Doepfer
Re: Dark Time tuning
2012-08-08 by Mike and Delonna Hyland
Mark, just thought I’d suggest another obvious possibility – if you are using a MIDI or other controller, make sure the pitch wheel is set exactly in center (or whatever is “0”).  I’ve had mine get a little off before and wonder why I wasn’t in tune.
Mike
PS  Dieter, I really love the Dark Time and Dark Energy combo.  Thanks so much, I’ve been having a blast with them.
2012-08-09 by mark
Cheers, hadn't thought of that either...
--- In Doepfer_a100@yahoogroups.com, "Mike and Delonna Hyland" <hy5@...> wrote:
> Mark, just thought I’d suggest another obvious possibility â€" if you are using a MIDI or other controller, make sure the pitch wheel is set exactly in center (or whatever is “0”).  I’ve had mine get a little off before and wonder why I wasn’t in tune.
> Mike
