No, the dx range is wrongly known as frequency modulation wheras its is really phase modulation. fm synthesis is done digitially because it uses groups of sine waves in which strict frequency and phase relationships are required, which you cant easily have with analog. You modulate one oscillator with another oscillator. The casio cz range is phase distortion not phase modulation. Close but different.
Reliability is mostly down to the owner. Keep it in a good environment and maintain properly then yes, its a golf
On 17 Jun 2013, at 15:42, "anoop.sahal" <draks@apollo111.demon.co.uk> wrote:
> Thanks,Florian and Thanks Zoe,
> You may have saved me from chasing rainbows by warning me of the limitations of FM synthesis.
> Would a ring modulator with multiple inputs and multiple ADSR's do a better job than simple phase interaction?
> I read on wikipedia that the DX 7 really had a phase distortion mechanism like the Casio synths. Now that was a cool whacky system, whoever thought of varying the rate of read out of a sine wave from a ROM!
> By the way does Doepfer have German reliability like my Golf, Waldorf and 50 year old Grundig reel to reel?
> --- In Doepfer_a100@yahoogroups.com, Zoë Blade <zoe@...> wrote:
> > Yeah, I'm afraid Florian's right.
> > To broaden the discussion a bit, modular synthesisers aren't particularly well suited for FM synthesis and polyphony. FM synthesis is usually implemented digitally because making another oscillator consists of writing a few more lines of code and getting a slightly faster chip, rather than spending another £200 or so on a tangible oscillator (not to mention the cost of the envelope generator, VCA, etc).
> > But before you get put off analogue modulars, there's a whole bunch of things you can do with them that you can't do so well in the digital domain. All the tiny imperfections add up to sound more quirky and interesting. You can touch physical knobs and leads to make changes, giving your eyes a rest from the screen and your hand a rest from the mouse. The inability to save a patch means you can't ever quite recreate anything you made before, but you will instead discover new sounds each time, and hone your patching skills faster. You will be forced to make the sounds of each track sound at least slightly different from the last, something everyone should be doing anyway. Negative points have a strange way of becoming plus points in this respect. And when you start throwing things like spring reverbs into the mix, and all those filters, you really get a completely different world of sound to what you can get from a DX-7 or software. Gritty, unstable, untamed beasts of sound that you're struggling to keep under your control, that sound powerful, strange and alien.
> > Now, if you want to make Krautrock, you probably only need a fairly basic A-100 system and maybe some Mellotron or Orchestron samples, and you'll be set for at least half a dozen albums or so. :)
> > I'd recommend reading Gordon Reid's Synth Secrets: http://www.soundonsound.com/sos/allsynthsecrets.htm (The list's in reverse order.) It's a great guide to patching sounds together, and will give you plenty of ideas about which modules you'll suddenly "need". :)
> > Anyway, I'd recommend making clean, clinical music in software, and gritty, organic music using something like the A-100. While both can do both, it's much easier to play up to each instrument's strengths.
> > All the best,
> > Zoë.
