Doepfer
modded a-110 question -
2010-08-22 by davevosh@aol.com
In a message dated 8/22/2010 5:11:43 PM Eastern Standard Time,
synaptic_music@yahoo.com writes:
a110  standard vco (modded
ingo,
a question on the mod`s -
i performed the one for linear fm and like it a lot but i didn`t add the
soft sync thinking it wouldn`t add much - having used it, what are your
thoughts  - ? also, i note that you didn`t add the potentiometer - ?
best,
dave
Re: [Doepfer_a100] modded a-110 question -
2010-08-22 by James Ulibarri
Anyone selling a Regelwerk?  I want a blue led version,  hopefully with the
blue LCD also.
I know Dieter made them for the last run.   Let me know..    I am in sunny
California.
Re: modded a-110 question -
2010-08-23 by selfoscillate
> ingo,
> best,
> dave
hello dave,
soft sync sounds clearly different compared to hard sync.
it is not really possible to say which sounds better, it is too
much a matter of taste. to my ears the soft sync sounds cleaner
and less fuzzy, so i tend to use soft sync more often than
hard sync, at least on my a110's. for me the soft sync option
is more usable and therefore well worth wiring an additional
jack for it. of course i can only speak for myself.
correct, there is no potentiometer at the lin fm input, which
indeed would be a good addition. i don't have this because
usually i use a vca in front of the lin fm input anyway,
and without a knob it was easy to keep the additional
panel at a size of 4 te.
best wishes
ingo
