RE: Cheap rotary tools at Harbor Freight
2006-01-21 by Ted Bruce
I'm still using the same two reconditioned HF bits
from their $9.95 box of bits package.  Over 600 holes
drilled so far.
Based on the comment as to how best to cut PC board
material, I'm looking at their $59.99 4" wet tile saw
with diamond blade.  I have their sheet metal brake
and one of the famous circular punches, and I'm
satisfied with the quality.
Ted Bruce KX4OM
Do You Yahoo!?
http://mail.yahoo.com
Re: Cheap rotary tools at Harbor Freight
2006-01-22 by alan00463
> drilled so far.
> Ted Bruce KX4OM
Let us know how that works on PC board.   Now that you men-
tioned it, I think I will see about getting a diamond blade
for my table saw to cut PC board.
Alan
2006-01-22 by kilocycles
Alan,
Now that you mention it, I have a saw table I haven't used in years
that mounts a regular 7 - 7/14-in circular saw.  The carbide blades
for those saws are pretty thick, since their application is not
usually fine finish work, but I haven't investigated diamond blades.
The diamond-edge tile saws are made to cut ceramic material, so I
figure they'll do pretty well on fiberglass-epoxy.
The reground router bits I use are carbide, and they have no problem
at all with the PC boards.  In the meantime, I quickly dulled two
regular Dremel "hobby" bits drilling the stuff.  The downside to the
box of 40 reground bit deals is that there are only 4 or five sizes
that I'd ever use, at least for PC boards.  Still, they're very
economical when on sale.
Ted
> > drilled so far.
> > Ted Bruce KX4OM
> Alan
--- In Homebrew_PCBs@yahoogroups.com, "kilocycles" <kilocycles@y...>
wrote:
> Alan,
> Ted
Yes, that would work fine, I'd think.   How about the score-n-snap
method, i.e. score with a razor-knife and a metal straitedge, then
snap it on the edge of a table ?
Has anybody been successful using this technique on fiberglass-epoxy?
I always like to try the simplest way first.
Alan
Re: [Homebrew_PCBs] Re: Cheap rotary tools at Harbor Freight
2006-01-22 by David P Harris
Different methods work, I have used successfully: a heavy duty paper
guillotine and a sheet metal shear.
There are small relatively inexpensive shears available.
The other recommended method is to use a water-cooled tile saw --- again
relatively inexpensive, the water captures most of the dust.
I have also used a abrasive cutting disk on a dremel -- poor cut and
very messy.  Table saw -- messy.  The dust is relatively toxic, so this
is a poor method.
David
2006-01-22 by Leon Heller
Sent: Sunday, January 22, 2006 5:49 PM
Subject: [Homebrew_PCBs] Re: Cheap rotary tools at Harbor Freight
> wrote:
>> Alan,
>> Ted
That's what I do. I use a Stanley knife, it works very well.
Leon
[This E-mail has been scanned for viruses but it is your responsibility
to maintain up to date anti virus software on the device that you are
currently using to read this email. ]
Power Tools for cutting PCBs-Was: Re: Cheap rotary tools at Harbor Freight
2006-01-23 by kilocycles
> wrote:
> > Alan,
---snip---
> > Ted
> Alan
Well, some of the stuff I do falls under the "Homebrew_PCBs" topic,
but it's not related to printing and etching.  For example, I need to
make four 2 x 8 inch pieces, with two 2 x 2 pieces for the ends, of
double-sided board to make a box for resistive decade box, soldering
the box edges.  So, I need to be pretty accurate with my edges.  I've
made some small boxes using sheet metal shears.  I really don't know
if I can score and snap a good edge with double-sided FR4 epoxy board.
I recently made a smaller box for an RF filter of the same form factor
out of precut brass sheets from Ace Hardware, but it's more difficult
to solder, and it turned out...well, butt-ugly!  They also carry thin
brass angle stock, so maybe I'll just use screws instead of solering
the edges.
Long term, I do need the ability to cut PCB stock accurately, not only
for the boxes, but also to make my PCBs a bit more square than I've
been able to do with the shears.  I also have a combo router
table-sabre saw table I haven't used in awhile, and it has a sliding
push-guide.  If one of the fine-tooth sabre saw blades can do the
double-sided copper without ripping it up along the edges, that will
be good.  I'll try that first and report back to the group.
Cheers,
Ted
2006-01-24 by Ben
Table Saw or a Sheet Metal Shear are the best ways that I have found.
I have used a Table Saw with a Dry/Wet Diamond blade, Table saw is a
10" but Diamond blade is a 7 1/4",  also a fine tooth Carbide blade
should work good but will have a wider Kerf.  For the board sizes you
listed one of the small bench models should work for you.
If you use your Table Saw to cut PCB material be sure and have a good
vacuum system on it for dust collection and also put a filter on the
motor's air intake.  On the motor air intake I used a cloth type
filter for a shop vac, and be sure and clean it.
Currently I use a Kepro shear that I picked up on Ebay at a good
price, you can also get a sheet metal shear which is really what the
Kepro shear is.
Also the Wet tile saws with a diamond blade should work, also guess
would help keep the dust down.
Ben
Re: [Homebrew_PCBs] Power Tools for cutting PCBs-Was: Re: Cheap rotary tools at Harbor Freight
2006-01-24 by Evan Dudzik
I have a small table saw that I use, i got it on ebay for about $40.  It's
just a very small saw, uses a 4" or 4-1/2" blade (can't remember), the blade
that came with it is a simple carbide-tooth blade, and it's worked fine,
with no signs of dulling after a lot of cutting.  It's loud, and like any
table saw there's always that risk of getting your finger in the blade, but
it makes very fast, perfect cuts, no rough edges or anything.
I generally set it in a shallow box to catch the shavings/dust.
-Evan
> Kepro shear is.
> Ben
> Photos:
2006-01-25 by dl5012
I use this 8" shear from Harbor Freight
(http://www.harborfreight.com/cpi/ctaf/displayitem.taf?
Itemnumber=90757).  Works great if your material is under 8" in one
direction.  It costs $125, but it's a lot easier than the methods I
tried before (jig saw, hack saw, mitre saw, power mitre saw, utility
knife, utility cutter (one of those Sears tools that will cut garden
hoses), and metal cutters/snips).
If you buy one, watch out for cutter alignment.  Mine wasn't adjusted
correctly and I could have damaged it if I hadn't noticed...
Dennis
board.
