Doepfer
What's the difference between the A-136 & A-137-1?
Re: [Doepfer_a100] What's the difference between the A-136 & A-137-1?
2012-01-23 by Florian Anwander
Hello Matt
Am 22.01.2012 19:06, schrieb Matt Fretton:
> Is the A-136 a simpler and smaller version of the A-137-1 or are there
> more significant differences? I don't have the space for both...
The A136 is basically like a guitar distortion stomp box going over the
top - and with the possibility to have different distortion levels for
the positive and the negative parts of the signal. Technically you may
think it is a compressor/expander with zero attack and release rate and
separate ratio and threshold for both half waves.
The A137 is like four simplified A136 stacked up in series. Simplified
because you do not have separated access to the two half waves. Also you
do not have access to the parameters of the individual stages. Instead
of that you control parameters which affect all stage the same way
(exception 'Folding Level', which decides how "deep" the signals is fed
into the four stage chain).
Sound wise: The A136 can(!) be a very very good dynamic distortion box,
but it is not easy to handle. The parameters interact very much, and
very often one wrong set parameter spoils the effect of another parameter.
The A137 is a little easier to handle, but also here the "damping"
interaction between different parameters should be obeyed. To my
experience, it is better not(!) to modulate the A137 with CVs, but
instead already modulate the signal level of the signal, which feeds the
A137.
For both modules, I like to use velocity CV, but with quite low
modulation amount. I like to use them for external polyphonic signals
(epiano, synths, guitar).
Florian
Re: What's the difference between the A-136 & A-137-1?
2012-01-23 by mfretton
Hello Florian,
Thanks for this, it's a really helpful explanation.
Really I'd like both but I don't have enough room in my P9 case and don't want to start a separate case again.
Matt
--- In Doepfer_a100@yahoogroups.com, Florian Anwander <fanwander@...> wrote:
> Hello Matt
> A137.
> Florian
Re: [Doepfer_a100] Re: What's the difference between the A-136 & A-137-1?
Hi Matt,
to be honest (sorry, Dieter): you can do 70% of the A136 with any
distortion stomp box (even if it's a $24,99 Behringer fuzz box) if(!)
you are handling the input signal right. Simple distortion is a much
neglected aspect of synthesis.
Florian
mfretton wrote:
> Hello Florian,
> Matt
2012-01-23 by Bakis Sirros
ok, but the stompbox lacks the cv inputs! that is important IMHO.
Bakis
To: Doepfer_a100@yahoogroups.com
Sent: Monday, January 23, 2012 10:44 PM
Subject: Re: [Doepfer_a100] Re: What's the difference between the A-136 & A-137-1?
Hi Matt,
Florian
mfretton wrote:
> Hello Florian,
> Matt
Hi Bakis,
That is, what I want to say: You don't need CV control for distortion.
Distortion becomes interesting, if the input signal changes already.
Having a steady input signal, and changing the distortion is mostly
(90%) unsatisfying.
If you have an steady signal, and increase the distortion threshold,
then the signal becomes thinner (from psycho acoustical point of view).
If you have a steady signal and increase the level and overtone
relations of the input signal, then the overall "look and feel" of the
power of the sound stays the same.
Put an envelope modulated VCF or VCA before a not modulated distortion,
and you will be happy.
Florian
i get what you say (and agree with the vca before the a136 audio input), but i still also like cv modulation of the a136...    :-)
Bakis
Sent: Monday, January 23, 2012 11:00 PM
Hi Bakis,
(90%) unsatisfying.
Florian
2012-01-24 by Florian Anwander
Am 23.01.2012 22:07, schrieb Bakis Sirros:
Yes. Of course CV control is a not a bad thing ;-). I only wanted to
say: CV control on a waveshaper or a distortion is not comparable to
lets say: Pulswidth modulation or filter cutoff frequency. You
definitely cannot say "the more the harder".
I like modulating +L with a very slow LFO and and +A with the inverted
signal of the same LFO.
Also modulating +A and -A with inverted/noninverted LFOs (same with -L
and +L).
The most "frustrating" parameter is A as it suppresses the original in
the center position. It took me months to get this into my head ;-)
