Easiest inkjet
2006-11-02 by Jim Lewis
I'm new here but has anyone summarized the easiest way to setup for direct inkjet - the best printer to use, detailed steps, etc. I hope Sahin's blog, which gets into firmware etc, is not the easiest.
2006-11-02 by Lez
> > I'm new here but has anyone summarized the easiest way to setup for > direct inkjet - the best printer to use, detailed steps, etc. I hope > Sahin's blog, which gets into firmware etc, is not the easiest. I think an epson stylus photo 900 which takes a full size a4 cd tray would be a winner if the carts were filled with good ink. Lez
2006-11-03 by James Newton
--- In Homebrew_PCBs@yahoogroups.com, "Jim Lewis" <jim.lewis@...> wrote: > > I'm new here but has anyone summarized the easiest way to setup for > direct inkjet - the best printer to use, detailed steps, etc. I hope > Sahin's blog, which gets into firmware etc, is not the easiest. > http://techref.massmind.org/techref/pcb/etch/directinkjetresist.htm The C84 is probably the easist. If you use the super thin stock, you can skip most of the physical modifications to the printer. If you do it, please consider documenting the experience and results (even if it doesn't work out) so others can learn. --- James
2006-11-03 by Stephen Lane
Stephen Lane wrote:
I'm new to the Forum, I have been making PCBs via the UV exposure
method for years, I also make a Theatrical effect called a Gobo from
etched Brass using the same techniques as PCB manufacture, having
become increasingly disappointed with the easy to find Electrolube
Positive Resist always being out of date on the shelf & the price that
was steadily escalating I looked for some new ideas & I found them on
this forum so using the info accumulated on the site I come up with the
following instantly successful way of creating an etchable object (I use
the same process for Brass or copper it dosen't matter which except the
PCB material has to be fed thru a modified printer (details for this are
avail on this forum & its a project for me in the next few weeks to mod
my printer to accept boards horizontally))
So to summerise
Hardware is plain clone computer with P4 3Ghz & 2Gig RAM & an
Epson C87 with original Durabrite Inks in it & a GMC Heat Gun (Hot Air
Paint Stripper), Software is Protel 99SE & Paint Shop Pro when needed,
touch ups are performed with Staedtler 318 markers or Texta Parcelmate
Markers & I etch in Ferric Chloride.
1. Prepare the Artwork as clearly as possible with what ever package
allows you to print a Raster picture of the finished layer you are
going to etch be careful of the mirror image issues as you are
usually looking down on the component side of the board & you need
to print the mirror image of the bottom layer for instance. One
thing that might help here & I use this for the later steps is
export the layout as a picture(.bmp, .jpg or .tif for instance) if
you can this helps later but do a check print for dimensional
accuracy.
2. When the you are happy with the Artwork bring it into the Paint
Program & change the track color to 100% Yellow 40% Magenta (this
creates a deep brown color (& yellow & magenta polymerise best &
remain the most resistant in the following steps. The Brown color
could be achieved via the printer driver to I think but I haven't
tried it yet).
3. Prepare your board material THIS IS CRITICAL to the success of any
of the procedures for Homebrew PCBs & cannot be stressed enough.
The board must be free of all oxides & contaminants particularly
oily greasy ones & should ideally be roughened to provide a key
for the resist(ink or otherwise) to sit on & slightly penetrate
the surface of the board. I use AJAX powder cleanser & a green
potscrubber (which has never been in contact with a greasy pan in
its life (In fact I buy a cheap pack of 6 & cut one into quarters
& throw away after a couple of boards if nesc. You scrub the
surface of the copper in at least 3 directions edge to edge with
some of the powder cleanser & wash off, when its clean water won't
bead on the surface it flows evenly (turn it over or try an
uncleaned bit & compare you will see what I mean) dry the board as
quick & as gently as possible (I use a convection microwave on
convection only set to 130 degrees C for 10mins) when no water on
surface is observed remove from the oven & let cool off. As soon
as cool wipe surface off with Acetone (note the last of the Black
Deposit that comes off the Copper onto the tissue). This stuff has
to happen inside a 15 to 30 min window of time because the copper
will start to oxydise immediately & this will stuff up the
etching later (In fact if you arn't going to etch as soon as
you've printed don't start until you can finish the whole
process), clean the 2nd side if nesc. before drying & cleaning
with Acetone
4. With your freshly modified printer that allows you to feed the
board thru horizontally do a test print to work out where the to
stick the piece of Board then align your board to your carrier
using this test print. Stick or mount your board using a heat
proof tape to the carrier. Then print the picture/tracks on the
copper side of the board
5. Dry the Ink on the board by subjecting it to heat hot enough to
polymerise the resin in the ink My Heat Gun says that its a 300C
to 350C the critical thing is to watch the surface of the ink at
an Angle so you can see it go dull & solid try & keep away from
the tape because you may want to reprint the design & registration
is critical. Instead of reprinting if any defects in the big bits
bother you, you can dot them out with a black texta (I use
Parcelmates but Stedtler 318 Perm Marker works very well) the
tracks tend to not have issues but the big open earth plains can
cause the pooling that people talk about & feeding the board thru
twice when wet makes a ral mess of your nice clean printer & drags
the good bits of the 1st layer off the right places (Very messy &
you have to clean the board all over again). Repeat for the 2nd
side of the board if nesc or coat the 2nd side of the board with a
varnish or thick black texta..
6. Etch the board, I have found the side to side rocking has the best
effect. I also activate the Ferric Chloride by microwaving for 5
to 10 sec (any longer will melt plastic or cause the Ferric
Chloride to be too active & strip the resist as well as the
copper) before I start (for a 100mm by 100mm size board this is
sufficient for the whole etch run). Once the thin tracks have been
etched use the black texta to protect them from undercutting &
keep etching until finished (remove wash in fresh water & spot dry
with soft tissue before touching up with texta and continuing)
7. You should have a usable board at this point which still needs
drilling & a conformal coating or tinning to stop corrosion.
Long Post sorry
However thanks for all the people that documented what they have
achieved in the Forum. I used the above method which is a consolidation
of all the documentation & my own tried & true cleaning techniques to
achieve instant success the 1st time I tried to etch an object.
So I hope this helps
Regards
Stephen Lane
[Non-text portions of this message have been removed]2006-11-03 by Stefan Trethan
Stephen, great work! I'm glad to hear people are working on inkjet printing since my C84 is just sitting around here looking dumb those last few weeks. I even had to get back the fuser from the attic when i had to make a few PCBs, like NOW, and the inkjet wouldn't work, imagine that. I had put it up there confident i won't need it no more. Anyway, i expect people will be especially glad to hear original durabright ink works! No nobody should have excuses not to use this method ;-) I'm somewhat surprised you have rather non-critical curing circumstances, maybe the durabright is even better suited for PCBs than the mispro ink. (Of course that would not be great since it likely costs a lot more.) Thanks for sharing your experience, and please do stick around since there's bound to be questions. ST
2006-11-04 by Stephen Lane
Stephen Lane again:
No problems any questions I'll do my best to answer them.
The heat gun I use is a real hot one & I'm not sure of the actual
temp on the board I'm going to borrow a thermocouple from work & try &
measure it. The measure of "done" I used was based on what the toner
transfer method described when you do the second melt of the toner onto
the transfer paper (where it goes nice & shiny and any pin holes are
supposed to fill themselves in) here it goes a nice dry flat mat & emits
a bit of "steam" which I'm careful not to breath in.
re the Durabrite inks I have not found a supplier for Mispro in
Australia so if anyone can point one out I will be most grateful I have
found a supplier that says the OEM ink they supply is a pigment one but
it will cost as much to buy a set of new carts as to buy a bulk supply
on spec & then discover it won't work. As pointed out in the Forum the
Black Ink is a waste of time & so is the Durabrite Black, I put some
test stuff around the actual thing I wanted the first time & the brown
combo was the only thing that came thru unscathed which I was suitably
impressed with & grateful for the Forum for pointing out the possibilities.
Thru out all my experience in making PCBs in the kitchen (even small
runs at work when we had a design arm) I can not reiterate hard enough
how important a clean, grease free copper surface with some fine
scratches in it helps the whole process. Followed by the time between
cleaning to etching must be kept as quick as is safely possible to
minimize the effect of the oxidation that starts instantly the board
stops being cleaned (you only need to look at the black deposit on the
"lint free" tissue that you use to wipe it after drying with Acetone to
realize.that something is starting to happen even while your drying the
board).
Another thing to think about when laying out the Artwork is to not
have large expanses of Copper to etch away if you can help it, not only
does this load up your etchant it is usually the last bit to go & while
you were waiting the small tracks between the IC pads just got seriously
under cut reducing their current carrying capacity or plain disappeared
(hence my hint re the remove, wash, dry & touch up in the original
post). If I have big expanses of board that arn't needed I tend to pour
a fill into them or do a X hash with tracks, make an extra ground plain,
anything to make the amount to be etched to be the same average over all.
Anyway I'm probably beating on somebody else's drum as I have'nt had
time to peruse all the Archives & everything in the last couple of years
but these last points are the things that really help me.
Regards
Stephen Lane2006-11-06 by Bora Dikmen
Hi all, I searched the current printers in Turkey. According to my search, only Epson inkjets are suitable for direct PCB printing because of its suitable mechanics. Other issue is the water resistant ink refill opportunity of the Epson printers. I have no idea but according to my Internet search, only Epson's cartridges are water resistant refillable. Epson C84 is an expensive and almost obsolete product. Or at least I it is not easy to find. One new and cheap option is Epson C48. As I examined its mechanical structure seems to be suitable for this job. Had anyone test it? What is your opinion? Best regards, Bora --- Stefan Trethan <stefan_trethan@...> wrote: > Stephen, > > great work! I'm glad to hear people are working on > inkjet printing since > my C84 is just sitting around here looking dumb > those last few weeks. I > even had to get back the fuser from the attic when i > had to make a few > PCBs, like NOW, and the inkjet wouldn't work, > imagine that. I had put it > up there confident i won't need it no more. > > Anyway, i expect people will be especially glad to > hear original > durabright ink works! > No nobody should have excuses not to use this method > ;-) > > I'm somewhat surprised you have rather non-critical > curing circumstances, > maybe the durabright is even better suited for PCBs > than the mispro ink. > (Of course that would not be great since it likely > costs a lot more.) > > Thanks for sharing your experience, and please do > stick around since > there's bound to be questions. > > > ST > > > Be sure to visit the group home and check for new > Links, Files, and Photos: > http://groups.yahoo.com/group/Homebrew_PCBs > > If Files or Photos are running short of space, post > them here: > http://groups.yahoo.com/group/Homebrew_PCBs_Archives/ > > Yahoo! Groups Links > > > mailto:Homebrew_PCBs-fullfeatured@yahoogroups.com > > > > ____________________________________________________________________________________ Want to start your own business? Learn how on Yahoo! Small Business. http://smallbusiness.yahoo.com/r-index
2006-11-06 by Stefan Trethan
On Mon, 06 Nov 2006 19:21:25 +0100, Bora Dikmen <bora_dikmen@...> wrote: > > One new and cheap option is Epson C48. > As I examined its mechanical structure seems to > be suitable for this job. > Had anyone test it? > What is your opinion? it may not have enough nozzles. ST
2006-11-07 by Steve
--- In Homebrew_PCBs@yahoogroups.com, "Stefan Trethan" <stefan_trethan@...> wrote: > > On Mon, 06 Nov 2006 19:21:25 +0100, Bora Dikmen <bora_dikmen@...> > wrote: > > > > > One new and cheap option is Epson C48. > > As I examined its mechanical structure seems to > > be suitable for this job. > > Had anyone test it? > > What is your opinion? > > > it may not have enough nozzles. Bora, can you get the Epson C88? It's the latest in the progression from C80, C82, C84, C86. Don't know about it's mechanical suitability. Steve Greenfield
2006-11-07 by William Nelson
I have a C88 which I'm working on now and it does not appear to be much different than the C84. I had all the mechanicals done and was test printing on paper taped to a pc board and all was well, UNTIL! I put the controller cable into the power supply connector. Psssssst no more worky. Both connectors are the same just a different color and I was not paying attention. I tried to get a replacement board but it's $60 and a complete rebuilt printer one from Epson is only $60 with all new inks, so I will be getting one of those and try again. HINT if work to poor to pay attention don't do the work.
2006-11-07 by Bora Dikmen
I can not find C88 in Turkey. But there is a lot of link for D88. C88 and D88 seem very similar? Technology 4-colour inkjet printer, Epson Micro Piezo\ufffd print head Epson Variable-sized Droplet Technology for minimum 3pl droplet size Print head of 180 nozzles for Black, 59 nozzles per Cyan, Magenta, Yellow Print Quality Up to 5760 x 1440 optimised dpi on suitable media using RPM (Resolution Performance Management) --- Steve <alienrelics@...> wrote: > --- In Homebrew_PCBs@yahoogroups.com, "Stefan > Trethan" > <stefan_trethan@...> wrote: > > > > On Mon, 06 Nov 2006 19:21:25 +0100, Bora Dikmen > <bora_dikmen@...> > > wrote: > > > > > > > > One new and cheap option is Epson C48. > > > As I examined its mechanical structure seems to > > > be suitable for this job. > > > Had anyone test it? > > > What is your opinion? > > > > > > it may not have enough nozzles. > > Bora, can you get the Epson C88? It's the latest in > the progression > from C80, C82, C84, C86. Don't know about it's > mechanical suitability. > > Steve Greenfield > > > ____________________________________________________________________________________ Sponsored Link Mortgage rates near 39yr lows. $420k for $1,399/mo. Calculate new payment! http://www.LowerMyBills.com/lre
2006-11-07 by Stefan Trethan
On Tue, 07 Nov 2006 20:34:17 +0100, Bora Dikmen <bora_dikmen@...> wrote: > > Print head of 180 nozzles for Black, 59 nozzles per > Cyan, Magenta, Yellow That should definitely be enough nozzles, if that is even important. ST
2006-11-07 by Steven Phellps
Hi All, Could someone give me a few pointers. This I am sure has been discussed but I am not sure where to look for the answer so I thought I'd ask. I tried to build my own PCB with the radio shack kit but the traces are terrible. They aren't smooth, they are jagged. The traces are thick then too thin. I used a sharpie, didn't work well. Used the radio shack black traces that you press on to the copper clad board. Very cumbersome and results weren't good. Double sided was even worse. What is a simple way to make my own double-side PCB ... even a single to start is good. Where do I find a small drill bit? Mine are too thick and the holes are too big that the DIP sockets don't fit properly. Is there freeware to draw a circuit board, print on something to transfer to a copper clad board? Or is there something better than chemical etching with the radio shack stuff? I would like something inexpensive... guess the radio shack stuff is pretty cheap and easy to purchase without waiting days for the mail. I've a inkjet HP, epson printer. An old(very old) HP fax machine. Toner seems to be expensive. I've read some ppl speak of photo etching. How complex is that? I don't need a really professionally done PCB but something better than what I've been using from radio shack(press on traces, sharpie markers etc). Any suggestions are most welcomed Steve _________________________________________________________________ Try Search Survival Kits: Fix up your home and better handle your cash with Live Search! http://imagine-windowslive.com/search/kits/default.aspx?kit=improve&locale=en-US&source=hmtagline
On Tue, 07 Nov 2006 22:16:31 +0100, Steven Phellps <scp2000@...> wrote: > Hi All, > Could someone give me a few pointers. This I am sure has been discussed > but > I am not sure where to look for the answer so I thought I'd ask. > I tried to build my own PCB with the radio shack kit but the traces are > terrible. They aren't smooth, they are jagged. The traces are thick > then > too thin. I used a sharpie, didn't work well. Used the radio shack > black > traces that you press on to the copper clad board. Very cumbersome and > results weren't good. > Double sided was even worse. > What is a simple way to make my own double-side PCB ... even a single to > start is good. Where do I find a small drill bit? Mine are too thick > and > the holes are too big that the DIP sockets don't fit properly. Is there > freeware to draw a circuit board, print on something to transfer to a > copper > clad board? Or is there something better than chemical etching with the > radio shack stuff? > I would like something inexpensive... guess the radio shack stuff is > pretty > cheap and easy to purchase without waiting days for the mail. I've a > inkjet > HP, epson printer. An old(very old) HP fax machine. Toner seems to be > expensive. I've read some ppl speak of photo etching. How complex is > that? > I don't need a really professionally done PCB but something better than > what I've been using from radio shack(press on traces, sharpie markers > etc). > Any suggestions are most welcomed > Steve If you can get a laser printer ($10 on ebay) or use a copier somewhere i'd suggest toner transfer. If not, you'll have to use photo process. But that one is better explained by someone who doesn't think it a PITA. ST
2006-11-07 by Paul Atkinson
Lurk mode off/ I've used the photo-sensitive method (as recently as a week ago) and the RadioShack kit (a few years back). I haven't used the toner-transfer method yet. On the RadioShack stuff - the copper needs to be really clean. Use a scouring pad and then wipe the board down with acetone. Don't assume the board is clean because it was in a plastic bag. (The PVC bags do something to the copper surface.) It's got to be clean _and_ smooth for the dry transfers to stick. A regular Sharpie (permanent marker) pen will resist the etchant as long as you let it dry well before etching. Getting traces with rough edges (assuming the original artwork/pattern is smooth) makes me think of two causes. One, the transfers or ink wasn't put down completely or the board wasn't smooth or clean enough to let it stick. And two, the etching probably was done at room temperature. If you heat the etchant (ferrous chloride at RadioShack) to about 100F it will etch faster, which allows less time for it to sneak under the transfer or resist layer and make rough edges on your traces. (I usually put the etching tray in a larger tray of hot tap water to keep the etchant warm. Some put it in the microwave for 15 seconds or so - at their own risk.) Personally, I have used MG Chemicals positive sensitized PCB system and it has worked well for small boards (3 inches by 6 inches, single sided). I still plan to try the toner transfer when I get a chance. For double sided DIY boards, some align the artwork top and bottom with tape and then apply the pattern (either toner transfer, photo, etc). Some drill the mounting holes first and then use them to align the patterns top and bottom. In either case, you have to be able to make a reliable pattern in the copper first. Good luck! Paul
----- Original Message ----
Sent: Tuesday, November 7, 2006 3:16:31 PM
Subject: Re: [Homebrew_PCBs] easy PCB
Hi All,
radio shack stuff?
I would like something inexpensive. .. guess the radio shack stuff is pretty
Steve
____________ _________ _________ _________ _________ _________ _
Live Search!
http://imagine- windowslive. com/search/ kits/default. aspx?kit= improve&locale= en-US&source= hmtagline
<!--2006-11-08 by cbq
Hello to all at homebrew , this is my first posting in this group. anyone knows whether it is neccessary to have durabrite ink? Epson's newer printers C79 , 90nozzle (Black) and 29 nozzles(C,M,Y) [without durabrite] Epson's C67 , 90nozzle (Black) and 29 nozzles(C,M,Y) [with durabrite] i can't see any difference in these printers. --------------------------------- Everyone is raving about the all-new Yahoo! Mail. [Non-text portions of this message have been removed]
2006-11-08 by JanRwl@AOL.COM
In a message dated 11/7/2006 3:20:44 P.M. Central Standard Time,
scp2000@... writes:
good.<<
A little patience and experience will enable you do to do quite fine PCB's
with the RS stuff! Their pressure-sensitive resist patters work FINE! You
must clean the board of all goop and film and boogers and water, and then rub
the patterns down good, and use the wax-paper like stuff between the sheets of
patterns over the pattern on the copper as a shield, and rub down hard with
a ball-point pen, so there are NO lifted corners, etc.
Drill your holes FIRST so you can do double-sided! You must de-burr and
clean after drilling! Use only carbide PCB drill-bits in a DRILL-PRESS (a good
one!). Those bits ALL have 1/8" shanks. There are places you can buy boxes
of 50 of a size reasonably ("re-grinds"). Look in the "want-ad pages" of
magazines like Radio-Electronics or Popular Electronics or catalogs of Jameco
and JDR Microdevices, etc. NEVER attempt to use a carbide PCB drill-bit in a
Dremel in your hand! It just will NOT work! And busted carbide bits cost
$money very, very fast! If you need to know a "size" when thinking about
ordering a box of fifty, #56 is a good size. (one or two numbers smaller or
larger would be useful). Some vendors offer assortments of sizes, but you WILL
bust the one or two "most needed" diameters the first day, so only buy those
assortments after you become a skilled expert! Jan Rowland
[Non-text portions of this message have been removed]2006-11-08 by Stefan Trethan
On Wed, 08 Nov 2006 01:53:50 +0100, cbq <timconfig@...> wrote: > Hello to all at homebrew , this is my first posting in this group. > anyone knows whether it is neccessary to have durabrite ink? > Epson's newer printers C79 , 90nozzle (Black) and 29 nozzles(C,M,Y) > [without durabrite] > Epson's C67 , 90nozzle (Black) and 29 nozzles(C,M,Y) [with durabrite] > i can't see any difference in these printers. I think MISPRO ink will work in both, but durabright might not. ST
2006-11-08 by Bora Dikmen
Dear List members, At the final, I found EPSON STYLUS C86 in Turkey. Since it has also empty spongeless cartridges from MIS Assc. Inc. I prefer C86 although D88 seems superior. Whar is your opinion? Best Bora, Stylus C86 Specifications: Resolution: 5760 Optimised dpi, 2880 x 1440 dpi Min Droplet Size: 4pl Bundled Ink Cartridges: Black:T0441 (Standard Capacity) Cyan: T0452 (Standard Capacity) Magenta: T0453 (Standard Capacity) Yellow:T0454 (Standard Capacity) Optional Ink Cartridges: Cyan: T0442 (High Capacity) Magenta: T0443 (High Capacity) Yellow: T0444 (High Capacity) Technology: Epson Micro PiezoT Black ink head : 90 nozzles Colour ink head : 177 nozzles (59 per colour: Cyan, Magenta, Yellow) ____________________________________________________________________________________ Do you Yahoo!? Everyone is raving about the all-new Yahoo! Mail. http://new.mail.yahoo.com
2006-11-09 by David Cureton
As Stefan said, the number of nozzles may not be important, it only seems to increase the print speed as the head can do 1 pass with 180 nozzles or 2 offset passes with 90 nozzles. There may be some changes in the registration of the dots of ink fired at the board because of the different mechanical tolerances and so forth however to get such high resolutions as quoted in the printer manual they all do multiple passes anyway. I'm betting the difference is not significant excluding print speed. I guess I will find out when I mod the C67 I have to start with as trial one of inkjet PCB printing and refine the mechanics in the move to the C87 which is also sitting on the study floor. The mechanics of these machines is identical except for the larger number of print nozzles in the C87. Cheers, David Stefan Trethan wrote:
> On Tue, 07 Nov 2006 20:34:17 +0100, Bora Dikmen <bora_dikmen@...> > wrote: > > >> Print head of 180 nozzles for Black, 59 nozzles per >> Cyan, Magenta, Yellow >> > > > That should definitely be enough nozzles, if that is even important. > > ST > > > Be sure to visit the group home and check for new Links, Files, and Photos: > http://groups.yahoo.com/group/Homebrew_PCBs > > If Files or Photos are running short of space, post them here: > http://groups.yahoo.com/group/Homebrew_PCBs_Archives/ > Yahoo! Groups Links > > > > > > > ** ACCEPT: CRM114 PASS osb unique microgroom Matcher ** > CLASSIFY succeeds; success probability: 1.0000 pR: 13.8672 > Best match to file #0 (nonspam.css) prob: 1.0000 pR: 13.8672 > Total features in input file: 2824 > #0 (nonspam.css): features: 115816, hits: 110286, prob: 1.00e-00, pR: 13.87 > #1 (spam.css): features: 227753, hits: 98540, prob: 1.36e-14, pR: -13.87 > >
2006-11-10 by James Newton
--- In Homebrew_PCBs@yahoogroups.com, David Cureton <yahoo@...> wrote: > I guess I will find out when I mod the C67 I have to start with as > trial one of inkjet PCB printing and refine the mechanics in the move to > the C87 which is also sitting on the study floor. > The mechanics of these machines is identical except for the larger > number of print nozzles in the C87. > > Cheers, > David Anyone who is modifying printers for direct inkjet to PCB: Please keep in mind that I would really love to add any documentation (pictures, text, etc...) you might care to collect to the web site. http://techref.massmind.org/techref/pcb/etch/directinkjetresist.htm I know a lot of people have found the documentation for the C84 from Stephen and the CX4200 from Volkan very helpful and so adding documentation for other printers would be of value.
2006-11-11 by Stephen Lane
Stephen Lane wrote:
Some one in the group did the maths on the printer head holes &
pointed out if I remember that if you wanted to do good plots of tracks
between IC Pads you needed to us a printer of around 1440dpi (its
something to do with the number of holes per color) & the lower
resolution printers have fewer holes so less achievable resolution when
printing in on copper using one ink (yellow magenta works best I've
found). Anyway its in the Archives I found it enjoy
Regards
Stephen
