Doepfer
Suggestions for what to do with 24HP (or maybe 32)
2002-09-25 by Joe Buechler
If I replace my A190/A191 with an MCV24, I'll have 24HP of space
suddenly available. I could maybe extend that to 32HP if I lose the
A115 audio divider, which I don't use very often.
Anyone have any good suggestions on how I might use this space?
I'm considering the VC mixer (maybe with the morphing controller).
Another possibility is the A129/3 attenuator/offset module which
might be really useful. I generally use a mixer and CV source for
attenuation and offset, which would be free'd up.
Maybe just an assortment of miscellaneous 8HP modules - I'm somewhat
interested in the freq shifter, the logic module, maybe the analog
version of the ribbon controller module instead of getting the midi
version.
Comments? Suggestions?
Joe
Re: Suggestions for what to do with 24HP (or maybe 32)
2002-09-25 by Tim Stinchcombe
Hi Joe,
I also find the A129/3 incredibly useful as a CV source (it's the
only thing I generally use it for), but be aware that it is only good
for *CV* type signals, i.e. anything above about 50Hz just doesn't
get through, therefore if you want to attenuate and add offsets to
audio signals, you'll still need the good old mixer and CV source!
Tim
