Dark enegy VCO out
2014-06-11 by raccoon_boy@yahoo.com
Hi there
I have a Dark Energy Mark I.
I believe it is possible to output the VCO (and VCF) but not quite sure how.
I have some electronic and soldering experience and can usually modify things with some confidence, but usually with some basic instructions.
I have the correct version of the DE (V2 2010) which has capability of outputtng the VCO (triangle). In the technical information it says it is the right pin of JP13 on the voice board. But how would I get this out?
Woud it be a sort of jumper with a wire attached to it? and then I attach this straight to a jack socket?
Do I need to do anything with the ground part of the JP13 to keep the socket grounded, or can I just ignore this?
Any help greatly appreciated.
Dan
PS: Is there any use for VCF out other than for sending out a sine wave?
