Thanks for the explanation Dieter, time to play now...??
Have a nice evening,
Danny Budts
info@syndromeda.be
www.syndromeda.be
----- Oorspronkelijk bericht -----
Van: yahoo@doepfer.de [Doepfer_a100] <Doepfer_a100@yahoogroups.com>
Aan: Doepfer a100 <Doepfer_a100@yahoogroups.com>
Verzonden: Thu, 25 Sep 2014 19:18:38 +0200 (CEST)
Onderwerp: AW: [Doepfer_a100] A-127 BOM
> Hi Dieter,
> I have just received my A-127 BOM today and I found out something
> misleading. The short manual says the stand factory setting for
> jumpers J2-4-6 are on bandpass, so on the lower row, the two left
> contacts,looking at page 3, but the jumpers on mine are on the
> lower row, the two right contacts. As i can see on the picture on
> page 5, I suppose the jumper is also on the right contact; Now
> what is right, this is confusing, do I leave them on the under
> right contacts or shall I put them on the under left contacts?
> Cheers,
> Danny Budts
> info@syndromeda.be
> www.syndromeda.be
I took a look at the document and it seems to be correct. If the jumper is
installed in the lower row of JP2-4-6 to the position towards the edge of
the pcb bandpass should be selected. Seems that the module came with the
jumpers on JP2-4-6 installed for highpass and not for bandpass. Simply
remove the jumper and re-install it on JP2-4-6 to the position that matches
your requirements (LP or HP or BP or Notch).
Best wishes
Dieter Doepfer
Yahoo Groups Links
