Muriatic acid and H2O2
2006-06-26 by mark.mickelsen
I'm considering using this combination as an echant and I was wondering
if anyone could give me some tips as to how to dispose of it safely
when I'm through with it.  Also, some tips as to how to tell when it is
all used up a I need to throw it away.  Any help would be appreciated.
Thanks.
Re: [Homebrew_PCBs] Muriatic acid and H2O2
2006-06-26 by John Popelish
Get a box of washing soda (sodium carbonate) from the grocery store.
Slowly add it to the expended etchant, till it stops foaming.  This
neutralizes the acid and precipitates all the copper out as copper
carbonate mud.  Dump the neutralized liquid down the drain and put the
mud in the trash.
2006-06-26 by Stefan Trethan
On Mon, 26 Jun 2006 04:32:44 +0200, John Popelish <jpopelish@...>
> mud in the trash.
Also consider if you don't want to use the etchant to start a CuCl batch
which can be regenerated forever.
ST
Re: Muriatic acid and H2O2
2006-06-26 by Hugo González Monteverde
Here's a link to doing the CuCl method.
http://www.smallsolar.org/workshop/etchant/index.htm
Hugo
Kiam oni amas, oni fajras...
Re: [Homebrew_PCBs] Re: Muriatic acid and H2O2
2006-06-27 by Myc Holmes
Note: Muriatic Acid is a very strong acid and will cause severe burns! Acid
burns destroy the tissue are very painful. Definitely use the gloves and eye
shield. Keep Baking Soda handy to neutralize any spills. If you get it on
yourself, flood, and I mean FLOOD, the area with water or apply a paste of
Baking Soda (Sodium Bicarbonate), then FLOOD with water.
Muriatic Acid will eat holes in metal, clothing and you. The mist and spray
created during bubble etching is very dangerous. Use extreme caution.
I like the way the Muriatic Acid / H2O2 etches, but it must be used with
respect. The bad habits and sloppiness picked up while using FeCl4 must be
unlearned.
Myc
(former Industrial Chemist)
> Hugo
2006-06-27 by Russell Shaw
> unlearned.
> Myc
HCl is tame stuff if not concentrated enough to be fuming.
http://en.wikipedia.org/wiki/Hydrochloric_acid
It stings on wounds like lemon juice or vinegar.
2006-06-27 by Adam Seychell
>>unlearned.
>>Myc
I know a guy who'd dunk his whole hand almost to the elbow when
retrieving a PCB from his heated ammonium persulfate bubble etcher.
Russell,
They say a little knowlegde is dangerous. Your comment is a prime example. I
spent 20+ years using HCL by the 55 gallon drum in an industrial setting.
Safe handling procedures were strictly followed.
Of course, there are defintely stronger acids than HCl, but all must be used
with safety in mind.
37% HCl is nothing to fool around with. There are some beginners here who
will listen to you and make that mistake. That's their choice and they can
remove themselves from the gene pool.
As L. Long said:
"Stupidity is a capital offense"
Myc
Note:  Adam, Ammonium Persulfate is not the same as Muriatic Acid (HC). I
rest my case about a little bit of knowlegde...
On 6/27/06, Russell Shaw <rjshaw@...> wrote:
> Acid
> eye
> on
> of
> spray
> be
> > unlearned.
> > Myc
>>Acid burns destroy the tissue are very painful. Definitely use the gloves and
>>eye shield. Keep Baking Soda handy to neutralize any spills. If you get it
>>on yourself, flood, and I mean FLOOD, the area with water or apply a paste
>>of Baking Soda (Sodium Bicarbonate), then FLOOD with water.
>>spray created during bubble etching is very dangerous. Use extreme caution.
>>be unlearned.
>>Myc
 > Russell,
The main problem there is large-scale spillage and fume generation.
Yes, but i said "not concentrated enough to be fuming". NewBs downfall is lack
of comprehension and research. Other dilute acids are still very hazardous even
when non-fuming (like hydroflouric acid).
The HCl you can buy from the hardware shop wouldn't be sold there if it was overly
bad, but it fumes and should be diluted to 5:1 or more before exposure (i've used a
lot of it for de-rusting). Getting dilute stuff in your eyes or a wound would be
painful, so *adequate* precautions are advisable.
 > Myc
2006-06-27 by YD
--- "mark.mickelsen" <mark.mickelsen@...>
> and I was wondering
> to tell when it is
> Thanks.
Save it and use it as a starter for a CuCl2 etch. Add
a few drops of H2O2 for every use and keep it in an
airtight container as long as there's excess acid in
it. It will become a bit greener every time you use
it. Once it's a deep green start maintaining it as
CuCl2.
If at some point it seems too slow and dilute
evaporate it in a shallow tray in the sun for a couple
of days, that's what I did and it worked a treat. If
you don't do many boards just feed it any old scrap
copper. It is a bit of a job getting it started this
way but once you have the hang of it you won't regret
it.
More links:
http://members.optusnet.com.au/~eseychell/PCB/etching_CuCl/index.html
http://www.pacificsun.ca/~robert/pcb/cucl.htm
http://www.pcbfab.com/iepart4.html
- YD.
Do You Yahoo!?
Tired of spam?  Yahoo! Mail has the best spam
protection around
http://mail.yahoo.com
Do You Yahoo!?
2006-06-27 by derekhawkins
Just started high school chemistry at around 14 years old....Had this
fungus looking mark about the size of quarter on my arm that none of
the doctor prescribed ointments could get rid of....Decided to steal
some HCL from the chemistry lab one day and dabbed some on the spot
that night....It started burning like hell and large pink craters
started forming on my skin....Rushed to the bathroom and flooded it
with water....Well, the good news is that the fungus went away for good
and the bad news is that I have the scars to this very day.
That episode is in the top five of the dumbest things I ever did as a
kid.
--- In Homebrew_PCBs@yahoogroups.com, Adam Seychell <a_seychell@...>
> kid.
Ahhhh, nothing like good old 18th century medication :)
2006-06-28 by Russell Shaw
> kid.
I got three darkish moles cut out by the doctor, and the resulting 10mm
wide wounds stitched up. The skin stretches over time so there's little
if any scarring.
