Circuit Cellar article
2007-04-25 by Victor Fraenckel
2007-04-26 by crankorgan
>*____________________________________________________________________________________________*
> Here is an interesting article in the May issue of Circuit Cellar
> magazine. This is the article's banner:
> "Circuit Board Plotting 101. Curt describes how to draw PCB traces onto
> copper-clad with a
> Hewlett-Packard 7440A ColorPro pen plotter and a Sharpie Ultra Fine
> Point permanent
> marker."
> Author did some nifty stuff. See the pics
> Vic
> *Victor Fraenckel
> KC2GUI
> victorf ATSIGN windreader DOT com**
--- In Homebrew_PCBs@yahoogroups.com, "crankorgan" <john@...> wrote:
> Just another ripped from the Internet article. Magazines run six
> months to a year behind.
> One of the original guys.
> http://www.qsl.net/ve2emm/pcb/pcbe.html
> --- In Homebrew_PCBs@yahoogroups.com, Victor Fraenckel <victorf@>
onto
> > copper-clad with a
> > Point permanent
> > marker."
> > Vic
> > *Victor Fraenckel
> > KC2GUI
2007-04-27 by martin_schoenegg
> http://www.willcoxonline.com/PCBplotting/main.htmlOh guys. I did this 15 years before :-)
2007-04-28 by Stefan Trethan
>Tried the same, same results, same box of useless but expensive steel and
> But the process isn't stable. Very often the tip smears as it reaches
> earlier drawn traces or pads (T-connections) or thicker traces that
> needs to be drawn with parallel lines. After tryinig a lot different
> pens (Staedler I used too) and several costy steel-tips with lots of
> different inks I switched back to photoprocess. May be my plotter is
> too fast.
> By the way: The best "ink" I used was colophonium in isopropylNow you are starting to scare me. I also tried colophony resin, also with
> alcohol. It is a good and cheal resist and you don't have to remove
> it, just solder. And if you draw the lines with a tinned solder iron
> the board is quickly tinned and stable for years. there is only one
> small disadvantage with colophonium alcohol ink: it is very
> transparent. Therefor i mix one or two drops of staedler refill ink.
> You may try this... Nowadays I prefer toner transfer.
2007-04-29 by martin_schoenegg
> Now you are starting to scare me. I also tried colophony resin,also with
> some staedtler refill ink.I'd have done it if You'd have asked me before ;-)
> You could've told me, you know, saved me the trouble and all... ;-)
> The laser will most likely not work because only about 50% of toneris
> transferred without the static pickup, i doubt the R producesenough toner
> so that 50% still resists.AFAIR there where here a few members that did some tests to print
> One thing that could work is a silicone roller below the drum as afuse the
> transfer roller, which picks up the toner (with static charge) and
> transfers it to a board running by below (which can be heated and
> toner in the same step because the roller can be heat-proofsilicone. Not
> my idea either that one.
> ST
2007-05-05 by Steve
onto
> > copper-clad with a
> > Point permanent
> > marker."
2007-05-06 by Trevor Matthews
> Longer behind than that! I started Homebrew_PCBs in late 2001, and the[Non-text portions of this message have been removed]
> plotter pen thing was already old then. But to be fair, an article
> like that can find someone who wouldn't even know to search for it on
> the internet.
> I think it was discussions about plotter pens drawing etch resist that
> spurred the scratch 'n etch idea. Wasn't that your idea, John?
> BTW, links:
> <http://tech.groups.yahoo.com/group/Homebrew_PCBs/links/Plotter_method_001007656445/
> <http://tech.groups.yahoo.com/group/Homebrew_PCBs/links/Plotter_method_001007656445/>>
> Steve Greenfield
> <http://www.qsl.net/ve2emm/pcb/pcbe.html>
> <mailto:Homebrew_PCBs%40yahoogroups.com>, Victor Fraenckel <victorf@>
> onto
> > > copper-clad with a
> > > Point permanent
> > > marker."
2007-05-06 by Lez
2007-05-07 by lcdpublishing
2007-05-09 by Trevor Matthews
> I will be (within a few weeks) testing out plotting / etching with[Non-text portions of this message have been removed]
> Staedtler pens. I made up a pen holder for my CNC machine and am
> working out a few other details for direct import of the Gerber data.
> Once complete, I will be trying this process out first hand.
> The Super Fine pens seem to plot about a .015" wide trace which
> severly restricts layouts (relative to what I have been doing so far).
> I went for the Staedtler pens based on SO MANY recomendations here
> from SO MANY people as to how well it holds up to etching. Aside from
> putting the ink on the copper, has anyone had to do any other special
> treatments (heating, drying, etc.) before performing the etching
> process?
> Thanks
> Chris
2007-05-09 by Lez
>The best hold up to etch I have found is the uniball paint pen, I have
> > process?
2007-05-10 by Leon
Sent: Thursday, May 10, 2007 10:44 AM
Subject: RE: [Homebrew_PCBs] Re: Circuit Cellar article
> Has anyone found the staedler (or other store-bought pens) able to
> withstand
> the muriatic acid and hydrogen peroxide etchant solution? I tried both the
> sharpie "paint pens" with fair results, and sharpie permanents. Both seem
> to
> immediately dissolve in the solution.
They work OK with ferric chloride.
Leon
2007-05-10 by K Wolf
> > process?
2007-05-10 by Lez
2007-05-10 by Stefan Trethan
>They work OK with hydrochloric acid and hydrogen peroxide etchant / CuCl.
>> withstand
>> the
>> seem
>> to
> Leon
2007-05-10 by Bob_xyz
>For muriatic acid: I don't know where you're located but you might
> I think the uniball px203 is resistant to everything.
> But I have not tried muriatric stuff, cant get it where I am, but
>as it
> withstands ferric overnight, I think it has a chance.
2007-05-11 by Dale Chatham
>> as it
> want to check at a swimming pool supply or home supply store for
> muriatic acid. It's frequently used for pool maintenance and concrete
> cleaning. It's usually available in a 30% or so concentration in
> gallon containers.
> For hydrogen peroxide: A professional beauty supply store should
> carry the 12% variety which is labeled 'Volume 40'. That's about the
> strongest that I've found.
> You may need to find someone with a beautician's license (or convince
> them that you're not going to bleach anyone's hair). The license
> requirement can vary from one store to another.
> Regards, Bob
