Re: Has anyone tried an Ironing Press instead of an iron to transfer las
2007-04-17 by Len Warner
At 08:39 07/04/17, Digest Number 2073 wrote: > Posted by: "chalaco_51" chalaco_51@... chalaco_51 > Date: Mon Apr 16, 2007 6:25 am ((PDT)) > >[snip] purchasing an ironing press a Conair (~$90) or >even a more expensive one like a Simplicity (~$150) which can add up >100lbs of pressure. > >[snip] the size of the boards >I have going are 6x6 inches at a minumum [snip] > >Does anyone have any comments in the pros and cons on using an ironing >press for toner transfer? 100lbs over 36 or more square inches is less than 2.8 lb/sq in. I'm sure most people's ironing technique, or the pressure rollers of a laminator, give a greater pressure. Additionally, in an ironing press some force may be wasted on parts of the bed which are empty.
