Doepfer
A-190-1 Clock pulse width adjustment?
2011-01-02 by mbox_online
Hello
I wish there was an option for adjusting the clock pulse width, would that be possible in a software update? My A-190 has a pretty wide pulse.
I often start patches/seq's with A-154/155 on internal clock and default width. Since Trig 1-3 outputs are reflected by the clock width, most envelopes etc sound different if I need to sync up via A-190 afterwards.
Any hope?
Martin
Re: [Doepfer_a100] A-190-1 Clock pulse width adjustment?
2011-01-04 by achtung_999
Hello Martin,
For changing the width of a pulse I use a hardware solution.
The A162 dual pulse delay has a second function in which you can adjust the
pulse width.
The delay time can be set to zero thereby making it useful for your problem
too I guess.
It's a slightly costly solution to your problem but it will work.
Grtz
Ernst
On Sun, Jan 2, 2011 at 3:21 PM, mbox_online <mbox@online.no> wrote:
> Hello
> Any hope?
> Thanks
> Martin
