Hmm, having only two sensors, I tried all the combinations about 5
times and it still powers up in "error Mode". It thinks there is a
paper jam according to the manual. I also tried connecting my
computer to it - can't find a driver to work with XP either!
They have it for win3.1, 95, 98, me, NT, and 2000 but not XP - GRRRR!
I used the Windows driver for it but I don't think that will work
out in the long run.
Either way, that didn't correct the error problem either.
--- In Homebrew_PCBs@yahoogroups.com, Robert Hedan
<robert.hedan@...> wrote:
> I had something like that on the C84.
> On mine, that sensor is a 'paper present in paper path' sensor,
not a 'paper
> ready for feeding' sensor. Does that make sense?
> I remember having problems testing the C84, my initial reaction
was to
> trigger this sensor, that gave me an error.
> Robert
> > -----Message d'origine-----
> > De : Homebrew_PCBs@yahoogroups.com
> > [mailto:Homebrew_PCBs@yahoogroups.com] De la part de
lcdpublishing
> > Envoyé : avril 24 2006 14:58
> > À : Homebrew_PCBs@yahoogroups.com
> > Objet : [Homebrew_PCBs] Epson 850 - getting closer but now
> > have an error problem?
> > I got most of the mechanicals out of the way now and decided to
put
> > it back together where I can to check to see if it will work
still.
> > I got everything wired back up and power it up. It seems to do
fine
> > for a while - you hear it doing it's usual cleaning - the main
> > feeder shaft seems to rotate the right direction etc.
> > However, when it finishes that up, The "Paper" LED blinks and
both
> > inks show as being empty. I don't have this printer connected
to a
> > computer at the moment so that could be partially the problem -
not
> > sure either way.
> > There is one thing I have to remove and this too could be the
> > problem. The paper feeder has an opto sensor on it to detect
> > position of a shaft (the one that holds the cams to feed the
paper
> > in). This sensor is NOT the paper "leading edge" sensor. I
have
> > tried to manual rotate that shaft so the sensor can "see"
through
> > the hole and so that it is blocked - same errors either way.
> > Anyone have any suggestions - I am all ears .
> > Thanks
> > Chris
> > Be sure to visit the group home and check for new Links,
> > Files, and Photos: http://groups.yahoo.com/group/Homebrew_PCBs
> > If Files or Photos are running short of space, post them
> > here: http://groups.yahoo.com/group/Homebrew_PCBs_Archives/
> > Yahoo! Groups Links
