Doepfer
Installed new module, now my rack has only one LED lit! HELP
2013-04-28 by metronomezine
I was installing the Delptronics LDB1e and expander - module webpage says it needed +5v. I already had the adaptor installed for the Rebel Tech Stoichea. Plugged the Delptronics module in, and didn't hear sound. Moved it to another rack, installed the +5v module, it worked. Then I tried patching to another module in the previous rack i tried the Delptronics in and it didn't sound right. I look at the LEDs on the busboards and only 1 LED is lit, +12v. The -12v isn't lit. All my other racks show both LEDs, the rack with the +5 volt module shows all three. WTF did i do, and how do I get it back to normal?? I dread the worst. Urgh. Help.
Re: Installed new module, now my rack has only one LED lit! HELP
I pulled all the modules and i have 2 LEDs again. Would excessive voltage draw cause this? How do you delete messages from this group?
--- In Doepfer_a100@yahoogroups.com, "metronomezine" <matthewmelnick@...> wrote:
Re: [Doepfer_a100] Re: Installed new module, now my rack has only one LED lit! HELP
2013-04-28 by Florian Anwander
On 28.04.13 23:46 , metronomezine wrote:
>> The -12v isn't lit
I don't think so. Especially as the -12V is usually the least used line.
You can't this is a mail list. The mails are sent already.
Florian
