Doepfer
A-110 tuning question
2012-07-10 by karlsjunkmail
Hey there Doepfer group members,
I have another newbie question. I purchased a basic A-100 modular system
used a few months ago, and I'm still having some trouble figuring it
out. Part of the problem is the tuning of the two A-110 VCOs. I
understand that I need to give the system at least 20 to 30 minutes to
warm up, but even then, the tuning is off. If I hook up the system so
that I can hear VCO 1 and/or VCO 2 when I press keys on my MIDI
controller, VCO 1 cannot tune to the correct pitch because it is not in
range of the tuning knob. More puzzling to me is VCO 2, which seems to
produce a slightly different random note each time I press a key. (In
regard to the issue with VCO 2, is there something else that could  be
causing this random-pitch effect? I have made only the connections
necessary for a simple synthesizer sound. When I "sync" VCO 2 to an
output of  VCO 1, this effect generally seems to go away. Please forgive
me if this is an  obvious problem.)
I've tried to investigate some previous discussion threads, and I see
that several other users have had the same problem I have with VCO 1,
and the suggested solution is to follow the "adjustment procedures" on
this webpage: http://www.doepfer.de/a110_tec.htm. However, since I don't
even have a rudimentary understanding of electronics repair, I have no
idea what the adjustment procedures are talking about. To give you an
idea of how clueless I am, I don't even know how I would go about
"measuring the voltage" of the various components, nor do I know how to
read the schematics. I suppose I could possibly take the modules and the
instructions to a professional repair person, but clearly, repairing the
VCOs is not a job I can do myself.
I guess at this point, since I am unable and frankly unqualified to make
the sort of electrical adjustments that appear to be necessary to get my
VCOs in tune, I'm wondering if I could fix the problem simply by buying
two brand-new VCOs. Would they ship from the factory with correct tuning
and function properly once installed? (If so, I'd be happy to part with
my current A-110s, which I'm sure could be calibrated by someone who
knows what he or she is doing.)
Thanks so much for your help!
Karl
AW: [Doepfer_a100] A-110 tuning question
2012-07-10 by yahoo@doepfer.de
Hello Karl,
in this case I'd recommend to send in the module for calibration as without
measuring a voltage it's impossible to do the adjustments. The procedure
depends upon your home country. If you live within the EU you may send in
the module directly to us (address on our website). Otherwise please contact
the Doepfer representative in your country and ask if they are able to help
you.
Best wishes
Dieter Doepfer
> -----Ursprungliche Nachricht-----
> Von: Doepfer_a100@yahoogroups.com
> [mailto:Doepfer_a100@yahoogroups.com]Im Auftrag von karlsjunkmail
> Gesendet: Dienstag, 10. Juli 2012 08:49
> An: Doepfer_a100@yahoogroups.com
> Betreff: [Doepfer_a100] A-110 tuning question
> Karl
Re: A-110 tuning question
2012-07-11 by karlsjunkmail
Wow, when I typed my post, I didn't expect I would hear back from Dieter Doepfer himself! Although I'm still very new to this forum and to modular synthesis in general, thank you very much, Dieter, not only for your many remarkable contributions to electronic music but also for being a supportive part of this online community. I will take your sound advice (so to speak) and contact the Doepfer rep in the USA. Many thanks and all the best!
-Karl
--- In Doepfer_a100@yahoogroups.com, <yahoo@...> wrote:
> Hello Karl,
> you.
> Best wishes
> Dieter Doepfer
> > Karl
> > Yahoo! Groups Links
