Doepfer
Musikmesse
Musikmesse
2013-04-15 by isoldeandisobelle
The good Dr.Doepfer doing his thang at the messe. ;)
http://www.sonicstate.com/news/2013/04/14/messe13-a-chat-with-dr-doepfer/
A-106-6 FCV2 Range
2013-04-16 by Pieter Volger
Hi all,
is it possible to reduce the calibration-range of the FCV2 attenuator on the A-106-6 module. If I go beyond 4 on the scale  I am already beyond the audible range when modulating with an LFO or ADSR. I bought the module used so I don't know if it is originaly calibrated like this. Thanks a lot.
Pieter
AW: [Doepfer_a100] A-106-6 FCV2 Range
2013-04-16 by yahoo@doepfer.de
> Hi all,
> Pieter
I'm sorry - there is no calibration for FCV2. Fully CW the sensitivity of
FCV2 is about 0.5V/oct, in center position about 1V/oct. But I wonder that
you are in position 4 already beyond the audible range with an ADSR or LFO.
Maybe the frequency offset has to be adjusted. That's P6, labelled OFFSET.
With all frequency controls at the front panel fully CCW the frequency of
the filter should be about 10-15Hz (can be measured e.g. in self oscillation
with a frequency meter).
Best wishes
Dieter Doepfer
Re: [Doepfer_a100] A-106-6 FCV2 Range
Thank you very much for the quick answer.
Best wishes
Pieter Volger
Am 16.04.2013 um 13:29 schrieb yahoo@doepfer.de:
> > Hi all,
> > Pieter
> Best wishes
> Dieter Doepfer
