Tinning the board?
2005-11-20 by Jim Miller
How do folks here tin their boards after they're etched? tnx jim [Non-text portions of this message have been removed]
2005-11-20 by Stefan Trethan
On Sun, 20 Nov 2005 18:54:47 +0100, Jim Miller <jim@...> wrote: > How do folks here tin their boards after they're etched? > > > tnx > > jim There was a discussion about using paint-on plumbers soldering paste a while ago, which works really well i must say. ST
Hi, while we are at the subject, i want to buy some paste for this application. I have tried it with old (lead) paste and it works well, but i don't feel comfortable with the disposal problem (as some of the paste is washed off). Also i hope for a nicer finish with tin paste. I have the choice of: ROSOL 1S S-Sn96,Ag4 250g 15eur ROSOL 3 S-Sn97,Cu3 250g 10eur Now what is the difference between paste with copper and paste with silver? I don't really mind the price since it will go a long way. I remember some leadfree solder (wire) has silver in it too? Anyone doing the tinning, what paste is yours? Thanks! ST
2005-11-20 by Mike Young
I use Tinnit. The only drawback is having to keep it warmer than 120 deg. F in use. It precipitates into a white goo when it's cold. ----- Original Message -----
From: "Jim Miller" <jim@...> To: <Homebrew_PCBs@yahoogroups.com> Sent: Sunday, November 20, 2005 11:54 AM Subject: [Homebrew_PCBs] Tinning the board? > How do folks here tin their boards after they're etched?
Now I'm really curious if you can just stick on the SMT packages at the same time. Would you use that paste without a solder mask? just slather it on like peanut butter? Here's a link to some SynTech products. It's not nearly as pricey as I thought it would be. http://www.stencilsunlimited.com/solder_products.php?source=google ----- Original Message ----- From: "Stefan Trethan" <stefan_trethan@...> To: <Homebrew_PCBs@yahoogroups.com> Sent: Sunday, November 20, 2005 12:44 PM Subject: [Homebrew_PCBs] Tinning the board? silver/tin solder or copper/tin solder?
> Hi, > > while we are at the subject, i want to buy some paste for this > application. I have tried it with old (lead) paste and it works well, but > i don't feel comfortable with the disposal problem (as some of the paste > is washed off). Also i hope for a nicer finish with tin paste. > > I have the choice of: > > ROSOL 1S S-Sn96,Ag4 250g 15eur > > ROSOL 3 S-Sn97,Cu3 250g 10eur
On Sun, 20 Nov 2005 20:05:59 +0100, Mike Young <mikewhy@...> wrote: > Now I'm really curious if you can just stick on the SMT packages at the > same > > time. Would you use that paste without a solder mask? just slather it on > > like peanut butter? > > > Here's a link to some SynTech products. It's not nearly as pricey as I > > thought it would be. > > > http://www.stencilsunlimited.com/solder_products.php?source=google That's really rather cheap, compared to the usual prices for SMD paste sold in syringes. I'm not sure about the smd at the same time, you want to wash off the paste that was painted on the etched parts after reflow. So if you already have SMDs there it might be impossible to get it out from under them. With the smaller parts it would probably wick away, but with the larger ones probably not. Anyway you need to make larger "mounds" on the smd pads, so you don't really add work if you make it in two stages. What i currently wonder about is component legend. Not sure if i can transfer on solder, but i guess so. ST
2005-11-21 by pebo festus
jim- read message 10103- the dealer is mcmaster.com mebo --- Jim Miller <jim@...> wrote: > How do folks here tin their boards after they're > etched? > > tnx > jim > > [Non-text portions of this message have been > removed] > > __________________________________ Yahoo! Mail - PC Magazine Editors' Choice 2005 http://mail.yahoo.com
2005-11-21 by Mike Young
From: "Stefan Trethan" <stefan_trethan@...> > I have the choice of: > > ROSOL 1S S-Sn96,Ag4 250g 15eur > > ROSOL 3 S-Sn97,Cu3 250g 10eur > > Now what is the difference between paste with copper and paste with > silver? I don't really mind the price since it will go a long way. > I remember some leadfree solder (wire) has silver in it too? It's too late in the day for hard science, but here's the reader's digest version. Eutectic tin (liquidus, or molten, that is) alloys freely with many metals, including silver. Adding silver to the solder reduces the silver taken from the solderee in the intermetallic layer formed during soldering. Sn96Ag4 also melts at a higher temperature than Sn63Pb37. This is useful for reflowing boards with components on both sides. The first side is reflowed at a high temp profile using tin/silver. The second side is then populated and reflowed with a suitable paste on a lower temp profile. If lead-free is a concern (one presumes it is), tin/copper melts about 20^C lower than tin/silver, 220^C versus 240^C; tin/bismuth/silver is lower still. The more familiar tin/lead melts at about 180^C, much lower than any of the lead-free alloys. Since the mechanical or electrical properties aren't the major concern for choosing between the two, tin/copper would work as well or better than tin/silver for our use. For that matter, I'm still using Kester 44. Just ordered another 1/2 lb., in fact. Nothing wets as well as that old crap.
2005-11-21 by Ron
> > I have the choice of: > > > > ROSOL 1S S-Sn96,Ag4 250g 15eur > > > > ROSOL 3 S-Sn97,Cu3 250g 10eur > > > > Now what is the difference between paste with copper and paste with > > silver? I don't really mind the price since it will go a long way. > > I remember some leadfree solder (wire) has silver in it too? > Apart from the melting points, one of the things that has me really concerned is tin pest. For most projects its probably not a big issue, as few will see the outdoors or temperatures much below room temperature. I would tend to think that either of those solders would be subject to failure if exposed to low temperature (below 13 deg C) due to tin pest. The silver version might be a bit better than the tin copper version. Ron
2005-11-21 by JanRwl@AOL.COM
In a message dated 11/20/2005 12:21:12 P.M. Central Standard Time, jim@... writes: How do folks here tin their boards after they're etched?<< Normally, one "tins" the desired pattern on the copper, then uses an etchant that attacks copper, but NOT tin/lead, so the pre-tinned tracks and pads stay. But a solution made of a solid called "Tinnit" by one of the mailorder PCB-stuff firms will "electrolessly tin" ANY copper dipped in it (per instructions). I do NOT know how the pro-houses "solder-plate" the pattern on bare copper, if this is electroless or done with DC power. Somebody? [Non-text portions of this message have been removed]
2005-11-21 by ballendo
Tinnit. Works fine, is simple, and cheap. About 4 bucks. Hope this helps, Ballendo P.S. Circuit Specialists sells it; among many others. --- In Homebrew_PCBs@yahoogroups.com, "Jim Miller" <jim@j...> wrote:
> > How do folks here tin their boards after they're etched? > > tnx > jim > > [Non-text portions of this message have been removed] >
2005-11-21 by pinoy_nyc@yahoo.com
Hello to All, How can I create a mechanically etch style PCB? Can I do this using eagle? I'm still going to use Ferric Chloride to etch it, but I want the mechanically etch style... any recommendations or suggestions? More power to this group. --------------------------------- Yahoo! FareChase - Search multiple travel sites in one click. [Non-text portions of this message have been removed]
2005-11-21 by David Griffith
On Mon, 21 Nov 2005, Ron wrote: > Apart from the melting points, one of the things that has me really > concerned is tin pest. For most projects its probably not a big issue, > as few will see the outdoors or temperatures much below room > temperature. I would tend to think that either of those solders would > be subject to failure if exposed to low temperature (below 13 deg C) > due to tin pest. The silver version might be a bit better than the tin > copper version. Tin whiskers also concern me, especially as more of us delve into surface-mount components for our homebrews. -- David Griffith dgriffi@...
From: <JanRwl@...> > instructions). I do NOT know how the pro-houses "solder-plate" the > pattern on bare > copper, if this is electroless or done with DC power. Somebody? Reading Think and Tinker's gives one the notion they can do this (almost) easily at home. Plating is deposited by electroplating at about 20A/sq.ft. Copper, bright tin, and solder are the typical platings, and differ only in the anode bars and electrolyte. For the small boards that I do, I think I can easily manage a DC supply to source 5A into the 20'ish milliohms in the bath. Some evening this week, I think I'll have a walkabout through WalMart and see what tubs are easily available for making into plating baths. I think a wallpaper wetting trough might be too long, but perhaps there'll be something the right size in the garden center. Actually, a rectangular tupperware thing with a tight fitting lid will be ideal, I think.
From: <pinoy_nyc@...> To: <Homebrew_PCBs@yahoogroups.com> Sent: Sunday, November 20, 2005 11:46 PM Subject: [Homebrew_PCBs] Mechanically Etch Style > How can I create a mechanically etch style PCB? > Can I do this using eagle? > > I'm still going to use Ferric Chloride to etch it, but I want the > mechanically etch style... any recommendations or suggestions? Isolation etching? Dunno. Some of the guys reported doing so with Proteus. Do let me know if you find out how to do this in Eagle.
Hi Mike, Oh I see, it's isolation etching. Thanks. I just tried experimenting with photoshop and able to produce it Isolation etching in about 30 seconds from the original eagle board image. what I did is select all the non copper area (black color) and contract the selection into 8 pixels. by doing Select->Modify->Contract and the flooding the selection with white. It looks ok though... I'm sure somebody has tried this before, and they may have a better idea. Mike Young <mikewhy@...> wrote:
Be sure to visit the group home and check for new Links, Files, and Photos:
http://groups.yahoo.com/group/Homebrew_PCBs
If Files or Photos are running short of space, post them here:
http://groups.yahoo.com/group/Homebrew_PCBs_Archives/
YAHOO! GROUPS LINKS
Visit your group "Homebrew_PCBs" on the web.
Homebrew_PCBs-unsubscribe@yahoogroups.com
[Non-text portions of this message have been removed]2005-11-21 by Mike Young
Excellent! Post process the image. :) I'll give the magic wand a swing or two this evening, too. 8 pixels is probably just right for 600 dpi, a touch more than 13 mil. I might go a bit more generous on the bus side. ----- Original Message -----
From: <pinoy_nyc@...> To: <Homebrew_PCBs@yahoogroups.com> Sent: Monday, November 21, 2005 8:56 AM Subject: Re: [Homebrew_PCBs] Mechanically Etch Style > Hi Mike, > > Oh I see, it's isolation etching. Thanks. > > I just tried experimenting with photoshop and able to produce it > Isolation etching in > about 30 seconds from the original eagle board image. > what I did is select all the non copper area (black color) and contract > the selection > into 8 pixels. by doing Select->Modify->Contract and the flooding the > selection with > white. It looks ok though...
2005-11-22 by pinoy_nyc@yahoo.com
Here's the procedure using Photoshop
1.) Load the board image
2.) select magic wand - make sure anti-alias & contigous is disabled.
3.) click/select the black color (non copper area)
this will select all the black color since contigous option is disabled.
4.) contract the selection/marque to 5 pixels.
From Menu: Select->Modify->Contract, then choose 5.
5.) Hit del key, to delete the selection/marque.
6.) Now etch the PCB with your favorite solution.
STEP 1.) *** THE ORIGINAL BOARD FROM EAGLE ****
STEP 4.) **** LOADED INTO PHOTOSHOP, MARQUE SELECTED AND CONTRACTED TO 5 PIXELS ***
STEP 5.) *** DONE!!!! *** ISOLATED TRACES READY TO BE ETCH ***
might go a bit more generous on the bus side.----- Original Message -----
> Hi Mike,
> the selection
> selection with
SPONSORED LINKS
Electrical engineering degree online Electrical engineering degree Printed circuit board Electrical engineering Electrical engineering course Electrical engineering graduate school
YAHOO! GROUPS LINKS
[Non-text portions of this message have been removed]2005-11-22 by pinoy_nyc@yahoo.com
WOOT!... the 3 images didn't attached succesfully...
I've uploaded the 3 images, pls see
Photo Section - ISOLATED ETCHING - TIPS & TRICKS
- PHOTO SECTION LINK -
> Hi Mike,
> the selection
> selection with
SPONSORED LINKS
YAHOO! GROUPS LINKS
SPONSORED LINKS
YAHOO! GROUPS LINKS
[Non-text portions of this message have been removed]2005-11-22 by Stefan Trethan
On Tue, 22 Nov 2005 04:57:40 +0100, pinoy_nyc@... <pinoy_nyc@...> wrote: > WOOT!... the 3 images didn't attached succesfully... > > I've uploaded the 3 images, pls see > > > Photo Section - ISOLATED ETCHING - TIPS & TRICKS > > > - PHOTO SECTION LINK - > That's a cool way of making a copper pour, not every PCB software can do it and it might be a solotion for those... ST
2005-11-22 by Dave
--- In Homebrew_PCBs@yahoogroups.com, "Jim Miller" <jim@j...> wrote: > > How do folks here tin their boards after they're etched? > > tnx > jim > > [Non-text portions of this message have been removed] Years ago, I used to use an electroless Tin plating solution based on Stannous Chloride, Sodium Hydroxide, and Sodium Cyanide. It produced a beautiful plating, but was a bit of a pain to work with. If you left it exposed to air, it would oxidize fairly quickly. If you splashed in a bit of acid, it would evolve Cynaide gas, which would rapidly kill everyone in the room. If you didn't have the temperature quite right, it wouldn't give you a good plating. I've since given up on it, and usually just solder the boards now. Dave
On Tue, 22 Nov 2005 16:40:51 +0100, Dave <wa4qal@...> wrote: > Years ago, I used to use an electroless Tin plating solution > > based on Stannous Chloride, Sodium Hydroxide, and Sodium Cyanide. > > It produced a beautiful plating, but was a bit of a pain to work > > with. If you left it exposed to air, it would oxidize fairly > > quickly. If you splashed in a bit of acid, it would evolve > > Cynaide gas, which would rapidly kill everyone in the room. > > If you didn't have the temperature quite right, it wouldn't > > give you a good plating. > > > I've since given up on it, and usually just solder the boards > > now. > > > Dave > The current electroless solutions aren't that much better, containing thiurea which is a known carcinogenic substance. ST
