Homebrew_PCBs
cheap UV light sources?
2007-02-23 by David McNab
I'm looking to try out photo etching and am considering the options.
Can someone please recommend a UV lighting source which:
- is cheap
- has consistent UV output
- is readily available, or easily made up from items from general
hardware stores
- gives good results with low exposure time (preferably 5-10 mins,
I'm not keen on 30 minutes)
Also, is it hard to get good results using spray-on resist? Should I
just cop the extra cost of pre-coated PCBs?
Cheers
David
Re: [Homebrew_PCBs] cheap UV light sources?
2007-02-23 by John P. Anhalt
I just use an F15T8 bulb in a standard 18" strip light fixture. Wood pieces on both ends make it 4.5" above the surface. I put a bent piece of aluminum (like a cookie sheet) directly over the bulb as a reflector. It actually hangs on the buld. Exposure time is 13 minutes with Injectoral pre-sensitized boards.
John
Sent: Friday, February 23, 2007 5:31 PM
Subject: [Homebrew_PCBs] cheap UV light sources?
- is cheap
hardware stores
Cheers
David
2007-02-24 by Russell Shaw
David McNab wrote:
> Hi,
> - is cheap
> hardware stores
Bunnings sell a helical dark blue (Woods glass) fluro tube that screws
into a normal light socket. Rig up six of them. (I haven't tried these).
Yes. With 4 "small" flouro tubes about 50-100mm from the pcb, PRP takes
about 3-5mins IIRC.
> Should I
To make PRP work well means cleaning the PCB well before coating it.
Precoated PCB is less hassle to prepare, but more expen$ive from retail
shops. I get mine much cheaper from the pcb house i use.
The normal precoated pcb from the board house is 100x more sensitive
to uv light, so exposure time in normal uv light boxes may be ridiculously
short.
2007-02-24 by Dale J. Chatham
Sunlight.
Short wavelength UV doesn't pass through glass very well. The good UV
bulbs are made of quartz, hence they're kinda pricey.
I've done boards in sunlight with some success. The trouble is, the
amount of UV you get from the sun varies widely from day to day and I
think humidity eats it up.
Russell Shaw wrote:
> David McNab wrote:
>> Hi,
>> - is cheap
>> hardware stores
> about 3-5mins IIRC.
> > Should I
> short.
2007-02-24 by Zoran A. Scepanovic
Hello Dale,
Saturday, February 24, 2007, 5:10:28 AM, you wrote:
> Sunlight.
Nonconstant UV-A radiation on hourly basis.
Short UV has nothing to do with photoresist on copperclad. Peak
sensitivity of photoresist is somewhere around 340nm what stands for
'long wave UV' aka UV-A.
For my prototypes I use Philips UV tubes for reprography. they are
marked 'somethinginhere/05N'. Won't harm your eyes, and this
wavelength of UV is passing ordinary window glass. I'm using 6mm
(1/4") piece as it is heavy enough to make enough pressure to my
repro films or vellum.
Best regards,
Zoran A. Scepanovic
zastos@...
When working toward the solution of a problem, it always helps if you know the answer.
Please be advised what was said may be absolutely wrong,
and hereby this disclaimer follows.
I reserve the right to be wrong and admit it in front of the entire world.
Local time: 08:31
2007-02-24 by David McNab
On Sat, 2007-02-24 at 06:32 -0700, Robert Blumer wrote:
> Very Good light source here:
> http://thinktink.com/stack/volumes/voliii/equipment/uvlamp/uvlamp.htm
> I use presensitized pcb, brand name Ever-Muse
> takes 90 - 120 sec for good exposure.
Now that's what we want - an exposure phase in less than the time it
takes to run board+artwork n times through a laminator :)
The idea of a 10-30 minute exposure was putting me off photo in a big
way.
Cheers
David
Re: cheap UV light sources?
2007-02-24 by derekhawkins
>way.
This homebrew light box takes 3.5 minutes per side to expose double
sided 6"X4" Ever-Muse boards and that's with normal daylight
fluorescent bulbs. The single sided Ever-Muse boards are much more
sensitive, it only takes 90 seconds. I have UV tubes for the box but
never got around to using them since the box is much more useful as a
portable light source.
http://www.pbase.com/eldata/image/52321530
2007-02-27 by garydeal
I use a 500 watt halogen "work light" from the hardware store, $10
including an extra bulb stashed in the handle. I also use this chinese
dry-film resist (ebay, $40 for way more than I can use before it dies)
fed through a $25 laminator from walmart, using the procedures noted at
thinktink.com. My contact frame is an old glass-faced photo contact
printer, a couple bucks at a thrift store but generally available cheap
on fleabay.
With the UV-filtering glass and guard assembly flopped out of the way I
get a good exposure in about four minutes at ~18 inches. I also avoid
eyeball exposure, I figure that UV filter is there for a reason.
I generally only do brass, not copper pcb, and I have a darkroom so I can
go from a good dark inkjet print to litho film without too terrible much
trouble. I *have* used an inkjet print as the mask (oil the paper with
vegetable oil, let soak a while, then keep wiping until dry-ish), takes
about twice the exposure and requires testing - produces slightly rough
edges. I'm going to need to make a pcb or two soon, so I expect this
experience will come in handy.
-Gary
> - is cheap
> hardware stores
Re: [Homebrew_PCBs] Re: cheap UV light sources?
2007-03-01 by otc_friend
Can you describe what makes brass pcb different from copper pcb? I'm wondering if I should switch to brass material.
How good is soldering?
regards -
Henry
www.ehydra.dyndns.info
-----Ursprüngliche Nachricht-----
Von: "garydeal" <garydeal@...>
An: <Homebrew_PCBs@yahoogroups.com>
Gesendet: Dienstag, 27. Februar 2007 11:48
Betreff: [Homebrew_PCBs] Re: cheap UV light sources?
| on fleabay.
| -Gary
| > - is cheap
| > hardware stores
| Be sure to visit the group home and check for new Links, Files, and Photos:
| http://groups.yahoo.com/group/Homebrew_PCBs
| If Files or Photos are running short of space, post them here:
| http://groups.yahoo.com/group/Homebrew_PCBs_Archives/
| Yahoo! Groups Links
2007-03-02 by Len Warner
Yes: AFAIK there isn't any!
(You have misinterpreted 'brass' as an adjective instead
of a noun in order to extend its scope to 'pcb'.)
Brass pcb wouldn't work all that well commercially since
the zinc content might mess up the processing baths,
would mess up the solder chemistry, and brass is a
much poorer electrical conductor than copper.
Some contributors here use (photo)chemical etching to
make parts out of metal shim stock; for example stencils,
and chassis frames for model railway rolling stock.
It produces a high-precision result in material which is
too fragile for mechanical machining, without the
expensive machinery of EDM or ECM.
Regards, LenW
2007-03-02 by otc_friend
Personally I found soldering brass metal not very difficult. I mean here low-temperature soldering, not plunging.
So it may make sense to ask for use it as a pcb material. Especially if the board should be thick and stable.
I think "German silver" would be another material especially for model builders.
Thank you for your explanation!
regards -
Henry
Von: "Len Warner" <novost@...>
Gesendet: Freitag, 2. März 2007 13:52
| Regards, LenW
2007-03-02 by garydeal
I'm sorry, I meant that I etch brass sheet, not pcb's (mostly,
anyway). The brass sheet is for parts for miniaturists and the whole
etching thing was more of an exercise in learning another process for
making prototypes for my job (making things for miniaturists). I joined
here more for the etching info, but I've learned plenty about doing
pcb's.
I need to make a small pcb soon, I expect the 1 oz or so copper will
be easier to etch than the .010" brass I did last.
-Gary
2007-03-06 by Sebastien Bailard
There is no such thing as a brass pcb.
People etch thin sheets of brass for making models. For example:
http://www.etched-brass.scale-train.com/EBNFARMWINDMILL_windmill-3.php
-Sebastien Bailard
RepRap.org - self-reproducing 3D printer project
> wondering if I should switch to brass material. How good is soldering?
> regards -
> Henry
> | on fleabay.
> | -Gary
> | > - is cheap
> | > hardware stores
> | Photos: http://groups.yahoo.com/group/Homebrew_PCBs
> | Yahoo! Groups Links
2007-03-07 by otc_friend
You can make your own brass pcb. I see no problem as such.
- Henry
Von: "Sebastien Bailard" <penguin@...>
Gesendet: Dienstag, 6. März 2007 03:14
Betreff: Re: [Homebrew_PCBs] Re: cheap UV light sources?
-Sebastien Bailard
> regards -
> Henry
