Re: [Doepfer_a100] Question about the A-185-2 module
2013-11-06 by Zoë Blade
Hiya! I'll have a go at answering this too. Someone please correct me if I'm wrong. When you use the front pitch and gate outputs on the A-190, does it still send the signals to the bus as well, or are they mutually exclusive? If it still sends to both, then yes, what you suggest should be fine. If they're mutually exclusive, then the signals will have to travel a bit further over many wires: from the A-190 in the first case to the A-185-2 (or an A-185-1 for that matter) in the second case then back from there to the two A-110s and up to two gate controlled devices in the first case. This will work, but it's a bit cumbersome (and uses up more leads!) compared to having an A-185-1 or A-185-2 in both cases, and linking the A-190 to one, and that to the other, and you're done. Also bear in mind that without a *buffered* multiple like the A-185-1 or A-185-2 talking to the oscillators, you can only control up to about two before the tuning goes off, which is another reason it's good to have an A-185-1 in each case: in case you want to have more than two oscillators in the first case one day. Does that help? Thanks, Zoë.
