Doepfer
track made to demonstrate timing multiplication in MAQ
2013-07-13 by niroke
http://vimeo.com/70227036
This video matches the soundcloud link I posted the other day in the DoepferMAQ group. It shows Row 2 altering the timing of both Rows 1 + 2. Row 1 is sequencing an A-100 patch, which was recorded in one take, with realtime manual control of FM Depth, Cutoff, and Note Length (using a joystick and VC Decay module). If you follow the lights on the top row, you will see the sequence speeding up according to the settings of row 2. The first minute is just the modular patch sequenced by the MAQ. Row 1 is set to pendulum mode. This sequence continues to play for the entire track.
You will also notice that sometimes there is no sound when Row 1 is
moving. These missing notes were muted from the captured audio when
arranging the track, and mainly occur at the very beginning and very end of the track. Otherwise, no editing of the MAQ sequence was done. Had I planned ahead, these mutes could have been performed live using a joystick and logic module but would have given different results.
The soundcloud file I posted was rendered at 124bpm. I had to re-render another version at 120bpm to sync to the video. I made a few changes while I was at it, but nothing major.  Other sounds were played and recorded as audio from an Indigo 2.
nick
Fwd: [Doepfer_a100] track made to demonstrate timing multiplication in MAQ
2013-07-14 by Peter Sedin
thanks for this!
---------- Forwarded message ----------
Date: 2013/7/13
Subject: [Doepfer_a100] track made to demonstrate timing multiplication in
MAQ
To: Doepfer_a100@yahoogroups.com
nick
Mvh
Peter H.K Sedin
Re: [Doepfer_a100] track made to demonstrate timing multiplication in MAQ
brilliant..
2013/7/14 Peter Sedin <peterhksedin@gmail.com>
> thanks for this!
> From: niroke <maq163x2@gmail.com>
> Date: 2013/7/13
> MAQ
> nick
> Mvh
> Peter H.K Sedin
Mvh
Peter H.K Sedin
2013-07-14 by Nicholas Keller
Thank YOU, Peter!
Sent from the future
On Jul 13, 2013, at 10:24 PM, Peter Sedin <peterhksedin@gmail.com> wrote:
> brilliant..
>> thanks for this!
>> Date: 2013/7/13
>> MAQ
>> nick
>> Mvh
>> Peter H.K Sedin
> Mvh
> Peter H.K Sedin
