Super bubbler - got it working now!
2006-07-12 by lcdpublishing
The other day I posted about a baffle I was trying to make.  My goal
was to get good agitation with good dispersion of bubbles.  Someone
said I had too big of holes, which weren't that way when I started.
Anyway, based on that comment I realized you can only get so much
power (Air) out of a tiny fish tank pump. So, like all "real men"
do, I opted for more power! MUCH MORE POWER!
I connected my big shop air compressor to the new baffle I made up.
I turned down the regulator till I could barely feel air comming out
of the air gun.  Then I held the baffle hose to the air gun and like
magic I had good bubbles and lots of them - everywhere.
Knowing that I will forget to turn down the regulator when etching a
board at some point, I will wait until I can hook up another
regulator for attachement to the etching tank.  That way, I should
be able to reduce the risk of having the whole tank of ferric
chloride sprayed about the shop.
It's still very dangerous in my opinion, but rather than buying
another fish tank pump, this is the next cheapest solution.
The point of this post is, poor bubble volume and dispersion may not
be the problem of the baffle (Hose, stones, etc.), but rather not
enough volume of air going into the tank.
I suspect this will even out the etching and etch a heck of a lot
faster than before!
Chris
Re: Super bubbler - got it working now!
2006-07-12 by fenrir_co
--- In Homebrew_PCBs@yahoogroups.com, "lcdpublishing"
> faster than before!
> Chris
My solution to this was to use two of the larger fish tank pumps that
have two air outputs, glue all four pairs of tubing into a brass or
plastic part that had a screw type pipe on one end big enough to fit
all four tubes in (make sure you get the glue /between/ the tubes as
well) and the other end a connector to attach another tube of the same
width. I half expected the combined pressure to simply make the tubes
pop off of the pumps, but it worked, and gave enough pressure for a
good bubble stream, but I always had problems with uneven etching,
even after getting what I thought was even bubbling, so I finally gave
up on it entirely. Better than worrying about making an etchant
fountain, really...
I first started out using an air brush pump but I didn't use it very
long as I didn't want to ruin it.
RE : [Homebrew_PCBs] Super bubbler - got it working now!
2006-07-12 by Robert Hedan
> -----Message d'origine-----
> De : Homebrew_PCBs@yahoogroups.com
> [mailto:Homebrew_PCBs@yahoogroups.com] De la part de lcdpublishing
> Envoyé : juillet 12 2006 17:49
> À : Homebrew_PCBs@yahoogroups.com
> Objet : [Homebrew_PCBs] Super bubbler - got it working now!
... So, like all "real men" do, I opted for more power! MUCH MORE POWER!
> Chris
You've come to the same conclusion I did several months ago, the fishtank
pump just doesn't cut it.  I connected my shop air compressor to a drilled
PVC tube I had running down the bottom of the etching tank.  I kept on
adding rows of holes until I got the desired 'coverage'.  I used a ball
valve with a nice red handle to control the air flow.
Like you, I knew that one accidental tap on that handle and I'd have a
disaster on my hands.  Don't forget, that bubbling action at the surface
creates a very fine ferric chloride mist.  Just 'cause you don't see it
doesn't mean it's not there, and I didn't have adequate ventilation for a
permanent installation.
I sure did get awesome bubbling action going though, like boiling water, but
not as crazy.  One day when I'm going to have a decent shop space, I will
make another etching tank.  But for the time being, all my equipment fits in
a large plastic bin, way up high on the top shelf (with the acid stored on
the bottom shelf of a cabinet out of harms way).
Now add a section of metal pipe after the air compressor, place a heat
source alongside that pipe and you've added temperature control to the
etching.
Robert
Re: RE : [Homebrew_PCBs] Super bubbler - got it working now!
2006-07-13 by derekhawkins
>fishtank pump just doesn't cut it.
Well it certainly cuts it here provided you're only etching one to two
boards at a time and the good part is that the tank, heater and
aquarium pump only cost me $29.00. The size of the tank and the size
of the holes (hence the size of the bubbles) is the key to the design.
http://www.pbase.com/eldata/image/62352753/original
--- In Homebrew_PCBs@yahoogroups.com, Robert Hedan <robert.hedan@...>
2006-07-14 by Royce Pipkins
So what kind of etch times to you get with your super bubbler? We use
a warming plate and an agitator that simply rocks the solution back
and forth. No bubbles. We get times in the 5 to 10 minute range
depending on the cleanness of the soultion.
Regards
Royce
The real problem is not whether machines think but whether men do.
B. F. Skinner
2006-07-14 by lcdpublishing
Hi ROyce.
Don't know yet.  I am still trying to find a regulator that I can use
for this and don't have time for the "Search" yet.  I am hoping this
weekend I will get some time to finish it up.
I did notice though an interesting thing (I am only using water at the
moment).  There does seem to be a bias as to how the water flows and
circulates in the tank.
For example, if there are more bubbles on the left side, the flow of
water is in a circular, clockwise rotation.  This draws the bubbles
from the right bottom and pulls them towards the left side as they
rise up.  What I am not sure of is if the bubbles actually do
the "Scrubbing" or is the "Scubbing" simply a function of the flow of
etchant.
If the bubbles are doing something, I will be getting some uneven
etching. I am going to try and modify the baffle a bit so that the
flow is back to front as opposed to left to right.  I believe this
would even out the etching.
--- In Homebrew_PCBs@yahoogroups.com, "Royce Pipkins"
> Regards
> Royce
> B. F. Skinner
Re: [Homebrew_PCBs] Re: Super bubbler - got it working now!
2006-07-14 by Leon Heller
Sent: Friday, July 14, 2006 11:54 AM
Subject: [Homebrew_PCBs] Re: Super bubbler - got it working now!
That's about how long it takes for me with manual agitation and warm
etchant.
Leon
2006-07-14 by Stefan Trethan
On Fri, 14 Jul 2006 16:05:03 +0200, lcdpublishing
<lcdpublishing@...m> wrote:
> Hi ROyce.
> etchant.
I see the same here.
When i switch the pump on the bubbler will fill from the left, so will
bubble there first, causing a circuiar current to start.
This is sustained unless i stop the pump, wait for the current to slow,
and start the pump again (now with a bubbler already filled with air).
There's still such currents then, but not as extreme.
I guess nothing can be done, it will be impossible to get it totally even.
ST
2006-07-14 by David Cureton
An I guess a lot of that mist can be mitigated by  having something
floating on the surface of the etchant so as the tiny bubbles collect
and form larger bubbles prior to breaking the surface. Most of the mist
is generated by the surface  tention of the liquid breaking at the
bubble pops causing tiny droplets of liquid. Therefore if the bubbles
are collect into larger bubbles before breaking the surface then there
is less 'surface-tention breaking events' thus less mist.
Cheers,
David
>>Envoy\ufffd : juillet 12 2006 17:49
>>\ufffd : Homebrew_PCBs@yahoogroups.com
>>Chris
>etching.
>Robert
>http://groups.yahoo.com/group/Homebrew_PCBs
>If Files or Photos are running short of space, post them here:
>http://groups.yahoo.com/group/Homebrew_PCBs_Archives/
>Yahoo! Groups Links
> ** ACCEPT: CRM114 PASS Markovian Matcher **
>CLASSIFY succeeds; success probability: 1.0000  pR: 50.7660
>Best match to file #0 (nonspam.css) prob: 1.0000  pR: 50.7660
>Total features in input file: 6014
>#0 (nonspam.css): features: 1603168, hits: 166139, prob: 1.00e+00, pR:  50.77
>#1 (spam.css): features: 786960, hits: 116216, prob: 1.71e-51, pR: -50.77
>-=xtra Stuff-=-
>  From sentto-4505361-15161-1152747819-yahoo\ufffdureton.com@... Thu Jul 13 09:43:48 2006
>Return-path: <sentto-4505361-15161-1152747819-yahoo\ufffdureton.com@...>
>Envelope-to: yahoo@...
>Delivery-date: Thu, 13 Jul 2006 09:43:48 +1000
>Received: from n26.bullet.scd.yahoo.com ([66.94.237.55])
>	by whitetail with smtp (Exim 4.62)
>	(envelope-from <sentto-4505361-15161-1152747819-yahoo\ufffdureton.com@...>)
>	id 1G0oMt-0002KF-Qg
>	for yahoo@...; Thu, 13 Jul 2006 09:43:48 +1000
>Comment: DomainKeys? See http://antispam.yahoo.com/domainkeys
>DomainKey-Signature: a=a-sha1; q=dns; c=nofws; s=lima; d=yahoogroups.com;
>	b=/WAysTBjW3lS2iJiT7DV+FKmqlYRyz63Ky/eoMQhLEvXlLWmZRBA320xZ7/ODTa//bJQTvgfUg7F36ZxgVKQikw3cHIgFe/JKHXD9WVOx6THR5diWPv+uD289c8Kse;
>Received: from [66.218.69.5] by n26.bullet.scd.yahoo.com with NNFMP; 12 Jul 2006 23:43:40 -0000
>Received: from [66.218.66.32] by t5.bullet.scd.yahoo.com with NNFMP; 12 Jul 2006 23:43:40 -0000
>X-Yahoo-Newman-Property: groups-email
>X-Yahoo-Newman-Id: 4505361-m15161
>X-Sender: robert.hedan@...
>X-Apparently-To: Homebrew_PCBs@yahoogroups.com
>Received: (qmail 9310 invoked from network); 12 Jul 2006 23:14:29 -0000
>Received: from unknown (66.218.66.217)
>  by m26.grp.scd.yahoo.com with QMQP; 12 Jul 2006 23:14:29 -0000
>Received: from unknown (HELO relais.videotron.ca) (24.201.245.36)
>  by mta2.grp.scd.yahoo.com with SMTP; 12 Jul 2006 23:14:25 -0000
>Received: from p41900 ([70.83.221.118]) by VL-MO-MR002.ip.videotron.ca
> (Sun Java System Messaging Server 6.2-2.05 (built Apr 28 2005))
> with ESMTP id <0J2B00HQ6BZRKWI0@...> for
> Homebrew_PCBs@yahoogroups.com; Wed, 12 Jul 2006 19:02:19 -0400 (EDT)
>In-reply-to: <e93qne+g4qa@...>
>Message-id: <000e01c6a607$37d7cfb0$0200a8c0@p41900>
>X-MIMEOLE: Produced By Microsoft MimeOLE V6.00.2900.2869
>X-Mailer: Microsoft Outlook, Build 10.0.6626
>Importance: Normal
>X-Priority: 3 (Normal)
>X-MSMail-priority: Normal
>>X-eGroups-Msg-Info: 1:0:0:0
> From: Robert Hedan <robert.hedan@...>
>X-Yahoo-Profile: roberthedan
>Sender: Homebrew_PCBs@yahoogroups.com
>MIME-Version: 1.0
>Mailing-List: list Homebrew_PCBs@yahoogroups.com; contact Homebrew_PCBs-owner@yahoogroups.com
>Delivered-To: mailing list Homebrew_PCBs@yahoogroups.com
>List-Id: <Homebrew_PCBs.yahoogroups.com>
>Precedence: bulk
>List-Unsubscribe: <mailto:Homebrew_PCBs-unsubscribe@yahoogroups.com>
>Date: Wed, 12 Jul 2006 19:02:15 -0400
>Subject: RE : [Homebrew_PCBs] Super bubbler - got it working now!
>Reply-To: Homebrew_PCBs@yahoogroups.com
>Content-Type: text/plain; charset=ndows-1252
>Content-Transfer-Encoding: quoted-printable
>>Chris
>the bottom
> -0-0-0-
On Sat, 15 Jul 2006 00:27:38 +0200, David Cureton <yahoo@...>
> Cheers,
> David
You mean like the styrofoam pellets thrown into septic tanks (hole in lid
== outside loo) in africa to stop dangerous insects from breeding?
I'm not sure that would be so practical, but you are right, a lid makes a
whole lot of difference. The mist seems to condense on the surfaces.
ST
2006-07-14 by George Lawrence Storm
For what it is worth, don't forget that most compressors put out a
fair amount of water and some oil with the air, you might want to put
a filter in line as well as your regulator.
Macintosh Applications Development
Edmonds (Seattle), Washington
E-mail: <keencoyote@...>
