Fairlight-CMI
Index last updated: 2026-04-29 00:03 UTC
5-pin XLR VDU cables
2010-06-09 by tama_rat
Hello All,
There does seem to be interest in ready-made 5-pin XLR cables for the mouse/lightpen interface, so I've been looking into the costs for building them.
It's a custom cable, so they aren't an off-the-shelf item.  They aren't too hard to make -- if you've made audio/video/computer cables before, you could probably make your own.
I used a cable with 3 mini coax cables, very similar to what is in my original Fairlight VDU cable, to make mine.  Most such coax cables have an outer diameter > 0.4", which is too big for the boot on the XLR connectors (typically has a max diameter of .31").  I've found some cable from Covid with an outer diameter of .26" (CVD 3300) which works well.
If you want one of these cables, I can offer them for $50 with the interface.  I think they will be about 1m (3 feet) long, maybe a little longer.
If you're just planning to use the RCA output with a modern monitor, you don't need it.  For that you'll just need a composite video cable (RCA male/male).
If you would like one of these cables, please let me know so I can plan for buying connectors and cable.
Joe
