TT Paper and release method
2007-05-20 by rdheiliger
I picked up some tips off Thomas Gootee's page and have done some
experimenting. Below are some things I have come up with that make
the process a bit easier.
I purchased the Photo Basic Gloss paper from Staples. It is the best
paper I have used, no pinholes. The problem was getting it back off
the board. Sore thumbs!!!
I found that after laminating the toner onto the board, putting the
board and paper into water at a full boil will totally release the
paper in less than ten minutes, it just floats off. Saves all those
sore thumbs. Just a quick going over with a toothbrush leaves a very
clean board. I tried some of the toner trasfer paper I used to use
and it came off in less than a minute. Toner Trasfer paper and all
other papers I have tried leave pinholes in the toner.
One problem with the Photo Basic paper is that it takes a lot of heat
and time to get it onto the board cleanly. I have some of the
Hammermill Office Glossy on order. It is 34# paper, the Photo Basic
is 52# paper. The thinner paper should take less heat and time. It
should also work better with the laminator I am now using.
I bought one of those document laminators. The one I bought was -
QuickFinish PL100 (about $50), made by Banner American. I purchased
this one because you can set the temperature, and it was not too
expensive. I did a minor modification to get the temperature a bit
higher. Open the case, 5 screws in the bottom. Remove the two small
screws holding the temperature control to the lid, pull off the dial,
lower the board. On the board in addition to the main pot is a small
trimmer pot, adjust it fully counter clockwise. This increased the
total resistance seen by the controller, and thus increases the
temperature on the laminating roller. I would have liked to have gone
even higher, but this seems to work ok. Tape the artwork onto the
board and make a couple of initial passes thru the laminator. Remove
the tape. Make four or so more passes until the pattern can be seen
thru the paper. Moving from end to end on each pass helps keep the
heated roller up to temperature. I am hopeing that the thinner
Hammermill paper will transfer faster. The copper on the board sucks
the heat up on the first couple of passes. After that the board is
pretty warm. Then just drop it into the boiling water until the paper
falls off. Will repost results with the Hammermill paper.
As an alternative to the PL100 or a cloths iron, I use one of those
toner transfer tools, a 25W soldering iron with a copper disk on the
end. This gives me a better transfer than the cloths iron. I am never
able to get the edges laminated with a cloths iron. Not sure if it is
the smaller area of the head that allows more pressure or if it is
just a bit hotter. Worth the investment of $25.
Link to toner transfer supplier -
http://www.treelineusa.com/cgi-bin/shopper?preadd=action&key=196-7310
RDHeiliger
Re: TT Paper and release method
2007-05-22 by rdheiliger
--- In Homebrew_PCBs@yahoogroups.com, "rdheiliger" <rdheiliger@...>
best
very
heat
dial,
small
gone
Remove
sucks
paper
never
is
7310
> RDHeiliger
This is an update on my previous post.
I have done a comparison between the Staples Photo Basic and
Hammermill Office Glossy.
Used the following process:
Minolta 1250 laser, this is a $100 copier, it is 5 years old
   I am using a generic toner refill
   Set at 1200 DPI, both brighness and contrast set to 100%
Use a Quick Finish PL100 laminator with the above modification
    both boards with equal number of passes, 6
Use the above boil the paper off procedure as above
  The Photo Basic paper floated off after about 13 minutes
  The Hammermill did not float off, but was so soft it rinsed off
under the tap.
  Both boards came out very clean with almost to adhearing paper.
Neither board had pinholes in the toner.
After etching the Hammermill board showed signs of the toner begining
to fall off at the edges of the traces, a longer etch would have
reduced the trace size. The Photo Basic did not show any deteriation.
The Photo Basic had 3 small places where the toner did not adhere,
belive this is because the laminator is not hot enough to penetrate
the heavier paper sufficiently or I had some dirt under the paper.
I would recomend either paper. The Hammermill is likely the best
price/performance choice. With a bit hotter laminator the photo basic
will produce the best board. The thinner Hammermill works better in
the laminator I have and so will likely be the one I use the most.
I have posted 3 photo's of the boards, after laminating, after
etching and after cleaning. Sorry, but the resolution of my old
camera is just not good enough to show how good the boards realy
look. Also the photo basic left the traces so shiny that the
reflections messed with the camera too.
Richard
2007-05-23 by James Newton
Preheat the board before laminating. They cool down very quickly so
right out of preheat into the laminator with the pattern.
Re: [Homebrew_PCBs] Re: TT Paper and release method
2007-05-24 by Derryck Croker
I first pass the TT paper through the laminator a couple of times to
"tack" it into position, then heat with an iron (just rest the iron
on top of a kitchen paper/TT/copper laminate/newspaper sandwich) with
the iron set at hot for about a minute. Then back to the laminator to
finish the fusing.
Cheers
Derryck
2007-05-24 by pgdion1
Thanks for the update, that's cool to know.  I've been having really
good results with the Hammermill paper and the price is great (I don't
even have to cuss when I botch a sheet at this price ;-) ).  It
doesn't float off like the old Office Max paper i had but it wipes off
so easily I don't care. I haven't had a bad board yet (and I use just
a plain old iron). My boards are usually SMD, double sided, and
smaller than 4x6 inches (usually more like 2x4). Even the 32 pin LQFP
IC's are working out good.
I'm going to add another pack to my next Sam's order in case they stop
making this.
BTW - when I was shopping for this (looking for a similar paper to
replace the Office Max stuff) there was also a paper from HP that
looked good (looked like maybe the same stuff rebranded and marked up
a little). Someone else tried it and said it worked well. Might be
easier to get for some people.  The paper is  HP Glossy Laser 32lb (HP
Q2546A) 300ct for about $15.
Phil
KA0HBG
> Richard
