the xlr pins? there are just 3. for soldering as it locks. well i
get later a kabel that will be nice for 1,5 A and 15 V. that should
do it then. or i cut of a bit from the kabel from the external power
supply cause then i dont have to buy a pack of connectors.
>They are floating outputs so it doesn't matter which goes to which. If using
>a 4-pin connector then use 2 pins for each wire - the thicker the better.
>Best Regards
>Laurie Biddulph
>Mobile: 0400 257 645
>Web: www.elby-designs.com
>-----Original Message-----
>From:
><mailto:Doepfer_a100%40yahoogroups.com>Doepfer_a100@yahoogroups.com
>[mailto:<mailto:Doepfer_a100%40yahoogroups.com>Doepfer_a100@yahoogroups.com]
>On
>Behalf Of istari
>Sent: Tuesday, 15 November 2011 8:16 PM
>To: <mailto:Doepfer_a100%40yahoogroups.com>Doepfer_a100@yahoogroups.com
>Subject: [Doepfer_a100] doepfer diy set 1
>hi
>befor i blow up anything.
>am i right i just dont have to care which cabel from the external 15V
>Transformer
>goes to the diy powersupply board?
>the transformer got a red and a white stripe but the board just got
>to pins for 15V AC.
>i will put some xlr connection inbetween the case also.
>best
>felix
>Yahoo! Groups Links
