Doepfer
Doepfer A-183-2 MOD?
2011-05-25 by Dennis Verschoor
Hi List
Is it possible to mod the Doepfer A-183-2 to have a 10 volt offsett
instead of 5 volt?
I wanna mod a set so i can use them to use them to control some Buchla
100  series vco's.
They need 8 or 9 volt to have an audiorange tuning and add a voltage
to that offset.
Cheers,
Dennis
Music at: http://mono-poly.blogspot.com/
AW: [Doepfer_a100] Doepfer A-183-2 MOD?
2011-05-26 by yahoo@doepfer.de
> Hi List
instead of 5 volt?
> I wanna mod a set so i can use them to use them to control some Buchla 100
series vco's.
> They need 8 or 9 volt to have an audiorange tuning and add a voltage to
that offset.
> Cheers,
> Dennis
For this you have to replace R1 (220k) by 120k. R1 is the top right resistor
(next to the offset control). I have to point out that warranty is void if a
module is modified by the customer.
Best wishes
Dieter Doepfer
