Doepfer
A-160 Clock Divider A-161 Clock Sequencer Ribbon Cable?
2012-09-04 by InLovingJest
Does anyone know the orientation of the smaller ribbon cable that connects the
Doepfer A-160/A-161  Clock Divider/Sequencer together. Mine are disconnected and I'm unable to find an online reference. I'd hate to incorrectly connect the power rail. Doh!
AW: [Doepfer_a100] A-160 Clock Divider A-161 Clock Sequencer Ribbon Cable?
2012-09-05 by yahoo@doepfer.de
> Hi,
> connects the
> Thanks :)
Please refer to page 1 of the A-161 user's manual:
"Installation in the rack system:
The A-161 must be positioned directly to the right of the A-160.
Join the two modules with the supplied 10-way ribbon cable. Use the upper
10-way socket on each module.
Make sure that the ribbon cable isn’t twisted, and that the colour-coded
section is oriented the same on both modules.
Only join the A-160 to the system bus! Leave the lower 10-way socket on the
A-161 unused."
Pay attention not to damage one of the parts on the boards (especially none
of the transistors). You may bent the transistors a bit (carefully) to plug
on the cable.
Best wishes
Dieter Doepfer
