6/6 Rules (.006" lines and .006" spacing)
2006-06-24 by derekhawkins
I'm attempting to debunk the following two myths at the same time;
1. A collimated light source is needed for .005" to .01" rules when
photoetching.
2. All vertical bubble etching system cause uneven etching. Board size
is 6"X4" hung vertically as shown.
http://www.pbase.com/eldata/6_6_rules
Re: [Homebrew_PCBs] 6/6 Rules (.006" lines and .006" spacing)
2006-06-24 by Russell Shaw
> photoetching.
I've used a vertical bubble etcher for a few years and have no uneven etching
at all. These myths are in the same category such as "ferric chloride is slow",
"PRP doesn't work", etc.
Re: 6/6 Rules (.006" lines and .006" spacing)
2006-06-25 by fenrir_co
> when
> > photoetching.
> size
> uneven etching
> chloride is slow",
I've used vertical bubble etchers, both homemade, and commercial (but
cheaper models), and both of them caused terribly uneven etching. I
suspect that 1) the strength of the air pump and 2) the size and
placement of the bubbles have a lot to do with this. So if you have a
vertical bubble etcher that works perfectly, post the name and model
number of it. I don't remember where I got the commercial one that I'd
bought, I think it was Electronics Express but I could be wrong. I
threw it away about two years ago. It etched much, much faster where
the bubbles hit the metal, and one edge would etch faster than the
other. So I don't think this is entirely a myth, I think it has to do
with the quality of the bubble etcher you buy.
Re: [Homebrew_PCBs] Re: 6/6 Rules (.006" lines and .006" spacing)
2006-06-25 by John Popelish
If you want the ultimate in etching, you need to collimate that
process. Bubble or spray etching is a far less collimated process than
exposing a mask to an uncollimated source.
If you float the board, copper side down on the surface of ferric
chloride etchant, the etching process proceeds almost straight up.
The loaded etchant is more dense than fresh, so a convection cell
forms that provides fresh etchant to the center of the slot (or hole)
between two edges of resist, and the loaded etchant slides down along
both sides, preventing undercutting, till the copper is etches all the
way through.  I have used this technique to etch holes with a diameter
equal to the copper thickness, and slots narrower than the copper
thickness.  The sides of the remaining copper traces are smooth and
almost perpendicular to the board surface.
The skill that must be mastered to make this work is to be able to
slide the board in, one edge first, so that no bubbles are trapped
under the board.  I usually slide the board in, to get it wet, raise
it up, to see if all the exposed copper has been wet, and slide it
back in.  I usually just use a plate of etchant, selected so that the
board is supported by the 4 corners just into the surface of the
puddle.  After that, resist (as much as possible) the urge to peak or
otherwise agitate the etchant, because that will ramp up undercutting
until the convection cells reform.  This works especially well with
single sided boards, where you can see through the board material when
the etching is about finished.
Spray, bubble or other agitated methods are faster than convection
etching, but, once you compare the precision and accuracy of the
results, you may decide that the extra time (to make and drink a cup
of tea), is well worth it, unless you are on a production schedule.  I
also like the absence of mist that corrodes everything metallic, nearby.
2006-06-25 by Russell Shaw
>>when photoetching.
>>size is 6"X4" hung vertically as shown.
>>uneven etching at all. These myths are in the same category such as "ferric
>>chloride is slow", "PRP doesn't work", etc.
Look at the blue etcher tank on http://www.kalex.net.au
When the bubbles rise between the pcb and the tank side, a vacuum forms,
pulling the pcb against it. Then the reverse happens on the other side of
the pcb. This causes the hanging pcb to pendulum back and forth. The bubble
stream is quite weak, but the etching still happens evenly over the whole pcb.
I use ferric chloride 1:1 with water (use hot water for bonus speed if you're
mixing a new batch), and 1/4 - 1/2 cup of hydrochloric acid every few months.
I've been using the same etchant in the tank for the last year. Double-sided
35um pcb etches in 6mins at room temp with fresh etchant. More typically, it's
8-12mins, then put the pcb into a tray and do a small amount of brushing to etch
the last few stubborn bits.
2006-06-25 by derekhawkins
>process.
Diminshed returns in a homebrew scenario. I have tried "float
etching" with Ferric Chloride (FC) and yes it's possible that it
more faithfully reproduces the original than normal etching. FC in
general seems to do a better job than the Persulphates (PER) in
terms of fidelity but that's just another reason why I prefer them
over FC. Below are extreme (the best my macro lens could do)
closeups of two of the 6/6 images that demonstrate that what you see
may not be what you want to get. The edges from inkjet printers are
far from smooth and I purposely overexpose inkjet artwork and etch
with PER in order to even things out. The etched board may have lost
a fraction of a thou along the way but the edges are much smoother
when compared to the original artwork. Lens to subject distance was
the same in both cases.
Closeup of original artwork;
http://www.pbase.com/eldata/image/62430331
Closeup of same area of etched board;
http://www.pbase.com/eldata/image/62430370
--- In Homebrew_PCBs@yahoogroups.com, John Popelish <jpopelish@...>
>So if you have a vertical bubble etcher that works perfectly, post
>the name and model number of it.
Kinsten ET-10 is what I have and it works well. The one in the shot
has seen active duty for around 5 years and worked so well that I
bought two more around three years ago. Circuit Specialists used to
sell them for $29.00 but now sells the ET-20 for $44.00. While the
latter is bigger it may not work as well for that very reason. Also,
the ET-20 requires a minimum of 2 litres of etchant while the ET-10
only requires a minimum of 1 litre so I'm led to believe it's using
the same heater. The heater is too high in the tank IMO, compare the
two images;
http://www.web-tronics.com/lowcosetsysw.html
http://www.pbase.com/eldata/image/62352753/original
2006-06-25 by Andrew
> .005" to .01" rules when photoetching.
> uneven etching.
> Board size is 6"X4" hung vertically as shown.
Nice etching.
I agree collimation is not needed and bubble
etching works well.  I currently use both an
uncollimated light source and a kinsten
bubble etcher.
My main problem I have with getting to 6/6 is
my phototool.
Printing on my personal laser I can do a 6/6
board FILLED with 6/6 like you have shown but
if I try doing a a board where 1/2 the board
is 6/6 and the other half has large areas of
copper I get problems.  During the develop
I either need to leave it too long for the
large copper areas to be pitted or I take it
out too soon and I get shorts in the 6/6 area.
I just use a little laserjet 4xxx myself.  It
just can't seem to do big black areas well.
The big laserprinter I borrow works well for
large black areas - but it is a half hour ride
to get to use.
How do your boards go with 6/6 AND wide tracks
mixed on a single board ?
I am going to build a think and tinker style
collimated box - but I don't think it is
going to make a noticeable improvement.
2006-06-26 by derekhawkins
Being setup for macro shots I decided to take some possibly useful
reference shots;
Unetched copper surface at same magnification as previous closeups;
http://www.pbase.com/eldata/image/62468091
A cheap commercial PCB;
http://www.pbase.com/eldata/image/62473838
Closeup of above;
http://www.pbase.com/eldata/image/62473839
Better commercial PCB;
http://www.pbase.com/eldata/image/62473840
Closeup of above;
http://www.pbase.com/eldata/image/62473841
--- In Homebrew_PCBs@yahoogroups.com, "derekhawkins" <eldata@...>
>Nice etching.
Thanks.
Assuming you're already using the highest toner density setting, you
could try the solvent fumigation trick or one of those sprays like
Laser Buddy. Most of us just switch to Inkjet to solve that problem.
> to get to use.
Which model printer is this?
Not a problem, Inkjet artwork is so opaque you can severly
overexpose in terms of time and still not have pitting or undercut
issues.
Just add a collimation grid to an existing lightbox, waste of time
though, it's not going to solve your opacity problem nor is it going
to address any issues you may have in the .005" - .010" range IMO.
--- In Homebrew_PCBs@yahoogroups.com, "Andrew" <andrewm1973@...>
2006-06-26 by Andrew
> Derek wrote:
> <snip>
Never heard of fumigation trick or laser
buddy - I will google them both now.
I have an endless supply of inkjets and
ink for them  (I have a friend that
imports and sells bottled ink systems
for epson and canon printers).  I
always liked the sharp edge of the
laser better.  Guess I can give an
inky a try though.
>> well for large black areas - but it
>> is a half hour ride to get to use.
Fuji Xerox one which I think uses the
technology they aquired with tektronics.
It's a big true 1200dpi colour laser that
I think costs as much as a small car.
It's 4 and a bit foot tall, 4 foot wide
and 3 foot deep.  Makes my little LJ4000
look like a pocket sized portable.
Does a very very nice job on vellum.
Incredibly black and no pin holes in
sight.
> <snip>
> lightbox, waste of time though, it's not
> it going to address any issues you may have
My current light box is a breifcase style
kinsten one.  The lamps are too close in the
breifcase style boxes and I get uneven
exposure.  SO I want to build a better one
anyways.  No harm in putting in the
collimating grid while I am building it I
think :D
Hopefully the laser plotter will solve the
opacity problem.  And I think all my sub 8
thou problems are photo tool related.
2006-06-26 by Leon Heller
Sent: Monday, June 26, 2006 4:58 AM
Subject: [Homebrew_PCBs] Re: 6/6 Rules (.006" lines and .006" spacing)
>> Derek wrote:
>> <snip>
Using solvent fumes to make the image denser.
Leon
2006-06-29 by Andrew
> John Popelish wrote:
> <snip>
> down on the surface of ferric chloride
> almost straight up.  The loaded
> convection cell forms that provides
> slot (or hole) between two edges of
> down along both sides, preventing
> etches all the way through.  I have
> a diameter equal to the copper
> copper thickness.  The sides of the
> surface.
> <snip>
I will give this a try with some CuCl on
the weekend and see if it works with that
and what I think of it.
2006-06-29 by John Popelish
>><snip>
>>almost straight up.
(snip)
I await your report.  I have used the method only with ferric chloride.
