Doepfer
A-188-1 clock frequency input
2014-01-14 by Zoë Blade
Hi!
So I was trying out some basic Karplus-Strong synthesis on my A-188-1.  It makes a really nice sort of plucked string sound!  I've been having great fun just playing a middle C and sampling it.  It would be even nicer to play it live, with all those wonderful subtle imperfections that really bring it to life.
So I connected my pitch CV output to the BBD's clock frequency input, and it's just shy of 1V/oct.  It manages something like 10 or 11 notes per volt (as both the maximum of CV2 and the fixed setting of CV1, I believe).
I realise it isn't designed to do this, and it's a bit of a hack.  Still, I was wondering if there might be some sort of (presumably warranty-voiding, and I'm fine with that) mod I could do to make CV1 and/or CV2 everso slightly more sensitive?  Is there a preset potentiometer or something for this, perhaps?
I really will end up buying the German language A-100SM at this rate... :)
Zoë.
Re: [Doepfer_a100] A-188-1 clock frequency input
2014-01-14 by JS Home
Surely you just need to amplify it a touch with A183-3 then run it through an offset/attenuator. Job done!
Jonathan Shapero
On 14 Jan 2014, at 19:50, Zoë Blade <zoe@bytenoise.co.uk> wrote:
> Hi!
> Thanks,
> Zoë.
> Yahoo Groups Links
2014-01-15 by Zoë Blade
Fantastic idea, thank you!  Now I regret selling my A183-3, heh...
Come to think of it, as I'm deriving the pitch CV using an MCV-24, I could retune that to compensate.  That should work, I think.
Thank you!  Boosting the signal before sending it to the module.  That's what I was missing.
Are there any other ways around it?  I love how modulars encourage lateral thinking, and there are so often several solutions to whatever someone's trying to do. :)
Zoë.
AW: [Doepfer_a100] A-188-1 clock frequency input
2014-01-15 by yahoo@doepfer.de
You may simply change the trimming of the scale of the internal HSVCO. It's
described in the document A1881_adjustment.pdf. A link to the document is
available on the A-188-1 info page.
Best wishes
Dieter Doepfer
> -----Ursprüngliche Nachricht-----
> Von: Doepfer_a100@yahoogroups.com
> [mailto:Doepfer_a100@yahoogroups.com]Im Auftrag von Zoë Blade
> Gesendet: Dienstag, 14. Januar 2014 20:51
> An: Doepfer_a100@yahoogroups.com
> Betreff: [Doepfer_a100] A-188-1 clock frequency input
> Hi!
> Thanks,
> Zoë.
> Yahoo Groups Links
Thank you, I can't believe I missed that one!  OK, that's three ways to solve my problem in total, thanks everyone. :)
All the best,
Zoë.
