Etching with HCl and H202
2007-03-25 by Jamie Lyon
Hi all,
I'm currently etching with Ammonium Persulfate, but having to heat it
up isn't very easy, so I want to give etching with hydrochloric acid +
hydrogen peroxide a go.
I've managed to get hold of the acid in the form of brick cleaner, it
doesn't specify the percentage, but I'm assuming it's somewhere around
30%, which seems to be standard.
The hydrogen peroxide however I had quite an issue getting hold of
(I'm in the UK), I've managed to get some medical grade (3%) stuff
from a local supermarket, however it mentions other extra contents on
the label, phosphoric acid & phenacetin. I'm not sure what the volume
of those additives are, as it doesn't mention it on the label. Would
they possibly cause an issue? I don't want it blowing up in my face
when I mix it :)
Finally, I've seen several mixes on the net -- with the medical grade
peroxide, does 2:1 peroxide:acid sound about right?
Many thanks,
Jamie
Re: Etching with HCl and H202
2007-03-25 by sam_jfs
--- In Homebrew_PCBs@yahoogroups.com, "Jamie Lyon" <aeonflame@...> wrote:
> Hi all,
> when I mix it :)
> Many thanks,
> Jamie
I use Muriatic acid and H2O2 ( medical grade 3% too ) with good
results. The only problem is, after some days i can´t really etch with
it, i must throw it away and make a new one, i don´t know why, i don´t
understand chemistry ...
I use 3:1 ( 3 of H2O2 and 1 of Muriatic acid ), it´s quite fast, about
5 to 10 minutes at room temperature (+/- 20ºC ).
Sam
Re: [Homebrew_PCBs] Re: Etching with HCl and H202
2007-03-25 by Stefan Trethan
On Sun, 25 Mar 2007 13:30:24 +0200, sam_jfs <Samuel_joao@...>
> results. The only problem is, after some days i can�t really etch with
> it, i must throw it away and make a new one, i don�t know why, i don�t
The reason is that the H2O2 is not stable in the etchant, it dissipates
into the air.
You can rejuvenate the etchant with fresh H2O2, but the problem with the
3% stuff is you would add too much water.
If you can get 25 or 30% H2O2 you can use the same etchant forever.
ST
2007-03-26 by mycroft2152
I use both FeCl3 and Acid/H202 etchant. Each has its good points as
well as its hazards. In either case, protective safety equipment must
be used.
FeCl3 is a "milder" and "safer" etchant to handle. Yes, it does stain
just about everything, but there is usually very little serious
damage. On the other hand, Muriatic acid / H202 is extremely damaging
to just about everything, including skin.
We all tend to become a little too familiar with the process and get
sloppy. I have had my share of stains and burns too. I definitely
prefer the FeCl3 stain.
When I do an acid etch, I wear goggles and rubber gloves. I have the
etchant tank in a second containment tray. I also have a half kilo of
baking soda handy as well as running water. After finishing, I dust
everything with baking soda and keep adding baking soda to any spots
that fizz. Then carefully wash everything down.
The acid etching process does generate heat and bubbles. There can be
a mist of etchant that is almost invisible. You will notice the
effects, if not immediately, but in a very short period of time. Acid
burns cause intense pain and heal very slowly. Fabric distegrates.
Do not underestimate the danger. Having a little "experience with
acds and bases" in high school, does not adequately prepare you for
proper use.
Be safe!
Myc
Industrial Chemist for 30 years
etch with
don´t
dissipates
> into the air.
with the
> ST
2007-03-26 by Stefan Trethan
On Mon, 26 Mar 2007 17:13:25 +0200, mycroft2152 <mycroft2152y@...>
Those are generally symptoms of too much acid or H2O2 or both. It is a bit
tricky, maybe impossible, to avoid bubbles completely when working with
fresh HCl H2O2 etchants, but an excessive amount should be avoided. I have
once timed a board at eleven seconds, so i know what it means to use too
much (it was a tiny board and tiny container), do NOT try this with large
amounts. Anyway, reducing concentrations should reduce bubbling, and stop
the etchant heating too much (which will generate lotsa HCl fumes too). Of
course it'll slow things down and you might even have to replace or
replenish the etchant during the etch if you work with small amounts in a
small container, on a freshly made per board basis.
If you can at all get H2O2 in concentrated form, or if you are prepared to
go through the trouble of regeneration with air oxygen, it really pays to
feed it up to a proper CuCl etchant. I have my etcher (with a lid, but not
at all airtight), right next to the corner where i store round stock and
rods and stuff, some of it steel, and notice no corrosion. The etchant
does not produce any smell or fumes or bubbles, only during etching a
slight smell can be noticed from the air pumped through (agitation). Also,
CuCl only contains HCl in a relatively low concentration, so will not
cause burns (at least if washed off soon). It will only need tending with
additional HCl and H2O2 every few boards (depends on total volume) so the
risk can be reduced and proper gear can be worn at those times.
Having used both, permanent CuCl is much more comfortable, but you need
concentrated H2O2. Maybe electroplating regeneration would be an option
for those who can't get H2O2 easily. Maybe O2 gas in bottles (welding)
would work better than air, possibly using something like a downstream
dissolver, possibly an option if someone already keeps a oxy/acetylene
welder. Maybe it would even be reasonable to generate the oxygen by
electrolysis of water, but then it is probably easier to use
electroplating and feed the generated gas into a dissolver.
ST
2007-03-26 by derekhawkins
>it up isn't very easy
Etching tanks like below (ET-10) do quite well on a small scale using
an aquarium heater and air pump;
http://www.pbase.com/eldata/image/62352752
Compact, cheap and easy to use.
2007-03-26 by YD
> <mycroft2152y@...>
> will notice the
> Fabric distegrates.
> it means to use too
> have to replace or
> during etching a
> those times.
> would be an option
> bottles (welding)
> like a downstream
> easier to use
> dissolver.
> ST
Has anyone ever tried passing the air through one of
those ozonizer tubes found in water ozonizers? I
figure that the O3 might speed up regeneration.
- YD.
Get your own web address.
Have a HUGE year through Yahoo! Small Business.
http://smallbusiness.yahoo.com/domains/?p=BESTDEAL
2007-03-28 by Jamie Lyon
Thanks for your help everyone. I tried it today. Unfortunately it
wasn't very successful  -- it took about 10 minutes to etch, slower
than the ammonium persulfate I usually use. Having to do it outside (I
don't really want to mess with acids of that strength indoors with
only a window for ventilation) meant it was much colder than room
temp... whether that was the reason or not for the slow etch, I'm not
sure.
Either way, I think I may take the advice of the person below and
obtain a small etching tank with a heater, probably safer for the
small volumes I do, and in actuality even heating up the etchant in a
bowl of hot water is probably less inconvenient than having to move
everything outside :)
I much appreciate all the advice, perhaps I'll try it again sometime
when the weather is warmer! :)
2007-04-16 by Dale J. Chatham
I'll guess that if you add more H2O2, it will work again.  With the
impurities from the etching and the natural tendency of H2O2 to go to
H2O and O2, I'd bet that's your problem.
>> Hi all,
>> when I mix it :)
>> Many thanks,
>> Jamie
> results. The only problem is, after some days i can\ufffdt really etch with
> it, i must throw it away and make a new one, i don\ufffdt know why, i don\ufffdt
> I use 3:1 ( 3 of H2O2 and 1 of Muriatic acid ), it\ufffds quite fast, about
> 5 to 10 minutes at room temperature (+/- 20\ufffdC ).
> Sam
One can get somewhat small aquarium water pumps that will do a better
job of moving the etchang, you won't haveto wory about bubbles on the
board keeping places from etching and the unhandy aerosols released by
the bubbling.
2007-04-16 by Bob_xyz
You can find a lot of good information on making and regenerating CuCl
etchant in the 'Links' section of the group.
Regards, Bob
And, though I'd never suggest anyone try it, FeCl3 makes a decent cure
for poison ivy.
Of course, so does a brush and clorox, but I wouldn't suggest that one
either.
> be used.
> proper use.
> Be safe!
> Myc
