Homebrew_PCBs
homebrew laser plotter
2006-01-22 by roel_cnc
i like the idea of making me own laserplotter.
tested: a pointerlaser (some cheap thing) with an extra focus lense, a
red sensible film gave me super fine lines (close to a single cloth
fiber).
did any of us fouling around with this idea !!
tips and suggestions always welcome:)
gr Roel (holland)
Re: [Homebrew_PCBs] homebrew laser plotter
2006-01-22 by Adam Seychell
> fiber).
> gr Roel (holland)
Are you talking a rotating drum laser photoplotter ?
Any idea of suitable low cost (<$5 A3 sheet) red light photosensitive film ?
There is also the problem of developing red light sensitive films!
Alternative is green, blue or even UV laser diodes. Choice depends on
photofilm and laser diode availability. Maybe the best approach is to
look at traditional black&white photographic films, and then decide on
suitable laser diode wavelength. Use common B&W films that are processed
with a standard red safe lights.
At say 20um wide pixel, that gives 15000 drum revolutions to scan a
length of 300mm. If drum spins at 1000 RPM, thats 15 minutes to
complete, which is acceptable.
Regarding film mounting, it is ideal to have the film placed on the
inside of a drum cylinder. The drawback with this approach is building
single sided bearing mount system for the drum. I guess thats all up to
degree of mechanical balancing.
Would be interesting hearing ideas too.
Adam
Re: homebrew laser plotter
2006-01-23 by roel_cnc
--- In Homebrew_PCBs@yahoogroups.com, Adam Seychell <a_seychell@y...>
lense, a
cloth
> > fiber).
> > gr Roel (holland)
on
to
on
processed
building
up to
> Adam
hi Adam,
Drum type would be nice but controlling and software tooks a great
deal of time to create i think !
must be somthing like a tv set creating a image on the screen with
sync goto next line :) lol
gr. Roel
Re: [Homebrew_PCBs] Re: homebrew laser plotter
2006-01-23 by Adam Seychell
roel_cnc wrote:
> hi Adam,
> gr. Roel
I'd be interested what you have discovered about photofilms for a home
made plotter. Let us know anything that converts your cheap laser into
raster scanning 20um beam projection. I think more brain power would be
required to devise software to compensate fringing of the projected beam
as would to the accurate and well predicted spiral mapping in a drum
plotter. If one were to build a < 50um resolution photoplotter then the
only feasible method is with a rotating drum. I'd be interested any
anyone's thoughts.
2006-01-23 by Leon Heller
Sent: Monday, January 23, 2006 2:40 AM
Subject: Re: [Homebrew_PCBs] Re: homebrew laser plotter
> roel_cnc wrote:
>> hi Adam,
>> gr. Roel
> anyone's thoughts.
Mega Electronics sells film for use with their laser plotter (it uses a
drum).
Leon
Leon Heller, G1HSM
leon.heller@...
2006-01-23 by Yngve Dahlstrom
Leon Heller <leon.heller@...> wrote: ----- Original Message -----
> roel_cnc wrote:
>> hi Adam,
>> gr. Roel
> anyone's thoughts.
drum).
Might be possible to hack an old HP LJ engine if you substitute the IR laser with something the film is sensitive to. Still sounds like a project more for self-education/entertainment than of practical value.
- YD.
Yahoo! Autos. Looking for a sweet ride? Get pricing, reviews, & more on new and used cars.
2006-04-28 by cunningfellow
<SNIP>
I like the idea too - so am going to try recreate
something half way between the pico-systems one
and the one bungard are selling.
Only sensible way to do it.
Have just found out I can get some red sensitve film
for about <$3 AUD an A4 sheet. (<$6AUD for A3 if that
is close enough to the mark for you Adam)
<SNIP stuff about other colours>
> revolutions to scan a length of 300mm. If drum
> spins at 1000 RPM, thats 15 minutes to complete,
I can't remember the last time I did a board 300mm
wide. So at 1000 RPM I reckon I would only be
waiting 5 minutes.
Still - I would be happy at 1 hour to get a decent
density to my blacks. In fact having it take an hour
would be an avantage to me - it would make me check
for mistakes more thouroughly :D
<SNIP stuff about mechanics>
I have started having a go at it. Have put together
a board with a 74HCT4046 Phase Lock Loop and some
other stuff to multiply the encoder wheel from a
servo motor. (and an ATMEL - apparently its against
the law these days to build something without either
a PIC or an Atmel on it)
Worked out my 7x10 minilathe isn't big enough to turn
up the drum. Going to have to steal a mates lathe for
that.
Have speced/thought out an interface to dump a BMP
file from a PC out to a laser (synced to the PLL
above)
Two parts I have not thought through yet are the
laser diode driver circuit and the carraige for the
laser.
Laser diode driver might end end up being an off the
peg solution so should not be too hard.
The carraige however I am undecided on. A belt, a
coach screw or a ball nut. The $1000 for a ballnut/
screw does not scare me too much. However if any
of the other homebrew guys out there want to make
one it might be a silly choice.
Whats everyone elses idea ?
Also do people want to see what I have done so far ?
2006-04-28 by Lez
Yes, pics please!
I am intersted in how your going to get the bmp out to a laser diode etc.
Reminds me of a paintjet (a real one, with paint, and an airbrush
using a jet of air) that was built in about 1990 on an amiga, did very
very large prints 2 metres etc and drum was turned by something odd
like a bicycle chain and a drill.....
> Lez wrote:
> Yes, pics please!
Your wish is my command. Check the files section.
"Laser Plotter"
I didn't take a photo of the bottom side to avoid the
merciless piss taking and cold solder joint counting
that seems to accompany solder photos in here :D
Will start a new thread for details on what I have
done so far.
To be honest, I didn't realy want to build anything
at all. I just felt someone had to build/do something
to affect the signal to noise ratio in the "My mothers
inkjet ink can resist etching better than your mothers
inkjet ink" saga.
It would almost be worth starting a "Macs suck - Amiga
Forever" flame war to have a post that didn't mention
toner transfer or MIS inks :D
andrewm
2006-04-28 by Lez
Thats where I'm going wrong, I'm using time and diptrace.
On 28/04/06, cunningfellow <andrewm1973@...> wrote:
> --- In Homebrew_PCBs@yahoogroups.com, Lez <lez.briddon@...> wrote:
> > Like the blue circuit board pic, whats it done with?
> Alt-PrintScreen and a bit of elbow grease.
Lez
- Looking for early starwars (episode 4, original starwars)
recordings, even pirate
- I dont need your originals just some information about running time
- and scene cut points
- also looking for a car, silver or white, 4 doors -
- diesel with a bosch pump, abs and pas -
- aircon would be nice, and not a ford -
Blue PCB - was re: homebrew laser plotter
The actual software I use is Easytrax an old freeware
version of protel for DOS.
To get the blue PNG of the PCB I go to windows, load the
PCB file into a cripple-ware demo version of protel for
windows. Then I zoom in to about 4x screen size. Cut-n-
paste into paint 4 times. Stitch them together.
The cripple-ness on the protel for windows demo is that
the save function is disabled. I'm glad they did that
rather than having a 30 day timed trial. I don't want
to save from it - I much prefer to do my layup in the
DOS version.
I have tried the newer version of Protel and have not
liked the loss of simplicity from the DOS version.
PLUS living in Australia if I used any CAD software from
another company, I would have the anti-protel police
come around to my house, beat me up and rape my dog.
andrewm
2006-04-28 by roger lucas
>above)
I am just starting to try to figure out BMP to raster
for the PCB EDM MILL for which I have just finished
the drive electronics,and xyz's. Because there are no
significant forces involved I have been able to use
the lightest of mechanisms.
Would be interested in your approach, the only
significant difference between our machines is that I
am essentially driving the spark generator whereas you
are driving the laser. Are you dumping the BMP file to
a separate micro or driving an interface direcly from
the PC? PC's are not my strong point, but PIC's and
Atmel are ok.
Yes, I would like to see what you have done so far,
PLEASE.
To all who are interested in the progress of the PCB
EDM MILL, I have produced a very simple clone of the
Garden of Edm circuit, modified with some hints from
Curt Richards (Curt are you still out there?).
Just got to figure out BMP to Raster scan
interpolation. If anybody else has any ideas please
say.
Roger
them here:
SPONSORED LINKS
Electrical engineering degree online
Printed circuit board
Electrical engineering course
Electrical engineering graduate school
YAHOO! GROUPS LINKS
Visit your group "Homebrew_PCBs" on the web.
Homebrew_PCBs-unsubscribe@yahoogroups.com
Your use of Yahoo! Groups is subject to the Yahoo!
Terms of Service.
___________________________________________________________
Introducing the new Yahoo! Answers Beta – A new place to get answers to your questions – Try it http://uk.answers.yahoo.com
EDM Lasers and marraige - was re: homebrew laser plotter
> the drive electronics <SNIP>
> Would be interested in your approach <SNIP>
> the PC? <SNIP>
> say.
Roger - Will you marry me :D
I so want to build an EDM for my machine shop. I can't
bring myself to build a spark-oscillator one for moral
reasons (it doesn't have an Atmel in it). Also the
garden_of_EDM looked too "thesis" project for me (here
is the idea, I am sure it would have worked if we had
more time to finish it)
It is another one of those "I will do it when I have
spare time" projects. If someone else is going to iron
out the bugs in Garden_of_EDM and give me an RTFM
idiots guide I will be so happy. I will also be able
to start my experiments to see if using stray cats as
a new form of dilectric has any merit :D
BUT to answer your questions.
I am dumping the BMP file to a seperate Micro.
There is going to be an ATMega in the laser plotter to
run the whole show.
I am going to try make it as universal as possible, not
stuck on Wintel machines. This is so people with other
computers like *nix, Amigas, RiscOS and VZ200s can use
it. Even people that dont have computers and only use
macs could try it. (wonder if that flame bait will work)
The idea is to have the ATMEL sit on a seriel port,
then you run some terminal software on the PC and
xmodem transfer the file to it.
The Atmel then turns the BMP file into a series of
dots. I guess it would be easy enough for you to
adapt it to burn holes with a spark rather than pulse
out a laser.
I was going to use TIFF file format with G3 fax
compression instead of BMP. On most PCB files you will
get about a 10:1 compression ratio with G3. This
might be important if I do manage to get 2000 dpi
out of the laser. The 1 megabaud limit of the FT232
chip I will use and a BMP would be a bottle neck.
I know I could use an AT90USB128 but that would
defeat the purpose of being free from writing any PC
software :D
The ATMega at 16Mhz should have pleanty 'nuff balls
to XModem, CRC, drive stepper, driver servo, drive
laser and decode G3-Fax without working up a sweat.
Worst case senario and I can't get an atmel to decode
G3 fax - I will hang my head in shame, do my own
RLE compression in software on the PC side and admit
to the world in general that pop-up-toasters do in
fact need 1 gighertz embeded Power-PCs.
2006-04-28 by Jan Kok
Maybe - there might be a problem at the edges of the film (that are
parallel to the axis of the cylinder), where the film might become
flat and not press against the inside of the cylinder. Also, might
have to tape the film inside, to avoid it sliding around.
Could have a conical plug that goes in one end of the cylinder. The
plug would have a bearing, and the plug/bearing assembly could be
mounted with a hinge to the baseplate. That allows the plug to be
removed from the cylinder so you can get at the inside of the
cylinder. But that doesn't sound like it is worth the trouble.
For good, cheap small ball bearings, check out the bearings for rollerblades.
Cheers,
- Jan
G3 fax - was EDM Lasers and marraige - was re: homebrew laser plotter
2006-05-02 by Andrew
> > the PC? <SNIP>
> Andrewm with the goat blood on his hands wrote:
> <Snip marraige proposals>
> <Snip>
> <Snip>
> <snip>
I am surprised no one quiped that a 1 Ghz CPU in a
toaster could be the heating element.
ANYWAYS - point of the post.
Mr Roger Lucas,
I have finished reading the TIFF specifications
carefully and also looked at some TIFF/G3 files in
a hex editor. It is very doable from a seriel
stream as long as the saving application does not
put the segments of the picture out of order.
Most of the apps I have looked at so far have saved
the TIFF in a suitable format.
I will over the next few weeks cut-paste/write
atmel code to:
- Act as a terminal
- Accept an X-Modem-CRC/128 file transfer
- Decode the TIFF header info and report if the
file is suitable
- Decompress the RLE/Huffman data into a stream
of black and white pixels
If your EDM hardware uses an ATMEL you are more
than welcome to the code. Even if you use another
micro you might like to look at the flow/logic/
pseudo/comments to see if you want to convert the
thing to run on your micro.
Re: G3 fax
2006-05-02 by Herbert E. Plett
I am already looking forward to it...
> atmel code to:
> - Act as a terminal
> file is suitable
Do You Yahoo!?
http://mail.yahoo.com
Re: G3 fax - Good news and Bad News
Well - The good news and bad news.
The good news is I wrote a quick and dirty TIFF
file decoding application in C on the PC this
afternoon.
The bad news is - MANY TIFF files have the image
description AFTER the pixel data.
This puts a spanner in my plans to just X-Modem
the file to the Plotter/EDM machine.
Does Roger or anyone else that may have wanted
to use this code have a preference for either of
the below options
1, Write some PC code the re-saves the TIFF with
the image descriptor at the start of the file
Then send this re-saved TIFF via X-Modem.
2, Write some code on the PC that just reads a
BMP or TIFF and sends it straight to the
target system byte by byte.
Option one is probably my preference. I can
still just use X-Modem. The re-saved TIFF is
still a valid TIFF. If your application saves
in that format anyways - there is no extra step.
Option two means I have to write more PC code
than I normally like too - lazy lazy andrew.
Re: [Homebrew_PCBs] G3 fax - was EDM Lasers and marraige - was re: homebrew laser plotter
2006-05-02 by roger lucas
Andrew,
I am very interested in your approach, code etc etc,
although I will probably use a PIC for the raster
handling since I already have a PIC controlling the 3
axes and the spark control. I never thought of the
TIFF format. Please post anything you develop, all
will be gratefully received.
Roger
> <Snip>
> <Snip>
will
> <snip>
decode
Mr Roger Lucas,
atmel code to:
- Act as a terminal
file is suitable
them here:
SPONSORED LINKS
YAHOO! GROUPS LINKS
Terms of Service.
Switch an email account to Yahoo! Mail, you could win FIFA World Cup tickets. http://uk.mail.yahoo.com
Re: [Homebrew_PCBs] Re: G3 fax - Good news and Bad News
2006-05-02 by Dave Hylands
Hi Andrew,
> afternoon.
Just an FYI.
I've used the libtiff library (www.libtiff.org) on previous projects
and it seems to work quite well. It also has lots of utilities for
manipu;ating TIFF files (compressing/uncompressing, resizing, etc).
Dave Hylands
Vancouver, BC, Canada
http://www.DaveHylands.com/
Andrew,
I have just completed some EDM tests (see separate
post), and certain requirements have come to light
which means that ideally I would like to read a BMP
and send it to the target byte by byte, (I need to add
extra commands after certain sequences of OFF pixels
in the target processor).
Sorry if this causes extra work, I know how difficult
it can be in the land of the Amber Nectar to motivate
oneself after lunch. LOL.
Roger
afternoon.
the below options
them here:
SPONSORED LINKS
YAHOO! GROUPS LINKS
Terms of Service.
Win tickets to the 2006 FIFA World Cup Germany with Yahoo! Messenger. http://advision.webevents.yahoo.com/fifaworldcup_uk/
PCB EDM MILL Initial Tests
Well, I finally motivated myself this holiday weekend
to get my PCB EDM lash-up to cut copper, and, YES, it
does cut clean lines thru the copper without board
burning or marking. Shine a torch through the tracks
from the rear of the board and there is a faithful
line of light, (no firstborn goats or pentagrams
neccessary).
With my highest power lens and head magnifier I could
see no trace of copper whiskers on the EDM'd track.
Interestingly, the copper is blasted away entirely
below the cross section of the wire, there is no
'erosion bleeding' into the surrounding copper outside
of the wire dia.
Have only cut straight lines so far with 26 swg and
with a 0.2 mm step increment, (need to modify the
stepper gear ratio), and with multiple (continuous)
sparking between increments, (no on/off sparks or
raster yet).
One significant problem has emerged which Curt
Richards did not address, (or if he did, he did not
mention it). The wire electrode erosion is
significant, and will require an active Z axis
correction to maintain as consistent a spark gap
distance as possible between the electrode and pcb
surface. To do this I will insert a routine to 'touch
down' the electrode on the copper to zero the gap,(no
spark, closure sensed by two PIC output/inputs for
voltage present), and then retreat the electrode to a
standard clearance before any track eroding is
commenced, (Andrew, this is why I need the BMP byte by
byte transfer). This will also tend to compensate for
any board distortion.
Used tapwater as a dielectric with no problems, (the
modified Garden of EDM circuit controls the
electrolysis with no problems).
Curt controlled his spark discharge voltage by
dynamically adjusting the electrode gap on the fly. I
think that for pcb work this is not the correct
approach because of the wire erosion problem, since
one needs to KNOW the gap distance AND available
discharge energy BEFORE discharge, which is why I am
going for the touch down zeroing method, (slower but
speed is not significant at the moment). The discharge
energy will be set by presetting the voltage level
required and capacitor selection, (simple comparator
control integrated into the spark control). I think
this is the secret of successful pcb edm'ing.
This is really looking as if direct raw copper board
to finished pcb is going to be possible.
Roger
Yahoo! Photos – NEW, now offering a quality print service from just 7p a photo http://uk.photos.yahoo.com
Re: [Homebrew_PCBs] PCB EDM MILL Initial Tests
2006-05-02 by Alan King
Don't you want to try changing every other variable first, to see if
you can eliminate the erosion problem first, then adjust everything else
to match? With the same distance everything else could be just as well
known with 1/4 the spark energy and 4x the rate for the same total,
seems you could simply be too close for the instantanious spark energy
you are using or something similar..
Only messed with EDM a few times, but I think I'd try everything under
the sun first before living with the electrode eating up, even to the
point of feeding blasting caps to the goats in the backyard before
giving up.. Keep them away from the back wall unless you want a mess.
And keep a camera handy, you will want a pic of the PETA girl's face.
Also start thinking now about two electrodes. Could cut both sides
with a 2 tooth tip, but independent control would be better. Raise one
while traveling to make an intersection. Change the width for different
traces or pads etc. And start routing everything with parallel traces
and you'll be cutting one edge of two traces at once, should cut the EDM
time about in half. Might even be nice for a third or fourth parallel
electrode for use while the board is already under control..
Alan
Re: PCB EDM MILL Initial Tests
2006-05-02 by lcdpublishing
VERY COOL! ;-) I am glad to hear that no goats were harmed in the
production of those EDM cut PCBs :-)
Chris
--- In Homebrew_PCBs@yahoogroups.com, roger lucas <ralucas4277@...>
> neccessary).
> of the wire dia.
> raster yet).
> Roger
2006-05-02 by Stefan Trethan
Good to hear you got such good results.
I don't have any specific concerns why it would not work, never had after
some manual tests with a simple power supply.
But i don't currently have the time to build a CNC, although i have most
components set aside for a while now.
The electrode erosion thing was discussed back then, if i remember
correctly the thinking was that one would advance the electrode until a
spark of the correct voltage is occuring. One would need to decide if the
energy was sufficient to blast out the pixel or if it must be re-done.
But your approach seems a good idea also.
Keep us updated, i definitely plan to build the CNC but it will be months
for sure. If i use it for drilling of inkjet printed PCBs or if EDM will
be an option is to be seen.
what material is your electrode wire made of?
ST
On Tue, 02 May 2006 18:07:19 +0200, roger lucas <ralucas4277@...>
> neccessary).
> of the wire dia.
> raster yet).
> Roger
Hi Stefan,
I know that it should have worked in theory, but I was
surprised at how well it actually turned out.
I tried with tinned copper wire and a tinned steel
sewing needle (purloined from my wife's needlework
box), essentially the wear was about the same for
both. The eroded pixel diameter is directly related to
the electrode dia, as the sewing needle eroded the
pixel became larger.
I need to try to obtain some half hard or hard 10 mil
brass wire for the next trial.
The setting of the spark parameters before sparking is
essentially to eliminate the uncertainty of whether
pixels have been fully eroded or not, especially where
electrode wear is high. I might just try some broken
carbide drill bits, the tungsten might resist erosion
better, trouble is carbide only goes to 0.5mm dia.
Will post some sample photos after next revision and
trials.
Roger
> if i remember
> it must be re-done.
> PCBs or if EDM will
> ST
> <ralucas4277@...>
> weekend
2006-05-02 by Codesuidae
What is the linear feedrate for this? Or, alternatively, about how many
square cm of copper are removed per minute?
Dave K
We were even considering a rotating electrode and a diamond wheel
"automatic sharpening station" back then.
Try graphite, they use it for EDM sinkers.
Probably a continous feed wire is easier than all that, but it would need
to be pretty thin wire to get any decent resolution.
ST
On Tue, 02 May 2006 19:57:22 +0200, roger lucas <ralucas4277@...>
wrote:
> Hi Stefan,
> trials.
> Roger
Electrode erosion is quite normal with EDM, it is not a fault as such that
can be eliminated.
Probably can be reduced though..
ST
Roger, I am not real familiar with EDM, but I do recall that the two
materials used for electrodes were carbon (for sinker types) and
Brass for Wire EDMs.
In the case of what you are doing, it fits into the realm of a
sinker type EDM. I vaguely recall them using a sinker EDM machine
to drill some small holes in some very hard metal. I believe they
used a carbon electrode for that too. Sorry I can't offer more, it
was about 18 years ago I was involved with that company and no
longer have any contacts in the EDM field.
Chris
> Roger
> > if i remember
> > it must be re-done.
> > PCBs or if EDM will
> > ST
> > <ralucas4277@...>
> > weekend
2006-05-02 by javaguy11111
Since some have suggested carbon electrodes you might try .3mm or .5mm
mechanical pencil leads. I have no way of knowing if they would be
appropriate,but might be worth a try. You should be able to find .3mm
leads at an art or architectural supply store.
--- In Homebrew_PCBs@yahoogroups.com, roger lucas <ralucas4277@...> wrote:
> Hi Stefan,
> trials.
> Roger
> > if i remember
> > it must be re-done.
> > PCBs or if EDM will
> > ST
> > <ralucas4277@...>
> > weekend
>can be eliminated.
Yep hadn't thought on it in a while, but doesn't look like much you
can do beyond having the electrode negative and spark power etc. If
only you could keep the electrode very cold and the board very hot for
different vaporization energies, but wouldn't be easy. Heck wire is
cheap anyway..
Your wheel got me thinking on a disc, a thin copper washer on a Dremel
arbor would have much larger edge area. Spin it some and it'd last a
long time with little change in gap, a little less precise in the long
direction but that's the way of travel. But directional, wire isn't,
and again heck it's cheap make a feed system and throw more at it. .2mm
pencil lead might be an option too on the graphite end of things..
For this, an HP Plotter may be a good choice too, no real need for CNC
power. HPGL is so flexible you may even get to the low feed rates
needed just from the language.. Of course I just threw mine away with
the older inkjets in the last round. Useful but way too bulky when not
using, and easy to replace for $10 or $20 here or there. Didn't even
junk them this time, too much work for a few motors.
Alan
[Homebrew_PCBs] RE : PCB EDM MILL Initial Tests
2006-05-02 by Robert Hedan
A short video would be ever so cool for nerds like me who have never seen
this type of machine. I can host it for you for a while too.
Robert
> -----Message d'origine-----
> De : Homebrew_PCBs@yahoogroups.com
> [mailto:Homebrew_PCBs@yahoogroups.com] De la part de roger lucas
> Envoyé : mai 2 2006 13:57
> À : Homebrew_PCBs@yahoogroups.com
> Objet : Re: [Homebrew_PCBs] PCB EDM MILL Initial Tests
> trials.
> Roger
No problems. BMP files are pretty easy to read.
I will have a play around with them in the next few
days.
For my purposes - I will still need to compress them
(G3 my pref) just to get them down to the plotter in
under 4 hours.
I don't quite understand the "motivate onesself
after lunch" comment. Is this "lunch" you refer to
something about 1/2 way through the day that we call
"Rum o'clock" :D
2006-05-03 by Andrew
> (www.libtiff.org) on previous projects and
> lots of utilities for manipu;ating TIFF
> etc).
Thanks - I suspected that there would be 1001
free librarys on the PC to do tiff. I wanted
to try decode it myself so I knew I could
re-write the code in an Atmel.
Now I am going to be reading the TIFF on the
PC for the final product - I will have a look
at the www.libtiff.org - thanks.
> roger lucas wrote:
<BIG snip>
YAY
> no goats were harmed in the production
AND
> AlanK wrote:
> even to the point of feeding blasting
> wall unless you want a mess. And keep a
> PETA girl's face.
But what will I do with unused goats if
the wire EDM works sans goats ?
andrewm - I'd rather be nekkid than wear
a thin film of goat blood.
> electrodes. Could cut both sides with
> would be better.
I don't understand why independant control
would be advantagous. The EDM was going
to be done raster not vector.
However - I agree that extra wires would
be cool.
Make it like a 24 pin dot matrix printer
(pins offset so they dont inter-pin-spark)
Knock out an EDM in pages per minute
rather than minutes per page. I knew
there was a reason I wanted 3 phase power
in my shed :D
2006-05-03 by Dave Hylands
Hi Andrew,
> under 4 hours.
G4 should give even better compression. It requies a bit more memory
to decompress since you need to use the previous line as a reference
line.
Dave Hylands
2006-05-03 by Chris Horne
Roger,
how small do you need to go ? probaly smaller than 0.6mm..
pity..
0.6mm Mig welding wire is cheap stiff and freely available.
Mild Steel would be the obvious choice,
it also has a nice copper coating for electrical connection, and the
design for the feed mechanism used in mig welders could possibly also
be used (Two rollers, one with a groove in it, much slower of course)
Chris
> Hi Stefan,
Re: G3 fax - was EDM Lasers and marraige - was re: homebrew laser plotter
> etc etc, although I will probably use a PIC
> for the raster handling since I already have
> a PIC controlling the 3 axes and the spark
> control. I never thought of the TIFF format.
> Please post anything you develop, all will
Roger - I missed this part in the TIFF FAQ
<Quote from a TIFF faq>
Question 7. Can I not stream TIFF? Why does my
library need seeking forward and backward in
my TIFF file?
TIFF is not a streamable format. It is its
very nature that all data blocks can be
written in any order that is convenient for
the particular application and/or TIFF
encoding library.
</Quote>
The first TIFFs I looked at where suitable
for streaming. They had the information
header in front of the actual picture data.
However the main app I use, and I guess a lot
of people do, is irfanview. It saves TIFF
with the header at the end of the file.
Many other apps probably do the same.
This just can't work for the plotter (or I
guess for your EDM). This is because the
ATMEL (or PIC) does not have enough memory
to hold the whole file. It has to burn each
line as it receives it and then discard that
data to buffer the next line.
Problem here is that you don't get to find
out things like how wide and how long the
file is in pixels until you get to the end
of it.
BMP is a much more strictly organised file
structure and always has the picture info
in front of the picture. It is an absolute
doddle to read.
The draw back of BMP is that there is no
compression.
a 12 inch by 6 inch 2000 DPI black and white
BMP will be 35 megabytes.
At 115200 baud if you take into account
overheads of a UART, X-Modem and the like
you end up with a 63 minute transfer.
Even at 1 megabaud it takes 7 minutes.
7 minutes IS within the time limit I would
like a plot to come out, but receiving at
1 megabaud is going to be a bigger strain
on resources of the ATMEL than if it where
to be run length compressed.
It would be easier for me to receive a
3.5 megabyte file and decompress it on the
fly than receiving 35 meg.
The EDM requirments are probably not as bad.
I would probably guess 500 dpi (0.05mm) would
be your highest res.
However it would still probably be easier for
your PIC to receive and do the CRC of a
smaller file and then decompress an easy
scheme like G3 or PackBits.
Tell me what you think? I am now thinking
- Read BMP file in PC software.
- Get PC to compress and send to ATMEL or
PIC in X-Modem-CRC format.
- Atmel decompresses to actual raster data.
> It requies a bit more memory to
> previous line as a reference line.
Yeah - I looked at G4 - it does about 25%
to 50% better compression on pictures
that look like PCBs.
I was however planning on using an atmel
with only 8K of ram.
If I had to put any external chips on
the thing to make it meet the specs I
will probably just say bugger it. Get
an ARM, put oddles of RAM run *nix on
it and FTP the file stragiht to it.
When the cat (or goat) gets too big to
skin wih a knife - you resort to high
explosives.
2006-05-03 by curt_rxr
wrote:
Well done Roger!
> surface.
Roger I used brass wire and distilled water and had arranged the servo
circuit to feed the wire via a pinch roller and worm screw drive. the
servo circuit is as per the NASA / Garden of EDM circuit.
Roger the gap breakdown voltage controls the gap via the servo. As
the electrode ( brass wire ) advances the gap closes until the spark
after which the electrode retracts so the system is ready for he next
spark.
> The discharge
> Roger
Hi Roger,
I'm glad to see someone making progress. My system is stalled at a
pulse repetition rate of 200,000 per second using IGBTs designed for
auto igniton system. That rate gives me about an hour and a quarter
pocessing time for an 8 inch by 12 inch PCB using .001 inch brass wire
as an electrode. It makes a real nice board, but I can use Toner
Transfer and CuCl2 bubble etching to make five boards in the same time!
I'll be interested in your advances to the art, but right now it looks
to me like the direct print inkjet system will replace TT and EDM for
homebrew PCB prototyping.
Curt Richards
> Curt AND Roger wrote - lots about EDM....
> Curt then wrote :
> <SNIP>
> using IGBTs designed for auto igniton
> hour and a quarter pocessing time for
> inch brass wire as an electrode. It
> Toner Transfer and CuCl2 bubble etching
> the art, but right now it looks to me
> will replace TT and EDM for homebrew
> PCB prototyping.
I was wondering if either Curt or Roger
would be willing to shre their circuits
with others. Some of us are a little
bit lazy and have a little to much other
stuff to design. An RTFM build would
be greatly appreciated. Even if it was
less than optimal.
I also don't know how fast the EDM PCB
could run. But I did a quick (stupid)
test with my fronius magicwave 180 amp
tig welder. I couldn't get 6 thou trck
spacing - but MY was the copper removal
rate fast :D:D:D
Re: [Homebrew_PCBs] Re: G3 fax - was EDM Lasers and marraige - was re: homebrew laser plotter
2006-05-03 by Russell Shaw
> my TIFF file?
> encoding library.
> </Quote>
> of it.
Just get the PC to re-order the file before sending it.
Decent software decomposes the data (in whatever image
format) to specialized control instructions for the machine
anyway.
Re: G3 fax - restating the problem for those who didn't see the first plan.
> > of it.
> sending it.
The original plan was to not have to write
ANY software on the PC ('cause we all hate
doing that).
It was just going to be use hyper terminal to
send the TIFF file to the plotter/EDM unit.
(X-Modem-CRC)
Seeing as we can't be sure that a TIFF file
is written in order - I HAVE to write some PC
software.
Either software to read a TIFF and re-order
it so it can be sent OR software to just
read a BMP/TIFF and send it to the plotter
myself (without hyper terminal)
> whatever image format) to specialized control
> instructions for the machine anyway.
A Decent machine doesn't need specialised
control instructions. It just reads a native
file from the control source :D
Seeing as my machine does not have enough
memory to read an abitary TIFF or enough
bandwidth to read a BMP. I am going to
have to compromise and only have a 1/2
decent machine that needs some special
Re: [Homebrew_PCBs] Re: G3 fax - restating the problem for those who didn't see the first plan.
>>>of it.
>>sending it.
> doing that).
> (X-Modem-CRC)
> software.
Most "real" machines read G-code, that has been
generated from the original CAD data such as DXF
(gerber is G-codes).
By converting all external data types to one format
suited to the machine, machine complexity is minimized.
Even if it could read tiff, that would mean that any
other data type would need to be converted to tiff.
2006-05-03 by Herbert E. Plett
> doing that).
> (X-Modem-CRC)
> software.
what about using any 'fax' program?
the nasty thing about PC software is it has to be multi-platform these days.
the old days of 'only' M$ are over...
Do You Yahoo!?
>>doing that).
>>(X-Modem-CRC)
>>software.
Multi-platform is easy as long as you exclude M$;)
>>> TIFF file is written in order - I
>>> HAVE to write some PC software.
I think a fax program would have a fit
if you gave it a BMP that was 12000 x
20000 dots. It is normally dealing
with files that are 204x204 DPI not
2000x2000 dpi.
> > days. the old days of 'only' M$ are
> > over...
> exclude M$;)
Multi platform is so easy if all you
need a a terminal program someone else
wrote :D
andrewm - Who is wondering if the
russell(dot)AU is from SE Qld.
Re: [Homebrew_PCBs] Re: PCB EDM MILL Initial Tests
2006-05-03 by Alan King
>>would be better.
I didn't really read every word of the rest so may have missed
something about raster, but raster would take a tremendous amount of
time vs vector, and the single wire CNC setup doesn't really have a
reason to go over areas that aren't etched, if it's following the cut
line and in different directions it's vector regardless of being an XYZ
table and keeping most of the paths X or Y.. Raster's more a fixed
format scan of everywhere, not really needed for this type of thing
normally. Little reason to travel uncut areas with a CNC.
And you almost always have to cut the other side of the trace, whether
it's an isolated trace or simply the cut between this trace and the
next. Wasn't clear, that was independent control of the feed rate of
both wires not different XY control, fixed or simple distance
relationship. You have to control seperately anyway for different
erosion rates, simpler to just back one or the other wire off where you
don't want to cut than control the supply too..
Really this would be simple, and do 90% of things well with an easy
enough system:
o
x o
All three the same size, x is just the main electrode. 3 seperate
feeds, two power supplies, the second attached to both of the secondary
wires. Main one cuts and does the tracing, upper cuts the other side of
horizontal traces, right one cuts the other side of vertical traces.
Keep most of the cuts horizontal and vertical and this will let you
isolate both sides of a trace at once without requiring rotation, just a
second supply and seperate feed mechanisms for the three wires. Just
back one of the two secondaries off or both for curves or diagonals with
only the main wire.. Generally double the linear cutting rate of a
single wire, with only a second power supply and 3 feeds so still not
too complicated. Don't care about the width change and you could do 45
deg diagonals too, they'd just be more narrow with a fixed system.
Just two supplies and 3 feeds on a CNC, may just have to try it out
myself. If it can be taken down to cutting pads and traces for SOIC
pitch devices it'd be great, that'd do enough for most prototyping.
The real work will be automatically controlling the feed rate for
erosion. With just drilling a hole, you simply look at the spark
frequency and when it gets too low you feed, it's in the direction of
feed. With this you have needing XY direction feed and erosion away
from the board that both reduce the spark rate. No doubt figureable but
not as easy..
>be cool.
Would be nice for other things even. But with differing discharge
rates or on or off control that will take either or both of 24 feeds and
supplies, depending on how you want to do it. Could probably hack a few
motors to do it all, like a vending machine selector, but getting it all
to work would probably still be not so easy..
Alan
> been generated from the original CAD data
> such as DXF (gerber is G-codes).
I Assume "real" means real milling machine /
drilling machine or something specific to PCB
or engineering.
Real plotters use HP/GL
Real printers use postscript or PCL
Real photo-printers (often) use TIFF
My photoplotter will also be used to make photo
tools for screen printing. That will be
inherently raster stuff rather than bitmaps.
Someone else has written the software to
convert gerber to bitmaps so I dont have too :D
> format suited to the machine, machine
There are lots of different standards out
there. I would have liked to use one of
them rather than make up my own.
> mean that any other data type would need
Yes - but by some software someone else
has written and that is also probably
already availabe cross-platform.
You do understand the concept and
advantages of making the machine just a
terminal that accepts a file via x-modem
don't you ?
> 2000x2000 dpi.
>>>over...
>>exclude M$;)
> wrote :D
A terminal program just dumps files from
the pc into the machine, which is no different
if tiff or g-code is used.
Another way is to have only a small buffer in
the machine and download a few g-codes at a time,
which should be doable with a terminal program if
flow-control is used.
I'm near melbourne (never been to Qld).
Beware of cane toads;)
> rest so may have missed something about
> amount of time vs vector, and the single
><snip>
Curt and Roger where doing it raster to avoid
problems of isolating copper from the GND
electrod clip.
If you just used a normal isolation milling
CAM file (like you would with a mechanical
router) then you might end up with an
island of copper in the middle of the board
with no ground connection.
The EDN wont spark on that any more :(
> or engineering.
Printers aren't "real" machines;)
I mean milling machines, x-y laser cutters, etc.
> don't you ?
Yes, but i'd use a vector format like g-code, gerber,
postscript, pcl, or some forth dialect because the file size
would be a thousandth of a bitmap file size. For an edm
or milling machine, the vector commands can be executed
directly. For a raster output device such as a scanner,
the machine controller can rasterize the vector output
like laser printers do with postscript.
> different if tiff or g-code is used.
Well - In this application g-code is not
suitable. If you remember the start of the
thread - I am trying to make a cheap
photoplotter anyone can replicate for a few
$100 or so.
Drum photoplotter means raster.
Cheap means that I cant have enough CPU and
RAM onboard to convert vector to raster
internally.
The board is planing on having an ATMEL,
a analog PLL and not much else on it.
16 megahertz - 8 bit CPU
128K ROM
16K RAM
couple of timers
a UART
and an SPI port.
Call me a masochist I guess :D
> g-code, gerber, postscript, pcl, or some
> size. For an edm or milling machine, the
> vector commands can be executed directly.
> scanner, the machine controller can
> rasterize the vector output like laser
Big thumbs up to vector formats.
They are GREAT.
But not in an ATMega1280 :D
hmmmm - I wonder if I could fit it into
an AT-Tiny45 ......... NOW there is a
challenge for me.
Makes sense and easy enough and probably not even that bad with an
intelligent skip of uncut areas.. I'd still rather see it draw the
traces with electricity, shouldn't be too hard to figure out some type
of useable sort and just more fun to watch.
> $100 or so.
> internally.
> 128K ROM
> 16K RAM
> couple of timers
> a UART
> and an SPI port.
I got slightly confused thinking of EDM machines.
At the data rates needed, you'll need to store the
whole file in the machine controller.
A 300mm drum has a circumference around 1000mm.
Assume a pixel size of 0.01mm.
If it rotates at 600rpm, the pixel rate is 1Mpixel/sec.
A 100mm x 100mm plot will need 1000s or 17mins to scan.
The averaged pixel rate will be 100k pixels/sec.
The file size will be 100Meg pixels, which is impractical.
You'll need to transfer and store the file in a vector
format, and progressively rasterize it as the drum scanner
needs it. If you rasterize to 1k pixels at a time, you'll
only need to do that 100 times per second.
> $100 or so.
> internally.
> 128K ROM
> 16K RAM
> couple of timers
> a UART
> and an SPI port.
The pc could send bitmap data while the machine is running,
if the data rate is higher than 100k bits/sec. Fast rs-232,
usb, or ethernet could do that.
> not even that bad with an intelligent skip
> draw the traces with electricity, shouldn't
> be too hard to figure out some type of
It would be an easy enough algorithm to to
get all the vectors from the G-Code and
z-sort them to avoid islands. But we are
going to get back into the writing PC
software argument again if we do :D
I think the 24/32 wire EDM printer might
win in a race with a vector one at the end
of the day anyways.
Back to the reason why I want G3 compression
> to store the whole file in the machine
> controller.
I was only planning on storing 1 row/
scanline of data at a time.
> 1000mm. Assume a pixel size of 0.01mm.
> is 1Mpixel/sec. A 100mm x 100mm plot
> will need 1000s or 17mins to scan. The
> /sec. The file size will be 100Meg
> machine is running, if the data rate is
I was planing on a 16.384 inch active
area on a 20 inch or so round drum that
is 10 inches long.
(no prizes for guessing why I chose the
active area to be 16.384 inches)
2000 dpi (about 0.01mm) resolution.
It ends up being a file size of 35
megabytes.
I think the data rate I worked out I
wanted was 800 kilo baud RAW.
An FT232 sitting on a USB port can do
this. But its going to be a strain on
the poor Atmel to keep the throughput.
Most PCB files compress better than
10:1 with G3.
If I G3 compress it I can get by with
much lower baud rates (sub 100 kilobaud)
CRC on a 1 megabaud link will take
more time than CRC on a 100kilobaud
link and G3 decompression together.
I think the ATMEL has enough omph
for either - but i like the idea of
keeping horsepower spare in case I find
there is something else I need to do.
Worst case senario and I am prting out
a bit map for a T-Shirt and I don't
get 10:1 compression - it just runs
slow.
Because the atmel has enough memory to
buffer one full scan line - it wont
BREAK the thing - it just will mean it
has to pause between scanlines. (one
hour to print instead of 10 minutes)
> of the day anyways.
Hi Alan and Andrew,
When I started playing with the idea of EDM ing PCBs a couple of years
ago, my thought was to modify a printer and "print" the PCB using most
of the PCL code built into the printer so that I could go directly
from a jpeg or scan of magazine artwork to copper. Like many "good"
ideas there were bumps on the road to realization!!
Using vector graphics would be very much faster, especially if
combined with multiple size selectable electrodes, but would lose the
ability to scan artwork and then "print" it to the PCB. Also a vector
approach requires attention to the ground return path.
Andrew I believe Stefan did some experiments with burning the copper
away as opposed to the spark erosion of EDM. I'm not sure as to his
results, but perhaps he could help with your TIG experiments.
I've pretty much suspended work on my PCB EDM project until I can
figure out a reliable ( and cheap! ) way to get a pulse repetition
rate of closer to 1 mHz. Since Volkan's inkjet announcement I'm
pretty sure EDM ing PCBs is a thing of the past in any event.
Curt Richards
2006-05-03 by roger lucas
Hi Curt,
Good to hear from you again.
>arranged the servo
>screw drive. the
>circuit.
I am in the middle of designing an electrode feed
system similar to yours. I have not heard of the NASA
circuit, is it some sort of servo drive?
>the servo. As
>until the spark
>ready for he next
>spark.
If I understand this right you are initiating the
spark by advancing the electrode and retreating it at
each point. How does this keep up with your scanning
speed of approx 20 inches/sec? Or have I totally
misunderstood the operation of the servo?
My early experiments included a solenoid armature
oscillating an electrode at 50 Hz, amplitude about
1mm. This worked very well since the spark always
initiated at the dielectric breakdown point. However,
at the moment I can see no way of integrating the
electrode feed with the solenoid arrangement. If I
could it would answer a lot of problems.
>Hi Roger,
>is stalled at a
>IGBTs designed for
.auto igniton system. That rate gives me about an
>hour and a quarter
>processing time for an 8 inch by 12 inch PCB >using
>can use Toner
>in the same time!
>right now it looks
>Curt Richards
My boards are all 4 x 3 inches, but the attraction of
EDM is it is the cheapest way to go, and it can be
left on its one to process with virtually no board
preparation, and no ink or etchant costs.
Roger
them here:
SPONSORED LINKS
YAHOO! GROUPS LINKS
Terms of Service.
NEW - Yahoo! 360 – Your one place to blog, create, publish and share! http://uk.360.yahoo.com
>days.
Andrew,
Many thanks, will look forward to that.
>under 4 hours.
>"Rum o'clock" :D
What we call "Going for a swift half" I think.
R:
them here:
SPONSORED LINKS
YAHOO! GROUPS LINKS
Terms of Service.
24 FIFA World Cup tickets to be won with Yahoo! Mail http://uk.mail.yahoo.com
>of the day anyways.
24 things to fail at every step, better start now so it can work by
2012.. :)
Alan
> 2000x2000 dpi.
just don't tell it it's 2000x2000, tell it it's 200x200 but 10x larger...
not sure how :(
Do You Yahoo!?
yes and no
G-code is for managing vector movements, not raster patterns
Do You Yahoo!?
>Roger
Inkjet is preeminiently reliable, with low costs and little extra work
for etching. Far more likely to have to watch the EDM or have more
often mechanical problems, plus wire and electricity isn't zero either,
even expensive ink will work out very low cost per board when it's only
used for PCB. All things considered it's unlikely to actually beat out
the inkjet, and even if it did it'd be so marginal for the extra work of
setting it up and keeping things running. Doing it for fun is one thing
since it'll be very cool, but if you're expecting practicality I doubt
it'll work out too well, just hard to see it coming out ahead by enough
to make a difference.
Alan
2006-05-03 by Stefan Trethan
I agree with you, inkjet may well turn out to be the most efficient
overall.
EDM would do away with the need for chemical etching.
It would go that one step further towards making things easier, but it
remains to be seen if the limits and problems do not far outweigh that
advantage. Especially resolution and speed are things that i'm not at all
confident will work out sufficiently.
ST
> Alan
Hi Roger,
> Hi Curt,
It's the circuit used in the Garden of EDM -- I'll be glad to e mail a
PDF of the original NASA Tech brief to you if you like.
You've got it exactly right.
It's not a problem -- the pinch roller that feeds the wire through the
insulating sleeve is driven on the same principal as a voice coil
drive in a hard drive and doesn't need to move the electrode very much
at all.
There are two ways to implement the servo. One is to use a stepper to
control the pinch roller whichs feeds the brass wire through the guide
the other is to use a worm drive and dc motor.
Your vibrating electrode is the same approach Ben Flemming used in his
Ramah Tap Burner design and should work well for PCBs which are
*FLAT*. It would simplify the overall design a ton. Well Done!!
> Roger
Yep!! And if you incorperate a drill head on the back of your gantry
you'll be able to drill the boards in water and save on dust collection.
Roger, I'm not saying the PCB EDM is a dead end -- just my system is
stonewalled! Since my major efforts in the spring and summer are
working on various Willys Jeep and Truck restoration projects and I
won't be much help in developing the PCB EDM until fall.
Good Luck to you Roger and feel free to ask me questions, I'll try to
be helpfull.
Curt Richards
> experiments with burning the copper away
> I'm not sure as to his results, but
> experiments.
Curt - is wasn't a serious experiment that
I thought would lead somewhere - I just
wanted to be destructive in a way that
didn't involve goats :D
Who cares about "cheapest" I think "most automated"
might be the winner.
And if you include ink drying and curing time - I
think it could win for speed as well.
> >of the day anyways.
> start now so it can work by 2012.. :)
Them there fandangled ink jet printers have
between 48 and 120 nozzels per colour and
they don't break down more than 3 times a
day :D
>Alan wrote:
> Doing it for fun is one thing since it'll
> practicality I doubt it'll work out too
> by enough to make a difference.
I will never replace my beloved photo-process
never-never I tell you - not over my dead
body.
However I think the EDM could/maybe/possibly
be more attractive than the inkjet if the
inkjet stuff is going to have to have all
the "steps"
Washing
Drying
Printing
Curing
Etching
EDM would have one step. Like mechanical
isolation milling does. Turn it on, go and
have a rum, come back an hour later.
EDM is meant to be an unattended process.
Reliabilty isn't anything I am scared of
with the idea either.
I would trust a well designed system to
keep running a long time. And if it does
fail - it should know how to fail gracfully.
> day
Yea but they were built by some guy over at a garage shop called epson
that builds a couple a day, and so he might have had a chance to work out
the problems. If i was building a EDM with many electrodes it would be my
first, so i think it would be best to start with one electrode instead and
actually get it to work.
ST
Do you actually do mechanical milling?
I don't, but as far as i am aware of it is far from trouble free and
working well unattended.
You get other stuff with EDM, like changing the water, caring and feeding
of electrodes, ... stuff...
ST
2006-05-03 by Codesuidae
I do. If you have some practice getting your setup right it's pretty
well unattended, presuming your equipment is reliable. If the equipment
isn't suitable to the task or tends to fail you can waste a lot of time
and materials whether you are watching it or not.
Dave K
> far from trouble free and working well
> unattended.
No - I don't do mechanincal milling. I have
compared the results of it and the time it
takes to photo. I stuck to photo.
I have seen a few people that could not get
photo to work well and thought "There has to
be a better way" and have tried milling.
Some milling shops get it to work relaibly
some don't. I would guess the ones that
don't are probably still looking for that
better way
The ones that do get it to work probably
care for thier machines and know its limits.
Hopefully the "stuff" is just once a month
maintenace like our CuCl etchant.
It needs looking after (acid/air/water)
but not every single board. Maybe the
EDM will need changing a roll of wire once
a year and replaceing water/filters once
a month. Who knows till its been running
a year :D
> out the problems.
I'm pretty sure from my dealing with
epson inkjets those guys are _realy_
yet to sort out the problems :D
Canon on the other hand - they might
almost be reliable with inkjet.
However in terms of reliabilty. Ink
jet is a LONG way down the food chain
from laser. And laser is a long way
down the food chain from impact dot
matrix with a tractor feed (if you
consider the print head a consumable)
> electrodes it would be my first,
> and actually get it to work.
Yep - First class plan. I always
learn to walk before I can run.
But *IF* one electrode gave good
results. Then two electrodes would
be faster.
And *IF* two electrodes worked -
then 32 might be a goal.
I am not saying I am competant
enough to pull it off. I sometimes
have a hard time pouring drinks
into LARGE glasses. It would be a
miracle if I could make something
that was 0.01mm wide and realiable.
:D
>day :D
Which inkjet also has 24+ independent complex mechanical systems that
have to be maintained? It's a relative PITA to keep 2 or 3 of something
like that working well. Heck took them 15 or 20 years to get inkjets
even close to right, and even now much of the rightness is simply waste
half the ink cleaning the nozzles.. They're reliable because they're
simple and fluid instead of mechanical all around..
Make you a deal, get just 6 working well for a week then you can tell
me how it is so much better than an inkjet.. :) Again, I'll expect to
hear back about it by at least 2012..
Even the 2 or 3 feeds I mentioned is problematic, but the advantage
would outweigh the extra complexity and problems of 2 or 3.
But the DISC does have the strong advantage of much more edge area for
a far lower erosion distance. It might last long enough with a decent
multiple to not need feeding over the making of a board. A stack of
copper washers on a tube, insulated and with their own supply, just scan
back and forth, when the washers have scanned to the next washer's area
just move the whole assembly. Spinning at least some to constantly
expose fresh edge and get power to each washer through the tube. I can
see something like that working far more easily than getting 24 seperate
wire feeds to cooperate for any real period of time..
Alan
>and materials whether you are watching it or not."
Um, isn't that part true of absolutely everything? Getting 24 wire
feeds to the point of not having hiccups will take a buttload of over
engineering, Jlo would be envious. And it will likely still require an
exploding goat here or there too..
My moms more reliable than your mom - was Re: PCB EDM MILL Initial Tests
> mechanical systems that have to be maintained?
They have 48 complex mechanincal systems.
Piezo electric effects are mechanical. And
their main problem is you can't maintain them
easily - you just throw them away. (which isn't
so bad 'cause they are a mass consumer item
that costs 80 cents to make the whole cartridge)
I shall refer you to the 15 page long thread
on amonia/ajax/pumping/syringing to attempt to
maintain ink jets to back up that point
The complexity of the EDM head would not be TOO
much more than an impact dot matrix. EDM has no
contact and no force on the tool head like
milling. It is not subject to great force like
an impact dot matrix even.
A spool, a clamp, a voice coil. dirt would
probably be your biggest enemy.
> something like that working well. Heck took
> them 15 or 20 years to get inkjets even close
> is simply waste half the ink cleaning the
> around..
They also HAVE to be reliable. They have to be
open-loop reliable.
An ink jet printer does not know if a nozzel is
working or not.
There is a difference between individual
component reliability, over all system
reliability and perceived reliabilty (when a
system is not smart enough to cope with small
failures and fail gracefully)
The EDM heads can have closed loop feedback and
tell when they are/have failed. If it knows a
head has failed the system could accomodate for
that failure (and maybe run at a lower speed)
I have some good books about reliability
I can lend you if you like.
> for a week then you can tell me how it is
> I'll expect to hear back about it by at
> least 2012..
I don't think I ever said I wanted to make
one myself :S
But if you want to make a valid challenge -
BET me a bottle of bundy I CAN'T do it by 2012.
Much more convincing that a glib "at least
2012" saying touchè under your breath and
thinking you've made a point.
> AK also wrote:
> Getting 24 wire feeds to the point of not
> engineering
Refer to failing gracefully comment above.
We can only hope and pray :D
(preps the goats and shivers in anticipation)
2006-05-04 by William Carr
I have a CNC machine, and the idea of leaving it unattended .... no.
2006-05-04 by cristian
I do, UNATTENDED, with positive results every time.
Cristian
2006-05-04 by Andrew
Is that a CNC milling machine for
cutting big hunks of metal - or one for
cutting little bits of GRP and copper ?
I would not leave a CNC milling machine
unattended. However the companies that
sell some of the PCB mills list that
as one of the points about having them.
2006-05-04 by roger lucas
Hi Curt,
Thanks for the info, just a couple of points
>glad to e mail a
>like.
If it is just the Garden of EDM, don't bother to send
at the moment, I have used bits of that but modded to
IPS etc.
>>However,
>use a stepper to
>through the guide
>which are
>Well Done!!
*BINGO* I have just found an ultra simple way of
integrating the electrode pinch feed with the
vibrating electrode, (without vibrating the pinch feed
mechanism). I will proto this w/e, and if it works,
I'll post a sketch.
BTW, do you have any info on the approx. erosion rate
of your 0.001 electrode. Does your electrode feed run
slowly or relatively fast? Just asking so I can
determine whether to use stepper or dc servo drive
motor.
>back of your gantry
>on dust collection.
Yes, I intend to. why reload twice.
If this vibrating electrode approach is succesful,
there is no reason why 2 (or more) electrode modules,
(spaced on the X or Y axis), could not be driven
simultaneously to produce two boards of the same
design.
For those interested, the vibrating electrode is
driven by the solenoid arrangement in an aquarium
aeration pump. Simple, cheap and very effective.
However, production item may have to be a lighter
design to increase the oscillation frequency.
Curt, many thanks for your help
Roger
them here:
SPONSORED LINKS
YAHOO! GROUPS LINKS
Terms of Service.
Send instant messages to your online friends http://uk.messenger.yahoo.com
2006-05-04 by Codesuidae
Isn't the frequency of an aquarium pump determined by the power line
frequency? In the designs I've seen its just a coil driven from the
power line pushing a magnet connected to a lever that moves a diaphragm
attached to a cavity with holes covered by small rubber flap valves.
Dave K
>the power line
>driven from the
>moves a diaphragm
>rubber flap valves.
>Dave K
Yes it is, if you connect it to the mains. However
there is nothing to stop you driving it with a
variable frequency oscillator and a high voltage audio
power module, or just a mosfet and dc. Change the
magnet to a rare earth specimen and it fairly takes
off.
The rubber diaphragm has good damping. Result =
Variable Frequency electrode for less than £10.
Connect the the EDM PIC control and you can sync the
spark discharge to the 3 axis movement.
Roger
them here:
SPONSORED LINKS
YAHOO! GROUPS LINKS
Terms of Service.
To help you stay safe and secure online, we've developed the all new Yahoo! Security Centre. http://uk.security.yahoo.com
It's a CNC machine for making signage, cutting signfoam, wood, even
brass if you use the lubricant spray.
I don't have an engraver head so I don't think I'll try doing PCB
work with it.
Re: homebrew laser plotter
2006-06-24 by roel_cnc
--- In Homebrew_PCBs@yahoogroups.com, "roel_cnc" <atmelletje@...> wrote:
> i like the idea of making me own laserplotter.
> tested: a pointerlaser (some cheap thing) with an extra focus lense, a
> red sensible film gave me super fine lines (close to a single cloth
> fiber).
> did any of us fouling around with this idea !!
> tips and suggestions always welcome:)
> gr Roel (holland)
Hi all,
M i started this toppic - got lots of replys on it with ideas :)
i gonna use Cunningfellow's pll thing
some stepper for the laser
and a dma-16 card - high speed dio card up to 250kB/s
some code compiled (TPascal)that eats the the 274 (gerber) files and
output to the drum
gr Roel
2006-06-25 by Andrew
>> with an extra focus lense, a red sensible
>> single cloth fiber).
> Roel also wrote:
> Hi all,
> on it with ideas :)
> i gonna use Cunningfellow's pll thing some
> stepper for the laser and a dma-16 card -
> high speed dio card up to 250kB/s some code
> files and output to the drum
Roel - I have done a bit more work on the PLL
thing. That one posted so far was just a test of
concept / prototype. There are a few things
un-needed and a few other things that are needed.
It was built to do some tinkering with a
commercial DC servo motor I had lying around.
I finally want to just use a DC brushed motor
with some optos ripped out of mice (to make it
easier for others to get parts to build)
Also - I was planning on getting the data out of
a USB port (via an FT232) instead of some custom
hardware in the PC (again ease to duplicate).
The FT232 can do 4 Mb (which is same ballpark to
250 KB). However if you compress the 1000dpi
data even with a simple algo like G3 fax you can
fit the data stream down 100 kilo baud (assuming
1000dpi and 10" x 10" board in 10 minutes)
I have sourced some toothed belts and linear
shafts for moving the laser head. I have also
found a source of cheapish lasers that can be
focused down to small enough dot size if I can't
find a simple repeatable solution for people to
do the same with a cheap laser pointer.
Very interested in your thoughts on the carraige
part. You seem to have a lot more experience
than I with CNC things (and PVC etch tanks). Do
you think at 1000 (or 2000) DPI that there will
be a sticktion problem? Do you think the tooth
belt idea is going to be good enough or do you
think that I might need to use a very fine pitch
leadscrew?
I have done some software on the PC to read a
BMP file compress it and send it out to my
hardware. I was just going to use and external
gerber to BMP thing. However - I have no
objections to reading geber directly if you would
like to work together on the project.
The only other though I had from the PC side
was to maybe write a GDI driver. That might be
a bit out of my league though.
andrewm (or cunningfellow to some)
2006-06-26 by Andrew
>>>>> Roel CNC wrote:
>>>>> <snip - "laser plotter anyone">
>>>> andrewm wrote:
>>>> <snip - "not a bad idea">
>>> lots of other people wrote:
>>> <snip - "how about doing it this way">
>> Roel wrote again:
>> <snip - "why the hell not">
> andrewm wrote again:
> <snip - other thoughts>
Have now investigated writing a printer driver
for windows.
There is a thing called unidrv that is quite easy
to do. You don't even realy need to do any
programming at all for simple cases.
I am going to write/make one of these and make my
laser plotter pretend to be a printer.
It makes it a bit windows bound - but I guess
thats the world we live in.
Only problems left now are the carraige and the
laser.
2006-06-26 by roel_cnc
> > Roel also wrote:
> > Hi all,
> > on it with ideas :)
lots of schematics on the net for pll that can be used i think
i was thinking to use a ldiode from a dvd burner they
can trow up to 70mw and with a good lense a super ultra thin line
> Do you think at 1000 (or 2000) DPI that there will
> leadscrew?
a lead screw for this job will be expensive i think
first touhts was to use a beld but after some thinking
a steel wire is super stiff and easy to gear
email me if you like Andrew or maybe msn its faster hey'
gr Roel
2006-06-27 by Andrew
> Roel wreto:
> can be used i think
Yep - I think the only thing there is more
schematics of on the net is propeller clocks.
> burner they can trow up to 70mw and with a
OK - They already have focus optics which
is good. But what colour are they ? I
thought they where shorter than 630nm.
1mW is pleanty for the comercial film if you
find a diode that doesnt do 70mW :D
Fine pitch brass bolt was my thought. Not
a hardend and ground zero backlas ballnut :D
> i think first touhts was to use a beld but
> after some thinking a steel wire is super
I used some stainless steel rope (from model
plain control wires) for something in the
past. The multi-stranded-ness of it made
it easy to use. It might be an idea again.
> its faster hey'
Yeah - MSN works for me.
andrewm1973 at hot-whatever
2006-06-29 by loco_labs
im building a small CNC type machine using steppers and belts to move
a dremel in 3 axis, controlled from parallel port. I will use eagle
pcb and then create a gcode file for mach3 to route the isolation.
for moving a laser diode around you will not need any torque at all,
so it would be possible to get away with using a few small stepper
motors from printers or using the assembly from flatbed scanners to
perform x and y movement. but it will be very slow.
if you google up 'orbit picstep' you will find a very nice stepper
driver that has step, direction & enable signals.
I know of UV sensitive boards, where can i get the red sensitive ones
as mentioned before?
-Michael
wrote:
> --- In Homebrew_PCBs@yahoogroups.com, "Andrew" <andrewm1973@>
> > > Roel also wrote:
> > > Hi all,
> > > on it with ideas :)
> > leadscrew?
> gr Roel
2006-06-29 by Andrew
>> Roel, Andrew and others wrote:
>> <Stuff about a drum plotter>
> steppers and belts to move a dremel in 3
> use eagle pcb and then create a gcode file
Have you tried the dremel tool to mill
fiberglass PCB ?
I beleive the speed (20K rpm or so) is a bit
slow and that they also have a bit much run
out to do a nice job of it.
The comercial machines you quite fast (60K)
low run out spindles.
Post pics when your dont though. We like to
see this kinda stuff being done.
> not need any torque at all, so it would be
> small stepper motors from printers or
> to perform x and y movement. but it will
> be very slow.
We only need a Y axis for the stepper motor.
X axis is around the drum as it spins.
Yes stepper will only need to be very small
as all it needs to move is the carraige for
the laser.
There is one thing I have no idea about and
no one else seems to have posted any
thoughts.
Am I going to have a problem with sticktion.
Sticking-Friction which is the friction that
is higher while something is at rest.
You can have a problem that you tell the
stepper to move one tiny step. The head
sticks and does not move. You tell it to
do another step. It is still stuck. You
keep giving it steps then all of a studden
it will jump X steps fwd and stick again.
You can get over sticktion by moving the
carraige back and FWD each time - but that
slows things down a bit.
15 minutes for a print is a bit slow - but
not too bad if the quality is good.
> signals.
Driving one stepper is pretty trivial so
I shall just do it out the main boards AVR
(saves people looking at me funny for using
a pic as well)
> i get the red sensitive ones as mentioned
> before?
No red sensitive boards - only film.
Use red laser to print on to film.
Develop film.
Use developed film to expose board with UV.
BTW - welcome to the group - where in OZ
are you (just in case I need to rib you if
QLD manages another 30-6 next wed night)
2006-06-30 by loco_labs
My name is Michael and im from Melbourne.
> fiberglass PCB ?
I have tried engraving with a 60degree bit into the fibreglass board
by hand and if going from the edge its likle butter, but it takes
some force to pierce the copper because the bit wasnt intended for
drilling. Im hoping the dremel will be good enough for basic smd.
as for the sticktion, one idea i had was; you see where on the older
carriages of printers/scanners they had bronze guides that slide
around a steel rod, what if there were a few holes drilled into the
bronze around the diameter and a small pump would supply some oil/air
under pressure into the holes. then the fluid should slowly leak out
around the rod and hopefully it floats on a pillow of oil. or even
pressurised air.
I have seen some precision grinders that used air compressor for
frictionless bearing.
problem is its easier said than done.
And when i get some time ill sort out my progress and put it on the
internet for all to see.
-cheers
2006-07-02 by Andrew
>"loco_labs" wrote:
> <snip>
> see where on the older carriages of printers/
> holes drilled into the bronze around the
> oil/air under pressure into the holes. then
> the fluid should slowly leak out around the
> oil. or even pressurised air.
> <snip>
I was considering air bearings for a little while
(the big 50 thousand dollar plotters use them)
But decided it sounds like a lot of trouble
unless I find out a simpler solution won't work.
2006-07-17 by David Cureton
Did i miss something? Are there any links to photos of the results.
David
> neccessary).
> of the wire dia.
> raster yet).
> Roger
> ___________________________________________________________
> ** ACCEPT: CRM114 PASS Markovian Matcher **
> CLASSIFY succeeds; success probability: 1.0000 pR: 69.2692
> Best match to file #0 (nonspam.css) prob: 1.0000 pR: 69.2692
> Total features in input file: 5621
> #0 (nonspam.css): features: 1574864, hits: 168951, prob: 1.00e+00, pR: 69.27
> #1 (spam.css): features: 700736, hits: 79657, prob: 5.38e-70, pR: -69.27
> -=-Extra Stuff-=-
> From sentto-4505361-14046-1146586123-yahoo=dcureton.com@... Wed May 03 02:09:25 2006
> Return-path: <sentto-4505361-14046-1146586123-yahoo=dcureton.com@...>
> Envelope-to: yahoo@...
> Delivery-date: Wed, 03 May 2006 02:09:25 +1000
> Received: from n16a.bullet.scd.yahoo.com ([66.94.237.45])
> by whitetail with smtp (Exim 4.50)
> id 1FaxRE-0001NB-O5
> for yahoo@...; Wed, 03 May 2006 02:09:25 +1000
> Comment: DomainKeys? See http://antispam.yahoo.com/domainkeys
> DomainKey-Signature: a=rsa-sha1; q=dns; c=nofws; s=lima; d=yahoogroups.com;
> b=Deo1r8Ca+ejr1GQGHFZDSS1S34fOlWbQd4wm9Xos6yJIVm6p8WvXAr2mUZ/RhXmB/a6A/tbLoiQ9VXVaM3t1vHq1Sk+YyfALAKxRt/ePyVI0NAzh37/VGKyftBT/PKTH;
> Received: from [66.218.69.5] by n16.bullet.scd.yahoo.com with NNFMP; 02 May 2006 16:08:52 -0000
> Received: from [66.218.66.36] by t5.bullet.scd.yahoo.com with NNFMP; 02 May 2006 16:08:52 -0000
> X-Yahoo-Newman-Property: groups-email
> X-Yahoo-Newman-Id: 4505361-m14046
> X-Sender: ralucas4277@...
> X-Apparently-To: Homebrew_PCBs@yahoogroups.com
> Received: (qmail 5150 invoked from network); 2 May 2006 16:08:23 -0000
> Received: from unknown (66.218.66.166)
> by m30.grp.scd.yahoo.com with QMQP; 2 May 2006 16:08:23 -0000
> Received: from unknown (HELO web25911.mail.ukl.yahoo.com) (217.146.176.249)
> by mta5.grp.scd.yahoo.com with SMTP; 2 May 2006 16:08:22 -0000
> Received: (qmail 56193 invoked by uid 60001); 2 May 2006 16:07:20 -0000
> Message-ID: <20060502160720.56191.qmail@...>
> Received: from [195.93.21.34] by web25911.mail.ukl.yahoo.com via HTTP; Tue, 02 May 2006 17:07:19 BST
> In-Reply-To: <20060502150532.7175.qmail@...>
> X-Originating-IP: 217.146.176.249
> X-eGroups-Msg-Info: 1:0:0:0
> From: roger lucas <ralucas4277@...>
> X-Yahoo-Profile: ralucas4277
> Sender: Homebrew_PCBs@yahoogroups.com
> MIME-Version: 1.0
> Mailing-List: list Homebrew_PCBs@yahoogroups.com; contact Homebrew_PCBs-owner@yahoogroups.com
> Delivered-To: mailing list Homebrew_PCBs@yahoogroups.com
> List-Id: <Homebrew_PCBs.yahoogroups.com>
> Precedence: bulk
> List-Unsubscribe: <mailto:Homebrew_PCBs-unsubscribe@yahoogroups.com>
> Date: Tue, 2 May 2006 17:07:19 +0100 (BST)
> Subject: [Homebrew_PCBs] PCB EDM MILL Initial Tests
> Reply-To: Homebrew_PCBs@yahoogroups.com
> Content-Type: text/plain; charset=ISO-8859-1
> Content-Transfer-Encoding: 8bit
> neccessary).
> of the wire dia.
> raster yet).
> dynamic
> -0-0-0-
2006-07-17 by Cristian
> . I think
> > Roger
Roger, it works, for sure at the beginning, when there are enough copper
to create the opposite polarity/electrode, but how you manage to fire
the last sparks,
when there are no more connection to the opposite polarity/electrode?
Are you advancing line by line in horizontal lines?
Could you explain your bmp to Machine software?
Cristian
update - Re: homebrew laser plotter
2006-09-09 by Andrew
An update for anyone interested.
First posted in June or there abouts my
intent to make a photoplotter along the
lines of the one John Elson did.
Said at the time I would probably take
about six months to get it done.
Well - I am about 1/2 way along my time
line and in light of other comments
around I thought I should give everyone
an update.
From the outset the plan has been to make
the whole thing with simple technology
and to do an RTFM build document on it so
anyone else can make one.
So far I have built a board that has all
that was needed to control a servo motor
and create a pixel clock. (the prototype
shown in the files section). Along with
this the CPU that created the pixel
stream (not shown in files section yet)
has been built.
Next step/goal was to get it all
comunicating with the computer. Originaly
was going to make it terminal driven and
to x-modem the plotter a TIFF file. The
hope here was to make it platform
independant. This turned out to be a
stupid idea. The TIFF standard does not
guarantee linear files :(
After giving up that idea someone pointed
me in the direction of windows Miniport
drivers.
They are very simple to make and I now
have the electonics of the photoplotter
pretending to be a normal laser printer
to any windows machine. if anyone ever
needs to do anything similar I recomend
that path.
Tasks still to complete are
1, Laser driving circuit
2, Mechanics of the drum
3, Mechaincs of the carraige
I hope to have these finished some time
soon.
NB soon is a relative term - I published
some of my first RTFM builds well over 10
years ago when I was still a teenager. If
you go and look at them on the wayback
machine I still am promising to do the
NTSC version of one of those projects
"soon" :D
