Milled boards
2005-12-24 by crankorgan
2005-12-25 by James Washer
> From Eagle to a finished board in less than 1 hour each.
> Drilled,Sanded and Cut
> http://crankorgan.com/perfchop7.JPG
> Parts added
> http://crankorgan.com/perfchop9.JPG
2005-12-25 by cristian
2005-12-25 by crankorgan
--- In Homebrew_PCBs@yahoogroups.com, cristian <cristianbip@b...> wrote:
> If you will design square or rectangle pads and will add square to each
> track's corner, the CNC
> will spend less time to mill (only X and Y movement instead of arcs).
> Cristian
--- In Homebrew_PCBs@yahoogroups.com, James Washer <washer@t...> wrote:
> Nice job John.
> Can you answer a few questions for me? How does one get from an
Eagle "brd" to whatever CNC instructions (or whatever they are called,
I don't know anything about CNC, sorry).
> What kind of a mill are you using?
> On Sat, 24 Dec 2005 13:17:38 -0000
> > Parts added
and Photos:
> > Yahoo! Groups Links
> http://mynock.dhs.org/pcbmilling/
> > Nice job John.
> > > Parts added
> and Photos:
> > > Yahoo! Groups Links
> Two questions
> 1) Is it "reasonable" to mill double sided boards?
> 2) Will Eagle(and scripts) provide code to do the drilling (I'd
assume so, but I don't like to make assumptions)
> - jim
> On Sun, 25 Dec 2005 12:43:28 -0000
wrote:
> > > Nice job John.
> > > > Parts added
> > and Photos:
> > > > Yahoo! Groups Links
and Photos:
> > Yahoo! Groups Links
2005-12-25 by Dale Mosby
> Two side is done using two register pins. The problem is you will
> have to add jumpers to make connections from one side of the board to
> the other. With a little thought you can make most boards single
> sided. If you let Eagle route your boards you will get double sided
> boards 9 out of 10 times.
> > Two questions
> > - jim
> wrote:
> > > > Nice job John.
> > > > > Parts added
> > > and Photos:
> > > > > Yahoo! Groups Links
> and Photos:
> > > Yahoo! Groups Links
> The idea of being able to use a cnc mill to create two sided boards
> looks great. Before investing in this technology I would like to
> observe the process. Is anyone in the greater Portland, Oregon or
> Vancouver, Washington metro area using a mill to cut and drill two
> sided boards?
> Thanks, Dale daleatarchcapedotcom
2005-12-26 by CNCQuest
Sent: Monday, December 26, 2005 2:40 AM
Subject: [Homebrew_PCBs] Re: Milled boards
2005-12-26 by crankorgan
--- In Homebrew_PCBs@yahoogroups.com, "CNCQuest" <pharmapack@s...> wrote:
> Eagle does allow you to auto route on one side of the board only. By
> indicated "N/A" in the top side under "Autorouter Setup", you will
then have
> "Autoroute" on the bottom side only.
> From: "crankorgan" <john@k...>
> Yes, I understand the need to arrange for either jumpers or "rivets"
from one side to another. Thanks
> On Sun, 25 Dec 2005 18:40:31 -0000
wrote:
> > > Two questions
> > > - jim
> > wrote:
> > > > > Nice job John.
called,
> > > > > > Parts added
Files,
> > > > and Photos:
> > > > > > Yahoo! Groups Links
> > and Photos:
> > > > Yahoo! Groups Links
and Photos:
> > Yahoo! Groups Links
2005-12-26 by James Washer
> I use jumbers or the resistors themselves to make a jump so I
> don't need a double sided board.
> wrote:
> > > > Two questions
> > > > - jim
> > > wrote:
> > > > > > Nice job John.
> called,
> > > > > > > Parts added
> Files,
> > > > > and Photos:
> > > > > > > Yahoo! Groups Links
> > > and Photos:
> > > > > Yahoo! Groups Links
> and Photos:
> > > Yahoo! Groups Links
Sent: Monday, December 26, 2005 10:57 AM
> In the case of designing a Stepper Chopper board, autorouting is
> useless. Certain traces have to be run certain ways. Autorouting works
> great for digital only circuits. But don't use it for audio and RF
> circuit unless you want extra noise or oscillations.
> then have
> Photos:
2005-12-28 by Kevin Morgan
to
wrote:
> > Two questions
> > - jim
> wrote:
> > > > Nice job John.
an
called,
> > > > > Parts added
Files,
> > > and Photos:
here:
> > > > > Yahoo! Groups Links
> and Photos:
> > > Yahoo! Groups Links
