Doepfer
A-114 or A-133 for ring mod duties?
Re: [Doepfer_a100] A-114 or A-133 for ring mod duties?
2014-02-28 by Martin Fay
Hi Richie,
I have an A-133 but not an A-114, iirc they don't sound that
different, both are certainly 4-quadrant multipliers as opposed to
diode rings. The A-133 is quite versatile, can double on attenuation/
inversion duties for instance, see if you can find Navs writeup. This
was one of the more multi-purpose modules before Euro headed West.
Martin
On 27 Feb 2014, at 23:14, <richyho@virginmedia.com> wrote:
> Is the A-133 a ring modulator? Does it sound like the A-114? It
> seems more versatile.
> Thanks
AW: [Doepfer_a100] A-114 or A-133 for ring mod duties?
2014-02-28 by yahoo@doepfer.de
> Thanks
The A-133 can be treated indeed as kind of a ring modulator. To speak the
truth I never tried to use the A-133 as a ring modulator. But in principle
it should work. The main difference between A-114 and A-133 is the signal
coupling (A-114: AC coupled, A-133: DC coupled) and the internal technology:
the A-114 uses a real four quadrant multiplier (MC1496), the A-133 is
nothing but a VCA where original signal is mixed with the inverted VCA
output signal. If both signals have the same level (VCA amplification = 1)
the output result is ~ 0V. If the VCA amplification is zero the original
signal appears at the output, if the VCA amplification is max. only the
inverted signal appears. But as the VCA also has a phase delay (depending
upon the signal frequencies) and frequency limitation the result is not
perfect (worse as the frequency goes up). I'd expect that both modules sound
different as ring modulators. Maybe another member has tried this out
already. I don't have the time as I'm busy because of the upcoming
Musikmesse in Frankfurt.
Best wishes
Dieter Doepfer
Re: AW: [Doepfer_a100] A-114 or A-133 for ring mod duties?
2014-02-28 by achtung_999
I have both. And with the right knob settings the A133 can sound like the A114.
I have tested it a few times when I needed an extra A114.
Best regards,
Ernst
On Fri, Feb 28, 2014 at 11:51 AM, <richyho@virginmedia.com> wrote:
Thanks Dieter. I did read Navs' review of the A-133 and it was this that made me ask. I would like to hear a comparison of the 2 if anyone can find one?
