2014-06-02 by isoldeisobelle@gmail.com
I seem to be having a problem with my A-105 SSM LPF.
If I modulate either of the cut off (FCV1/FCV2) inputs with any shape from an LFO, I get a loud audible click coming from the filter as the LFO goes through it's cycle - with audio going in to the filter or not... also with resonance set to zero or otherwise.
I have tested other Doepfer filters with the same lead/LFO/ etc and the problem does not materialise.
Any suggestions, please.
Best wishes
2014-06-03 by yahoo@doepfer.de
> Hi,
> Best wishes
I suppose that the module is faulty and has to be repaired. Maybe the SSM
circuit is defective but it may be also another circuit. Please return the
module for repair to the dealer where you purchased it.
Best wishes
Dieter Doepfer
2014-06-03 by isoldeisobelle@gmail.com
Thank you very much for your reply.
Best wishes
2014-06-11 by isoldeisobelle@gmail.com
Hi again.
I just received the replacement A-105 and on testing the module it still generates the same short click on modulation of the CV inputs with any shape wave.
It seems quite unfeasible that two of the same modules would be faulty in the same way, so maybe it is me at fault!!!
Should this be happening? It is quite a loud sound that it produces as the LFO modulates... like I stated before: with no other inputs and the level at zero.
Any suggestions would be most welcome.
Kind regards
2014-06-11 by Florian Anwander
Can you post a detailled description of a test patch which can be used
to reproduce the problem. Create the patch only with Doepfer modules and
make the patch as simple as possible. Describe each parameter setting
for each module. And finally you may provide an audio example of the
problem based on this patch on soundcloud or similar.
Maybe then it is possible to reproduce (and explain) the behaviour.
Florian
On 11.06.14 21:23 , isoldeisobelle@gmail.com [Doepfer_a100] wrote:
> Hi again.
> shape wave.
> level at zero.
> Kind regards
2014-06-12 by isoldeisobelle@gmail.com
Hello and thank you for your reply.
Here is the patch: A-145 sine > A-105 FCV2> A-105 output > A-138 input 1 set at seven > A-138 output set at seven > Audio interface.
The A-105 freq is set at the five mark and I sweep the FCV2 pot up from zero to ten. The sound starts to appear at around the three mark - but, earlier if the freq is lower.
Here is the Soundcloud link -
A-105 A-105 Listen to Isolde & Isobelle / A-105 | Explore the largest community of artists, bands, podcasters and creators of music & audio.
Preview by Yahoo
Thank you and best wishes.
.... sorry, forgot to mention, all other settings of the A-105 are at zero.
2014-06-12 by yahoo@doepfer.de
> Hi again.
> Kind regards
I'll take an A-105 module from stock and try it out. The A-105 nothing but
the standard application of the SSM2044 filter circuit. How loud is the
sound compared to the normal audio signal (i.e. with full audio level just
before clipping). Maybe it's the control voltage feedthrough which is
specified with -36dB in the SSM2044 data sheet. So if the click is
about -35dB compared to the full signal it's probably the control voltage
feedthrough.
Best wishes
Dieter Doepfer
Hi Dieter and thank you for the reply.
I can not be to certain to the accuracy of my monitoring of the sound - but, with the settings I mentioned above it is almost touching the -4dB level on my hardware mixer (with no extra gain) and roughly the same in my DAW.... so pretty loud!
I should have recorded a sample with audio input for comparison, but with lower frequency input the sound is fairly noticeable as the LFO cycles... even more so with higher frequencies as the sound is fairly low.... it makes a useful kick drum btw! ;)
I only had the filter for a short period before I sent for the replacement, but I am almost certain that it never behaved this way at first... it seems striking that the replacement would be the same.
Having said that; I have eight filters in my system - five of them being Doepfer and this is definitely one of my favorites - a wonderful smooth sound and I personally prefer its more ''darker'' tone compared to its nearest rival.
Best wishes
2014-06-12 by Florian Anwander
Hi Dieter
Am 12.06.2014 10:48, schrieb yahoo@doepfer.de [Doepfer_a100]:
> So if the click is
> feedthrough.
Listen to the soundcloud example, there is no audiosignal at all.
But the soundexample is indeed quite "funny", because the modulation
sounds like an asymmetric pulse wave - while he states, that he is using
a triangle from the A-145.
@isoldeisobelle:
Can you turn up the resonance so we can hear whether it is in fact a
sine, which is doing the modulation.
Maybe it is not the 105 which is broken, but the A-145 (I don't have the
schematics here, so I don't know whether some broken OpAmp in the sine
out could act as an comparator).
Florian
2014-06-12 by achtung_999
"while he states, that he is using
a triangle from the A-145."
Sorry to intervene but he said he uses the sine from the A145.
Interesting problem though...
On Thu, Jun 12, 2014 at 11:23 AM, Florian Anwander
fanwander@mnet-online.de [Doepfer_a100]
<Doepfer_a100@yahoogroups.com> wrote:
Hi Dieter
> So if the click is
> feedthrough.
@isoldeisobelle:
Florian
Hi Florian.
It is a sine wave that I am using from the A-145.
I have also tried the square and triangle outputs from my A-143-4 - it still behaves the same way, but with different waves the ''click'' becomes more or less pronounced in character - but, not volume.
With resonance turned up you get the expected ''sweep'' sound but with the click at the end of the modulation cycle.
Kind regards
2014-06-13 by isoldeisobelle@gmail.com
Hello .
Any more suggestions for my problem, please, or should I return the module to my distributor again.
Kind regards
2014-06-13 by yahoo@doepfer.de
> Best wishes
I took an A-105 module from stock and measured indeed a control voltage
feedthrough of about 30mVpp (i.e. if the CV changes the output voltage
changes up to 30mV without audio input). The full level of the module before
clipping is about 15Vpp. So the measured control voltage feedthrough is
25mV/15V = 0,017 which is -35dB. That's very close to the specified -36dB
control voltage feedthrough in the SSM2044 data sheet. So I suppose that
it's just the control voltage feedthrough which you hear. Maybe we should
add this information to the A-105 specs (which are in the end nothing but
the spec of the SSM2044). The output voltage follows not exactly the CV
input signal but is assymetrical (or distorted), i.e. modulating the filter
frequency e.g. with a sine wave does not generate a sine wave at the output
but a very distorted sine (like a waveshaper). If the CV input is in the
audio range you will hear the frequency of the modulation LFO at the A-105
output even without any input signal (about -35dB compared to the full 15V
signal with audio input).
Best wishes
Dieter Doepfer
> Hello .
> Kind regards
Please refer to my previous email. If the control voltage feedtrough is not
acceptable for you please return the module for refund (replacing does not
make sense as all A-105 show this behaviour).
Best wishes
Dieter Doepfer
Hi Dieter.
Apologies, I did not see your previous detailed explanation.
Thank you very much for your reply and taking the time to test my query.
I never noticed this behavior when I first used the filter but -36dB is, for me, a usable level to deal with - I suspect that I may be patching things now a little differently, possibly with regards to VCA gain, which has made it noticeable than it did to begin with.
Either way, it is great sounding filter and so long as I know that this behavior is inherent in the design... it is something that I am prepared to live with.
Kind regards and best wishes
Tolly Hamilton
> Hi Dieter.
> begin with.
> Tolly Hamilton
As a rumor Solid State Music (SSM) was aware of this drawback and developed
a new SSM2044-compatible circuit named "SSM2046" which should have a 10dB
better control voltage feedthrough. But it's quite impossible to find more
information about this circuit and I have never seen an exemplar of this
circuit.
Best wishes
Dieter Doepfer
