Doepfer
Wire for patch cables?
2012-07-05 by cliffmaniam
I am going to make up a bunch of patch cables, but having trouble finding a good source for wire. Anyone have a Mouse or Jameco part number for some decent single-conductor shielded wire?
thanks
cliffman
Re: Wire for patch cables?
2012-07-13 by neal_beard_ahm
Hi I have also been puzzling over this - specifically looking for a supplier of - decent single conductor shielded cable in different colours... red, green, yellow, blue, white  - anything apart from grey or black!
So far I've drawn a blank...
I'm based in UK
Neal
(this is my first post!)
> thanks
> cliffman
Re: [Doepfer_a100] Re: Wire for patch cables?
2012-07-13 by brian walker
Hi
http://www.studiospares.com/cables+connectors/icat/shocablesconnectors/
or
http://uk.rs-online.com/web/
You might have to dig deep at RS
Brian
To: Doepfer_a100@yahoogroups.com
Sent: Friday, 13 July 2012, 11:35
Subject: [Doepfer_a100] Re: Wire for patch cables?
I'm based in UK
Neal
> thanks
> cliffman
2012-07-14 by umcorps
--- In Doepfer_a100@yahoogroups.com, "neal_beard_ahm" <neal.layton@...> wrote:
Analogue Systems
http://www.analoguesystems.co.uk/buynow.htm
Not cheap, but superb quality.
Mark
2012-07-14 by Ton Akveld
Dear Dieter,
We are crying out loud for more colour in our Doepfer lifes :-)
> I'm based in UK
> Thanks
> Neal
> > thanks
> > cliffman
And unfortunately: Note that this service is available to the UK only. Contact sales for international shipping charges.
--- In Doepfer_a100@yahoogroups.com, "umcorps" <mark@...> wrote:
> --- In Doepfer_a100@yahoogroups.com, "neal_beard_ahm" <neal.layton@> wrote:
> Analogue Systems
> Mark
2012-07-16 by cliffmaniam
Those are nice cables, but I just want wire. Make my own. Wire seems to be impossible to get in the US, i am considering using 50 ohm coax, which at least i can get from Belden. Sigh.
The studiospares site looks great, wish I could find something like that in the US...
cliffw
> > Analogue Systems
> > Mark
2012-07-16 by james_w72
I ran across this site last week - may be of some use - the site is mostly parts for guitar effects pedals -
http://www.mammothelectronics.com/category-s/148.htm
Color cables are available already made up -or- as just plain. Available by the foot or by the spool. Prices seem reasonable.
Would like opinions on these - if they would work for synths.
- James
> cliffw
> > > Analogue Systems
> > > Mark
2012-07-16 by the_real_dripfeed
Forgive my naivety, but are modular patch cables (I presume you are talking about patch cables) made out of something esoteric? I would have assumed that decent instrument cable (e.g. for guitars, etc.) would be fine.
Guitar cable is typically way thicker than the sort of cable used for 3.5mm-1/8". Guitar cable has to stand up to a bit more stress from those guitarists jumping around :) Wire inside is usually  20 AWG or bigger, low capacitance is real important for guitarists. So, guitar cable is like this: http://www.awcwire.com/mfg/Belden/Part/9778 I think such wire would be way to big for my connectors, plus too much strain on the jacks. I'm looking for more like 28-30 AWG, which seems to be what I'm finding in pre-made cables. I am thinking maybe this, at last resort: http://www.awcwire.com/mfg/Belden/Part/9396 - notice it's less than 1/2 the thickness of the 20 AWG stuff.
cliffw
--- In Doepfer_a100@yahoogroups.com, "the_real_dripfeed" <seandynan@...> wrote:
2012-07-17 by mr julian
Cable suitable for making patch leads is very available.
though it takes a fair bit of time to make just one lead, and you are
going to want up to 4 times as many patch leads as you have modules.
I make my own audio leads generally, but not patch leads.
I have a combination of doepfer and http://www.adinfinitummusic.com/
patch leads. I can't make them for less money than these sell for.
anyway - maybe if you really want to have the feeling of having made
them yourself, searching for "single core shielded cable" should put you
on the right track.
here's a local (to me, in Australia) example:
http://dicksmith.com.au/product/W2030/single-core-shielded-audio-cable
I've used this to make longer 1/8" plug cables for running to midi-cv
converters and my 101, etc, and it's what I'd be using if I wanted to
make all my own patch cables.
here's a hi quality and expensive example of what you might want.
http://www.canare.com/ProductItemDisplay.aspx?productItemID=62
though this may be a little large with outer diameter at 4mm. Check with
the plugs you want to use and see what cable they'll take.
have fun!
julian
> cliffw
>>> Analogue Systems
>>> Mark
