Thanks that's what I thought I just wanted to be sure!
Thanks, Jack
On Apr 27, 2013, at 2:34 AM, "nicholas_kent" <zaum@optonline.net> wrote:
> --- In Doepfer_a100@yahoogroups.com, "Jack" <jackjohnaldson@...> wrote:
> > Hello I just built a PAIA model 9302 drum tone board and I'm trying to figure out how to wire it's power connector for my Doepfer power supply. Does anyone have a diagram. The power requirements for the PAIA module are +12v +5v gnd but no -12v
> > thanks ,Jack
> The simple answer is if it doesn't need -12v then no -12v wiring is required. You wire the ground and the voltages needed. Also be aware that +5 is not generated on a lot of Doepfer supplies.
