Doepfer
Dual Ring Modulator A-114 on lfo question
Re: [Doepfer_a100] Dual Ring Modulator A-114 on lfo question
2014-10-10 by achtung_999
I just tested for you... It does not respond very well to slow voltages for what I could hear in a quick 3 min. test...
Ernst
On Fri, Oct 10, 2014 at 10:25 PM, Dennis Verschoor modular@gmail.com [Doepfer_a100] <Doepfer_a100@yahoogroups.com> wrote:
Hello.
Does the A-114 works well on slow lfo singals?
Or are there caps which need to be bypassed for this purpose?
Cheers,
Dennis
Re: Dual Ring Modulator A-114 on lfo question
2014-10-11 by Dennis Verschoor
Thanks for the test.
My guess is that there are cappacitors on the inputs filtering dc.
But maybe Dieter can tell about it.
On Saturday, 11 October 2014, achtung_999 heinrich.himmelwasser@gmail.com [Doepfer_a100] <Doepfer_a100@yahoogroups.com> wrote:
Ernst
Hello.
Cheers,
Dennis
Music at: http://www.mono-poly.nl
Re: [Doepfer_a100] Re: Dual Ring Modulator A-114 on lfo question
2014-10-11 by Martin Fay
The A-133 is a DC coupled multiplier, works as a ring modulator for
audio and is really quite a handy utility module in general. In
modulation terms it can be thought of as an inverting attenuator with
CV control. It will substitute for a VCA, though where zeroing isn't
important.
Search for Navs modular blog A-133 for a full article on it.
Martin
On 11 Oct 2014, at 08:09, "Dennis Verschoor modular@gmail.com
> Ernst
> Hello.
> Cheers,
> Dennis
AW: [Doepfer_a100] Dual Ring Modulator A-114 on lfo question
2014-10-13 by yahoo@doepfer.de
> Hello.
> Cheers,
> Dennis
No, the A-114 works only down to about 50Hz. You may replace the capacitors.
But this will only reduce the lowest frequency. You will nevery obtain DC
coupling. But the A-133 can probably do the job. It is DC coupled.
Best wishes
Dieter Doepfer
2014-10-13 by achtung_999
And adding to Dieter's comments: I managed to get the same sound from my A133 as I got from my A114. Totally possible with the right settings.
Ernst
On Mon, Oct 13, 2014 at 9:52 AM, yahoo@doepfer.de [Doepfer_a100] <Doepfer_a100@yahoogroups.com> wrote:
> Hello.
> Cheers,
> Dennis
Best wishes
Dieter Doepfer
Yahoo Groups Links
<*> To visit your group on the web, go to:
http://groups.yahoo.com/group/Doepfer_a100/
<*> Your email settings:
Individual Email | Traditional
<*> To change settings online go to:
http://groups.yahoo.com/group/Doepfer_a100/join
(Yahoo! ID required)
Doepfer_a100-digest@yahoogroups.com
Doepfer_a100-fullfeatured@yahoogroups.com
<*> To unsubscribe from this group, send an email to:
Doepfer_a100-unsubscribe@yahoogroups.com
<*> Your use of Yahoo Groups is subject to:
https://info.yahoo.com/legal/us/yahoo/utos/terms/
