Wasp no longer buzzing
2013-11-16 by mantzster@gmail.com
Hi All,
1st message and it's a plea for help As the title say my Wasp is no longer working, I had it out of the case, and on putting it back all I get out is the original audio from the HP out ie. the HP/LP balance acts as a volume control. Nothing from the BP out either, and the Freq & Res controls have no effect on the audio I can hear via the HP.
Swapped out the CD as I understand this can be vulnerable, no change. Tried swapping out the 2 CA3080s one at time, again no change. Only thing I haven't swapped out is the 5532. No obvious signs of shorts / crack damaged components. What's the next step? Do have some electronics experience and a multimeter
cheers for any advice.
