Doepfer
is A-141 fast enough for percussion/clicky stuff?
2012-10-31 by midihooker666
Hello! I´m finlay building a little system here.. looking for some god adsr for percussion (main thing for me right now). Is A-141 fast enough for this? also looking at cwejman modules everybody says should be used for this but these are expensive!
any thouhgt to a newbee like me on this? also says hello to old fiends from AH list :)
peace
peter from sweden
Re: [Doepfer_a100] is A-141 fast enough for percussion/clicky stuff?
2012-10-31 by Bakis Sirros
the A140 is pretty fast and should be ok for what you want.
not cv-controlled though.
Bakis Sirros
www. parallel - worlds - music. com
www. facebook. com/ pages/Parallel-Worlds/192093934136476
www. myspace. com/ interconnectedmusic
www. myspace. com/ memorygeist
www. DiN. org. uk
www. vu-us. com
To: Doepfer_a100@yahoogroups.com
Sent: Wednesday, October 31, 2012 10:03 PM
Subject: [Doepfer_a100] is A-141 fast enough for percussion/clicky stuff?
peace
peter from sweden
2012-10-31 by Zoë Blade
I'll second this.  It's got a switch to toggle between slow, medium and fast.  It can get plenty fast enough even on the medium setting. :)  With just a white noise module (A-117 or A-118), the A-140, a multimode filter and ideally a curveball such as the A-199 spring reverb (which can sound very metallic with percussive white noise, like hitting a massive metal drum, sort of), you can make a whole wealth of interesting percussive sounds.  Then you just need a MIDI to CV converter like the A-190-2 to actually trigger the envelope generator and you're all set for percussion!
I haven't used any Cwejman modules, so can't really comment on those.  I hear they're very good, but my motto's to get several inexpensive and versatile modules instead, so I can make a wider variety of sounds.  Doepfer's modules are ideal for this!
All the best,
Zoë.
Re: is A-141 fast enough for percussion/clicky stuff?
2012-11-01 by Rudy
I often use my A-141 for hi hats with cv control of release to create close -open effect.
I t can be pretty snappy and clicky! But as a starting system I would go with 2 A-140
--- In Doepfer_a100@yahoogroups.com, "midihooker666" <peterhksedin@...> wrote:
> peace
> peter from sweden
2012-11-09 by midihooker666
yes that why i looked at 1-141 cause i like to control the decay..
--- In Doepfer_a100@yahoogroups.com, Bakis Sirros <synth_freak_2000@...> wrote:
> Â
> Bakis Sirros
> www. DiN. org. uk
> www. vu-us. com
>  From: midihooker666 <peterhksedin@...>
> Â
> peace
> peter from sweden
2012-11-09 by Peter Sedin
thanks for your reply Zoe..
I  have a Cirklon sequencer i just bought the CVIO board to wich give med 8
gates and 16cv outputs, 32 patterns. so i have the trigging sourted out as
those gates can be anywhere from 2ms as shortest..
I now also have looked at a-101-2 lowpassgate wich seems like yet another
way to make short percussion stuff.. controlling decay is essential i think
to make cool evolving percussion.. I also looking to buy a malekko wiard
borg filter (also a lowpassgate)..
peace out..
peter
2012/10/31 Zo� Blade <zoe@bytenoise.co.uk>
> All the best,
> Zo�.
Mvh
Peter H.K Sedin
