Re: Doepfer Mods
2002-09-25 by spfeifer
I modified Doepfer modules as below and drilled blank synthesizers.Com panels for faceplates. I just have to find time to do the lettering of the panels. I posted a picture of my synth called Doepfer-Synth.com. The top cabinet has the Doepfer modules. For more info about the synth: www.bigsynth.com Scott --- In Doepfer_a100@y..., unknown freak <ospengler@r...> wrote: > Thanks for the info and for posting the pictures. Inspiring -- > definitely looks like the hot ticket. Panel and knob size and jack > durability are basically the only shortcomings of the Doepfer that I can > see. > > Do you have a photo showing how you've mounted the boards to the panel? > > It's somewhat dispiriting but not crucially so that doing over my > 75-module system would probably run around US$2,700 or so, plus the time > investment, but that's still no doubt a savings over MOTM and probably > at least in line with Synthesizers.com if not cheaper. > Sythesizers.com's cabinets would be a logical elegant finishing touch. > > Perhaps doing this kind of work would be a nice sideline for someone -- > there'd definitely be economies of scale. In fact it would be extremely > nice if Doepfer were able to offer this kind of larger panel size or > and/or retrofit to interested customers. > > > -----Original Message----- > > From: noisejazz [mailto:s.f.martin@n...] > > Sent: Wednesday, September 25, 2002 1:08 PM > > To: Doepfer_a100@y... > > Subject: RE: [Doepfer_a100] Doepfer Mods > > > > > > Well - Difficulty wise - all you have to do is desolder all the mini > > jacks and pots (you will almost certainly destroy the mini-jacks - > > no bad thing:). This is quite easy with a good soldering iron and a > > decent solder sucker, but is a bit tedious. > > Then you just solder connecting wires between the pots and your > > newly obtained 1/4 inch jack sockets. Attach the re-used pots and > > new jacks to the Faceplate (Schaeffer), then add knobs. > > I just finished the A-116 and it took me about 1 1/2 to 2 hours > > total. > > I am a slow worker :). > > The face plates are designed with Schaeffer's own software - > > available at http://www.schaeffer- > > apparatebau.de/English/FPD_index.htm > > They cost about 20 - 23ukp or so a piece. > > I used switchcraft 112a jacks (because they are the best) but they > > come in at about 1.50 ukp each. > > The knobs - MOTM style cost about 70p each ( in bulk) > > Then its just wire, solder, patience and determination to get rid of > > thoses darn mini-jacks. > > If I have missed anything out or you have more questions just > > ask. Steve M. > > > > > > ------------------------ Yahoo! Groups Sponsor > > ---------------------~--> Sell a Home for Top $ > http://us.click.yahoo.com/RrPZMC/jTmEAA/MVfIAA/QnLolB/TM > -------------------------------------------------------------------- -~->
> > To unsubscribe from this group, send an email to: > doepfer_a100-unsubscribe@y... > > > > Your use of Yahoo! Groups is subject to > http://docs.yahoo.com/info/terms/
