Problem with Midi Clock in A-190
2013-09-27 by etabetawave@yahoo.com
Hello,
I am trying to synchronize a-190 by using midi clock from a Cubase project. The 190 clock output is divided by software divider and controls a a-155 sequencer. But the clock sent to the seq does not follow the project, that is too fast. The manual of 190 says that the clock can be divided in these ways:
divisor clocks per note note length
1 96 1/96th
3 32 1/32nd
6 16 1/16th
12 8 1/8th
24 4 1/4
but none of these is properly controlling 155 seq…
This also happens if I leave the clock rate unchanged and use the same in-160 clock divider.
Has anyone had this problem?
thanks
