a good light source and the right transparency
materials).
 Also, if there is no method to amend the mistake after making a foul-
up, how easy is it to remove the resulting transfer and just use the
ol' fashion TT method thereafter? what is the best solvent to use for
removal?
 Thanks in advance for the help, jd
Re: [Homebrew_PCBs] UV developer re-do's....how to??
2007-08-14 by Leon
Sent: Tuesday, August 14, 2007 7:06 PM
Subject: [Homebrew_PCBs] UV developer re-do's....how to??
How will you tell if the resist needs touching up?
> materials).
> removal?
Sodium hydroxide solution (stronger than that used for development) will
remove the resist in a few minutes, or you could rub the board with a paper
towel and IPA.
Leon
Re: UV developer re-do's....how to??
2007-08-15 by timbomcnuckle
hhhmmmm,, I dunno if I understand-- you mean how do I know if a
mistake has been made after the developer? it would be obvious I
assume once compared to the artwork. Things like creep, poorly filled
areas, etc.(in most cases could be manually cirrected with additional
re-touch work, but if not then...) A hypothetical problem that I
assume would render the pcb unusable for developing thereafter,,
correct? I mean to suggest that there are no re-dos for a
presensitized PCB unless you have some UV sensitive material to
spread back over the cleaned board? (I personally don't yet).
 What else can I use to get the resist off the PCB after development?
I'm on a harsh budget so cannot go out and buy more chems than what I
curentluy have on hand.
 Thanks in advance, Jd
--- In Homebrew_PCBs@yahoogroups.com, "Leon" <leon355@...> wrote:
> From: "timbomcnuckle" <jaydag71@...>
transfer
that
but am
experience
do
transparency
> > materials).
foul-
for
> > removal?
will
a paper
> towel and IPA.
> Leon
Re: [Homebrew_PCBs] Re: UV developer re-do's....how to??
2007-08-15 by Leon
Sent: Wednesday, August 15, 2007 6:07 PM
Subject: [Homebrew_PCBs] Re: UV developer re-do's....how to??
If your exposure and transparency are OK, and the transparency is in contact
with the board, there shouldn't be any problems. If you do have problems
with your process, they will rather extensive, and you won't be able to do
much about them.
NaOh is cheap.
Leon
Leon Heller
Amateur radio call-sign  G1HSM
Yaesu FT-817ND transceiver
Suzuki SV1000S motorcycle
leon355@...
