old plotter
old plotter
2006-11-10 by Lez
Few years ago I bought an old calcomp model 83(m83)
I fiddled with it and it did a self test.
well here I am five years or so later and I finally deiced to try it
again, but cant remember what button combination I used to get a self
test out of it.
It says rs232 on th back with dip switches for baud rate etc.
Does anyone have one of thse still, I'm wondering what type of serial
cable to use on it first, and more importantly, what to use as a
driver with XP.
Lez
Re: [Homebrew_PCBs] old plotter
2006-11-11 by Hugh Prescott
ISTR that Calcomp got bought up by Summatech.
Might do a Goggle for the drivers.
Hugh
> test out of it.
> driver with XP.
2006-11-11 by Fake_Name
Calcomp is still around, though they've apparently changed their name to
Calgraph.
I recently acquired a Calcomp techjet, (36" inkjet plotter), and have
been trying to find drivers for it.
The two best resources I've found are:
http://www.printer-drivers.com/companies/186.htm
http://www.calgraphinc.com/Support/cgdrivers.htm
Winline is supposed to support Calcomp stuff too, but I've had no
success with the demo, Your experience may vary.
http://www.winline.com/
Good Luck.
If you get anywhere, let me know. I'm stumped as far as my plotter goes.
> Hugh
> > test out of it.
> > driver with XP.
Re: old plotter
2006-11-11 by Stephen Lane
Stephen Lane wrote:
    Winline supports the following Calcomp plotters by name but it is a
general HPGL & HPGL2 Driver so if the Plotter can emulate either then it
will do the job
[CalComp]
"Artisan Plus 1023" :
"Artisan Plus 1025" :
"Artisan Plus 1026" :
"DesignMate 30xx" :
"DrawingMaster 600 53336" :
"DrawingMaster 800 53436" :
"DrawingMaster Plus 522xx" :
"DrawingMaster Plus 524xx" :
"DrawingMaster Pro 524xx" :
"EcoGrafix I 52436" :
"EcoGrafix II 53436" :
"Pacesetter 20xx" :
"Pacesetter Classic 4036" :
"Solus 4 544xx" :
"TechJET 55xx" :
"TechJET Color 175i 5336" :
"TechJET Color 53xx" :
"TechJET Color GT 53xx" :
"TechJET Designer 54xx" :
"TechJET Designer 720 54xx" :
"TechJET Designer 720c 56xx" :
I hope it helps
Regards
Stephen Lane
2006-11-11 by YD
> Calgraph.
> plotter), and have
> but I've had no
> Good Luck.
> as my plotter goes.
Try http://www.driverguide.com. It's saved my ass and
sanity a number of times. A percursory search didn't
get me very far, but Calcomp's there and I didn't look
very hard.
Free registration is required, but just give it the
addy to your spambox.
- YD.
Cheap talk?
Check out Yahoo! Messenger's low PC-to-Phone call rates.
http://voice.yahoo.com
2006-11-11 by Stefan Trethan
> very hard.
So they finally stopped accepting user "drivers" and pass "all" for
access...
Oh well, what's safersignup for..
ST
Re: [Homebrew_PCBs] Re: old plotter
2006-11-11 by Lez
Can  not connect to it at say 300baud on com1 with hyperterminal and type it
a command to see if I actually have a working cable between the two?
