Doepfer
A132-4 hot output signal
2014-11-30 by sj230962@gmail.com
Got my A132-4 last week and just wanted to check something with you knowledgeable folks.
I ws feeding output from A140 ADSR into CV,1 audio in from filter, out to external mixer. The output was *really* hot (loud). I had to route the signal via the attenuator module to keep it workable even with the faders turned almost to zero.
1. if I'm feeding in ADSR output on a regular basis, should I trim the potentiometer to handle 8V as suggested in the manual ? (yes, I did RTFM..haha).
2. Is it easier to route the A140 output via the A183-2 to attenuate the CV first before feeding into CV1 on A132-4 ?
I'm learning all the time, so appreciate the help.
Steve
AW: [Doepfer_a100] A132-4 hot output signal
2014-12-01 by yahoo@doepfer.de
> Steve
Yes adjust the trimming potentiometer for CV1 so that the desired max. level is obtained. The factory setting 5V for amplification
1. With this setting and 8V CV you will obtain a very high level (probably even clipping).
Best wishes
Dieter Doepfer
