Epson C84 printhead mechanism
2006-04-20 by Robert Hedan
When you look at the printhead mechanism, there is; - a drive strap. - a front and rear guide rail. - a thin darkened transparency strip that passes between 2 'posts' behind the printhead. What's that thin transparency strip used for? I figure it's for motion control, but how does it work? It seems uniform grey colour, but I think it must be more than that, is it magnetized film with position markers? Or is it more of an optical device (my eyes can't make out lines, and I don't want to touch it)? I'm looking at what would be required to lift the printhead chariot by 1/16". So far I've determined that the drive strap would most likely not require displacement. That darkened strip might still be within sensor range, tests required. The front guide rail just requires a 1/16" spacer on the 'skate'. The main obstacle is that rear guide rail, the printhead is clipped around it. One possible solution is to trim the bottom of the clip 1/16" and adding a 1/16" shim at the top of the clip. I haven't taken the chariot apart yet, but the more I look at it, the more I think it would be possible to modify this printer to accurately process 1/16" PCB. Robert :) [Non-text portions of this message have been removed]
