> You might do a search on my user name, as I have made several posts on
> the Brother HL-2040 problems over the past year and a half. It simply
> would not work well with Press n Peel Blue. Teknics tech department
> said the new printers use higher temp toners. The lable on the inside
> of the printer discharge chute has a caution regarding the 431 F parts
> inside.
> What I've finally settled on is catalog paper, specifically non-glossy
> pages from the mailed version of the Harbor Freight catalog. It's
> thin, so I tape it to a sheet of printer paper. I have some board
> examples, beginning with the first try, in the Ted-KX4OM folder in the
> Photos section.
> I preheat the iron to 330 degrees and then iron for 2 minutes using
> moderate pressure, with the temperature still increasing. I use a
> paper towel between the iron and the paper/PCB; it evens out the heat
> and it minimizes the problems with steam holes in the iron.
> The digital thermometer is one for cooking meat. I has a sharp-tipped
> probe on the end of a cable, and a digital readout in C or F. It cost
> $15 from Harry's Market here in Atlanta, a large fresh foods/gourmet
> place.
> Thanks go out to Buddy for the tip on the Office Depot toner.
> Cheers,
> Ted
> --- In Homebrew_PCBs@ yahoogroups. com
> <mailto:Homebrew_PCBs%40yahoogroups.com>, "izzo47" <izzo47@...> wrote:
> > THANKS! I have a Brother HL-2040. I made 5 boards ok, then a run of bad
> > traces...... Still trying to find the right paper.
> <mailto:Homebrew_PCBs%40yahoogroups.com>, "Buddy Brown" <buddybrown@ >
> > wrote:
> > > Hi all,
> > > I also have a Brother printer. It can be made to work,
> > > But, it takes a little more pressure and a lot more
> > > Ironing time, about 8 to 9 minutes. Also, the generic
> > > Toner refills from Office Depot for the Brother printers
> > > Works for TT much better with very much shorter
> > > Ironing times.
> > > I have also converted to an HP printer, but just wanted
> > > To let those of you that still need to use the Brother
> > > Printers, that they can be made to work.
